starter question
#1963105
12/04/15 02:13 PM
12/04/15 02:13 PM
Posts: 361 Yocumtucky,PA
moparbo
Yocumtucky,PA
Recently we were trying to get my friend's 62 Valiant Wagon /6 running. Every time you crank it over, as soon as you get any king of spark, the starter seems to disengage from the flywheel, but continues to spin as the key is turned. This is becoming annoying because the car has been sitting and needs that bit of extra starter help to get it going. Has anyone else encountered this and is there a way to bypass? Is it just in need of a new starter? Any help is greatly appreciated!
There's no "I" in team..........but there's "ME"
Re: starter question
[Re: moparbo]
#1963122
12/04/15 02:34 PM
12/04/15 02:34 PM
moparbo
Yocumtucky,PA
The flux capacitor is good as it is putting out the required 1.21 gigawatts. Whilst at it I checked the turn signal fluid, muffler bearing, and even the glasspacks on the mufflers.
[Re: moparbo]
#1963170
12/04/15 03:32 PM
12/04/15 03:32 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
The bendix is kicking out.Years ago we took them apart and fixed them as starters were pricey.Now they are cheap.Try a mini and you will never go back to the old starter.Rocky
Chrysler Firepower
[Re: therocks]
#1963176
12/04/15 03:39 PM
12/04/15 03:39 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Amen to the Nipondenso mini-starter. I think that any of the newer ones from those found on the minivan V6s to the 5.7 Hemi in the trucks are all the same...but I could be wrong, I often am.
I put one of the Mopar mini-starters on my '64 Polara's 440 motor and it is still going strong, 19 years later.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1963184
12/04/15 03:50 PM
12/04/15 03:50 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Yep... Bolted mine in, in '94... (The heat-shielded variety...)
[Re: moparbo]
#1963526
12/05/15 01:31 AM
12/05/15 01:31 AM
moparbo
Yocumtucky,PA
Great! Thanks for all of the help and info. New starter it is!
[Re: moparbo]
#1963721
12/05/15 01:20 PM
12/05/15 01:20 PM
therocks
Niles , Ohio
I think we still have the starter from the 62 300.Put in a new mini and kept the old one.Still have the OE trans and complete heads from it also.Rocky
Chrysler Firepower
