Help removing rocker clips #1971488
12/17/15 03:59 PM
12/17/15 03:59 PM
WNY
slimert Offline OP
slimert  Offline OP
WNY
How do you remove (without damaging) the rocker moulding clips from a 68 Coronet?? Not sure if the center plastic 'rivet' needs to be drilled out? Any advice sure would be appreciated!
Mike
Re: Help removing rocker clips [Re: slimert] #1971505
12/17/15 04:24 PM
12/17/15 04:24 PM
fargo,nd
fk5hemi Offline
fk5hemi  Offline
fargo,nd
I have drilled the center pin with small drill bit. Screw in small screw. Grab screw head with vice-grip and pull center pin out.
Re: Help removing rocker clips [Re: slimert] #1971723
12/17/15 10:40 PM
12/17/15 10:40 PM
WNY
slimert Offline OP
slimert  Offline OP
WNY
Nice! Thank you for that tip!
