help with conv identity
#1957071
11/24/15 02:32 PM
11/24/15 02:32 PM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
the ring gear says 47339E12 CH RG 130 It's a 10" conv Trying to figure out what brand and all specs. Any info appriciated
thanks
It's a bigblock with a torque flight!!!
Re: help with conv identity
[Re: CMcAllister]
#1958010
11/26/15 12:22 AM
11/26/15 12:22 AM
mopar_to_ya
south central,Pa
Hey Cole, what's new in your neck of the woods? It is black in color, and is a 10". It has 5/16 bolts. I was told it was ATI, but I called them and they never heard of a number like that. thanks for the reply
[Re: mopar_to_ya]
#1959151
11/28/15 11:39 AM
11/28/15 11:39 AM
mopar_to_ya
south central,Pa
here is a pic, I'm sure someone has seen one like this before. Maybe an Alambama conv???
[Re: mopar_to_ya]
#1960125
11/30/15 07:01 AM
11/30/15 07:01 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
50,000 members and nobody has ever seen a conv like this? lol
BUMP Sure.......seen plenty. It's black and it's a torque converter. The number on the gear is likely just the gear number. With no stampings on either half...........yep, it's a torque converter and that's about all any one will be able to tell you. I CAN tell you this, it's likely NOT an ATI. Never seen a company like that that doesn't stamp them. How would THEY even know what it was with no numbers on it. Lots of local trans shops built converters for people. Probably what that is. You want to know the "specs" somebody will have to cut it open and see what parts are in it
[Re: mopar_to_ya]
#1960255
11/30/15 03:17 PM
11/30/15 03:17 PM
Posts: 43,719 Bend,OR USA
Cab_Burge
BUMP Let see, 10 inch converter with no I.D #s and 5/16 bolts, probaly a real cheap one like the old hated GER brand
[Re: Cab_Burge]
#1960397
11/30/15 07:48 PM
11/30/15 07:48 PM
Posts: 12,289 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Ronnie, I see no-name 11" converters that look like that all over ebay for a couple hundred bucks. But no 10". Don't know anything else other than to have it opened up to find out exactly what it is.
[Re: Cab_Burge]
#1960555
11/30/15 11:47 PM
11/30/15 11:47 PM
mopar_to_ya
south central,Pa
I had a junk GER conv years ago, lol. It actually looked like a normall conv, but it was def a p.o.s. I would like to find a brand that looks similar and call the company but, oh well. I'll just sell it or put it in something to check it.
[Re: CMcAllister]
#1960556
11/30/15 11:49 PM
11/30/15 11:49 PM
mopar_to_ya
south central,Pa
Yeah, Cole, that's why I took the chance on this one from a friend, because it is a 10"
[Re: CMcAllister]
#1961085
12/01/15 05:04 PM
12/01/15 05:04 PM
Posts: 26,470 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Ronnie, I see no-name 11" converters that look like that all over ebay for a couple hundred bucks. But no 10". Most 11" converters are based on factory cores where the ring gear attaches directly to the shell, ring gears attached with "spokes" like the pic are 10" and smaller.
[Re: mopar_to_ya]
#1961098
12/01/15 05:26 PM
12/01/15 05:26 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I've never seen one that was smooth like that one is. Best thing is to have it cut open and inspected. My local guy will do that pretty cheap.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: mopar_to_ya]
#1961197
12/01/15 08:16 PM
12/01/15 08:16 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If nothing else, it would be interesting to know what it is. Seems you have the only one.
[Re: John_Kunkel]
#1961454
12/02/15 01:41 AM
12/02/15 01:41 AM
mopar_to_ya
south central,Pa
I guess I need another pic to explain what I'm thinking, lol. If that makes any sense at all. The bottom of the shell isn't radiused like most.
