oil galley plug removal #1964118
12/06/15 01:07 AM
12/06/15 01:07 AM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
Ok guys, I found my engine is missing the oil galley plug by the distributor. The outer plug on back of the engine has a square opening for a socket. I have been looking everywhere to buy a socket,I cannot find one. What the heck do you use to get it out. It is smaller than a 3/8 rachet,and larger than a 1/4 rachet.
Re: oil galley plug removal [Re: dartphil] #1964124
12/06/15 01:10 AM
12/06/15 01:10 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
they sell diff. size sockets for them.
I would check your local parts store . napa maybe.
I know the tool trucks sell them
Re: oil galley plug removal [Re: dartphil] #1964126
12/06/15 01:12 AM
12/06/15 01:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I made mine... milled down a 3/8 square steel bar
stock.. once its out put in a allen head plug... you
could sand down a piece of 3/8 square if you have a
grinder or a belt sander
wave
Re: oil galley plug removal [Re: a493demon] #1964128
12/06/15 01:13 AM
12/06/15 01:13 AM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
Thanks Ichecked sears and the discount tool store,I'll try napa and carquest tomorrow
Re: oil galley plug removal [Re: dartphil] #1964143
12/06/15 01:34 AM
12/06/15 01:34 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I was in a bind once and took a 1/2 inch hex head bolt and taper ground four sides with my bench grinder on the threaded side. Worked great as I could use a socket or open end wrench on the hex end
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: oil galley plug removal [Re: dartphil] #1964174
12/06/15 02:38 AM
12/06/15 02:38 AM
I use a square punch or chisel that fits tight into those plugs and then a crescent wrench to turn the square part thumbs scope Some of the SB inner oil galley oilplugs use the same type of oil galley plugs the next size smaller, some use a standard allen head size pipe plug shruggy
Re: oil galley plug removal [Re: dartphil] #1964239
12/06/15 10:40 AM
12/06/15 10:40 AM
pennsylvania
poboyengineering Offline
pennsylvania
I took an old extension and ground on it a bit. worked like a champ.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: oil galley plug removal [Re: dartphil] #1964272
12/06/15 12:01 PM
12/06/15 12:01 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
It's 5/16". Snap On sells a tool for it.
2011 Drag Pak Challenger
Re: oil galley plug removal [Re: dartphil] #1964327
12/06/15 01:18 PM
12/06/15 01:18 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
If it's 5/16, you could get a piece of 5/16 keystock from Lowes, Home Depot or Tractor Supply then use a wrench on it. I'm sure it's not as tough as the snap-on tool but might do the trick in a pinch twocents
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: oil galley plug removal [Re: dartphil] #1964409
12/06/15 04:12 PM
12/06/15 04:12 PM
Washington
madscientist Offline
Washington
Use a piece of 5/16 keystock. Heat the plug to red hot. Let it cool a bit. Hit it with some WD40 or rub some parrafin on it. Use the keystock and your hand to back the plug out.
Heat the PLUG, not the BLOCK.
Re: oil galley plug removal [Re: madscientist] #1965033
12/07/15 06:18 PM
12/07/15 06:18 PM
st. Louis Mo.
dartphil Offline OP
dartphil  Offline OP
st. Louis Mo.
Thanks far all the replys, I got it out using a large flat screwdriver that fit tight in the corners and put my pipe wrench on the end, it came right out.
Re: oil galley plug removal [Re: dartphil] #1965042
12/07/15 06:34 PM
12/07/15 06:34 PM
PA.
"Little"John
"Little"John
PA.
GREAT job. I love it when hot rodders use some ingenuity instead of rushing out to buy a SPECIAL tool to do every job.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: oil galley plug removal [Re: dartphil] #1965044
12/07/15 06:39 PM
12/07/15 06:39 PM
an8sec70cuda Offline
I have an allen wrench that was close to being the right size. Just ground the end down square to fit the plug and cut it off short so it fits in a socket. Use it w/ a ratchet and takes em right out.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: oil galley plug removal [Re: an8sec70cuda] #1965139
12/07/15 09:49 PM
12/07/15 09:49 PM
NJ
cb1289 Online content
cb1289  Online Content
NJ
Probably is a 8mm square plug. Pep Boys auto parts sells 8mm & 10mm square head 3/8" drive sockets for about 5 bucks ea. Or check the internet. www.ctatools.com. Just used them on my motor. Perfect fit.
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: oil galley plug removal [Re: cb1289] #1965886
12/08/15 09:48 PM
12/08/15 09:48 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
can't find it on their site now, but Harbor Freight used to sell a drain plug bit set that included the 5/16 square. That's what I use.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: oil galley plug removal [Re: dartphil] #1967055
12/10/15 02:07 PM
12/10/15 02:07 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
BTW, I would not recommend replacing the square plugs with a mopar perf hex allen head plug (especially on the large plugs).
They tend to strip easily when you try to remove them.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
