Any interest in a Power Window relay kit? #1970659
12/16/15 02:52 AM
12/16/15 02:52 AM
CA
crackedback Online content OP
crackedback  Online Content OP
CA
I was speaking with a member about the benefits of relays for power windows for B, C and E body cars.
The kit would consist of 8 relays, 2 for each window, and be set up essentially as plug and play using correct Packard 56 connectors at the motors. Some finish termination would be required at the supplemental fuse block provided to tailor wiring to each car. Enough wire would be provided to make a clean installation.
Same build quality as my other relay kits, using as many components sourced from the US as possible. Pricing would be in the 250-300 range depending on brand of relays used, Picker relays on lower end, Tyco/Bosch on the higher end of price scale.
Would there be any interest in a kit like this? Thanks for any input.
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1971055
12/16/15 08:54 PM
12/16/15 08:54 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I thought about it for my 72 road runner
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1971056
12/16/15 08:56 PM
12/16/15 08:56 PM
CA
CA
The member I spoke with says the windows work similar to a new car now. Window up and down, Stop to stop with good speed. Loads are taken off the switch, bulkhead, ammeter and factory wiring. Gets upgraded to at least 12GA wire for all power carrying circuits in the kit.
I've sold one kit on another site, along with a vert top relay kit. Putting it together this weekend.
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1971145
12/16/15 11:17 PM
12/16/15 11:17 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i'd be interested in a kit for my 71 challenger convertible if it makes a difference.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1971158
12/16/15 11:30 PM
12/16/15 11:30 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've added relays to a couple cars. Really makes a difference.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1971360
12/17/15 11:33 AM
12/17/15 11:33 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
do you have a website with your relay kits?
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1971440
12/17/15 02:43 PM
12/17/15 02:43 PM
CA
CA
I don't have a website. That may be in the works.
Here are two threads at another site that have examples of my products.
http://www.forabodiesonly.com/mopar/showthread.php?t=334888
http://www.forabodiesonly.com/mopar/showthread.php?t=216514
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1972611
12/19/15 12:47 PM
12/19/15 12:47 PM
dart1962_440 Offline
How much do you think it'd help on a b-body convert? Mine are super slow.
Re: Any interest in a Power Window relay kit? [Re: dart1962_440] #1972685
12/19/15 02:41 PM
12/19/15 02:41 PM
Massachussetts
RCKTMN Offline
RCKTMN  Offline
Massachussetts
I would be interested in a set for my 1970 Barracuda convertible.
1970 Barracuda Convertible
1970 Newport Convertible
1970 Satellite Convertible
1974 'Cuda shell - '71 conversion
1988 Oldsmobile Cutlass w/455
2003 RAM3500 CTD
2007 Caliber R/T AWD
2007 Magnum SRT-8
2016 Chrysler Town & Country
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1974572
12/22/15 03:19 PM
12/22/15 03:19 PM
CA
CA
The relays help both window and vert top speed a lot.
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1974638
12/22/15 04:35 PM
12/22/15 04:35 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Interesting. On a side note, does anyone make an electric window kit that actually works correctly? I have a Duster and I've heard that most of the kits out there don't even have enough power to move the window so you have to help it with your hand. These relays may help that though.
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1974873
12/22/15 11:59 PM
12/22/15 11:59 PM
CA
CA
If the window motors aren't getting the voltage they should, same as the headlights being dim, they just don't work as designed.
Here's a picture of a kit I put together today. Should have it finished up tomorrow.
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1975302
12/23/15 07:10 PM
12/23/15 07:10 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Before I buy the relays I need to find an electric window kit, it looks like Electric-Life doesn't make a kit for a '72 Duster.
https://www.electric-life.com/product-ca...opar-dodge-car/
Re: Any interest in a Power Window relay kit? [Re: crackedback] #1998961
01/26/16 12:46 PM
01/26/16 12:46 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I still can't find a 72 Duster electric window kit! I can't believe Electric-Life makes them for the 73-76 Dart but not the 70-72 Duster.
