Re: oil galley plug removal
[Re: dartphil]
#1964126
12/06/15 01:12 AM
12/06/15 01:12 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I made mine... milled down a 3/8 square steel bar stock.. once its out put in a allen head plug... you could sand down a piece of 3/8 square if you have a grinder or a belt sander
[Re: dartphil]
#1964143
12/06/15 01:34 AM
12/06/15 01:34 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I was in a bind once and took a 1/2 inch hex head bolt and taper ground four sides with my bench grinder on the threaded side. Worked great as I could use a socket or open end wrench on the hex end
[Re: dartphil]
#1964239
12/06/15 10:40 AM
12/06/15 10:40 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
I took an old extension and ground on it a bit. worked like a champ.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: dartphil]
#1964409
12/06/15 04:12 PM
12/06/15 04:12 PM
Posts: 4,457 Washington
madscientist
Washington
Use a piece of 5/16 keystock. Heat the plug to red hot. Let it cool a bit. Hit it with some WD40 or rub some parrafin on it. Use the keystock and your hand to back the plug out.
Heat the PLUG, not the BLOCK.
[Re: dartphil]
#1965042
12/07/15 06:34 PM
12/07/15 06:34 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks far all the replys, I got it out using a large flat screwdriver that fit tight in the corners and put my pipe wrench on the end, it came right out. GREAT job. I love it when hot rodders use some ingenuity instead of rushing out to buy a SPECIAL tool to do every job.
[Re: dartphil]
#1965044
12/07/15 06:39 PM
12/07/15 06:39 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I have an allen wrench that was close to being the right size. Just ground the end down square to fit the plug and cut it off short so it fits in a socket. Use it w/ a ratchet and takes em right out.
[Re: an8sec70cuda]
#1965139
12/07/15 09:49 PM
12/07/15 09:49 PM
Posts: 145 NJ
cb1289
NJ
Probably is a 8mm square plug. Pep Boys auto parts sells 8mm & 10mm square head 3/8" drive sockets for about 5 bucks ea. Or check the internet. www.ctatools.com. Just used them on my motor. Perfect fit.
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: cb1289]
#1965886
12/08/15 09:48 PM
12/08/15 09:48 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
can't find it on their site now, but Harbor Freight used to sell a drain plug bit set that included the 5/16 square. That's what I use.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: dartphil]
#1967055
12/10/15 02:07 PM
12/10/15 02:07 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
BTW, I would not recommend replacing the square plugs with a mopar perf hex allen head plug (especially on the large plugs).
They tend to strip easily when you try to remove them.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
