BB rods, preference? #1958770
11/27/15 02:16 PM
11/27/15 02:16 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
BB Chevy journal and pin, 7.100". It has BME 426 forgings which have performed great. The problem is maintenance. 300 passes comes up pretty quick. Engine runs to 7100 makes 850-900hp. If I go to steel then I'm sure it's going to need mallory. Steel rods being anywhere from about $600 (Scat, Eagle ,Molinar, etc) to $1500 (Manley, Oliver or for that matter BME). What do you like?
Doug
Re: BB rods, preference? [Re: dvw] #1958880
11/27/15 07:08 PM
11/27/15 07:08 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
440 Source is $499 delivered. Good price. Should hold the power and I have no reason to think that any other Chinese rods are any better.
2011 Drag Pak Challenger
Re: BB rods, preference? [Re: rickseeman] #1958891
11/27/15 07:18 PM
11/27/15 07:18 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I have K1 rods in my 572, Eagle rods in my 422, Molnars in my 360, K1's in my 408, and 440source are going in my 512 engine that I am putting together right now. All are H beem rods with upgraded rod bolts. my last set of 440sorce rods made 275 8 seconds passes until I found a crack in my 440 block. I sold the whole assembly and it now has 2 Summers on the street. I personally would not buy the Eagle rods but I bought the whole 422 rotating assembly from a Friend.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: BB rods, preference? [Re: rickseeman] #1958936
11/27/15 08:40 PM
11/27/15 08:40 PM
SoCal
Brian Hafliger Offline
SoCal
That's like saying all American rods will have the same quality or power/rpm rating...not good advice...but I get what your saying.
There is a big difference between the way Eagle, Scat, Molnar, K1 and other do their rods compared to Carrillo, Callies, Oliver, etc....
Brian
Brian Hafliger
Re: BB rods, preference? [Re: Brian Hafliger] #1958942
11/27/15 08:46 PM
11/27/15 08:46 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Brian
Brian what are your thoughts? What would you suggest?
Doug
Re: BB rods, preference? [Re: dvw] #1958952
11/27/15 09:03 PM
11/27/15 09:03 PM
michigan
sandmangtx Offline
sandmangtx  Offline
michigan
Doug, I would go with the oliver or carrillo rods, even the manleys. There is no sense skimping on the rods a few extra bucks now will save you big bucks later. You know what to do .... Just do it. lol
Re: BB rods, preference? [Re: dvw] #1958985
11/27/15 10:24 PM
11/27/15 10:24 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I've had trouble with rods being up to snuff. I bought a set of Manley Hemi I-beam rods a number of years ago from a SS Hemi racer. They were still new in the box, but when my machinist/engine builder took them apart he found the rod bolts were galled in the threads and under the bolt heads. These rods are around $1600/set new now. I think I paid around $1300 for them and spent another $1k on new rod bolts, ring dowels, and machine work to fix them. For that money, I could have bought Carrillo's with CARR bolts.
I've had problems with other rods for 440s that I've bought as well. One set had the hardness down around 25 HRC, basically the annealed hardness of 4340. Rather disappointing.
Floyd Lippencott IV
Re: BB rods, preference? [Re: dvw] #1958998
11/27/15 10:49 PM
11/27/15 10:49 PM
AndyF Offline
AndyF  Offline
At 900 hp I'd most likely buy a set of Oliver rods but I wouldn't be surprised if the SCAT Pro H beam rods handled that power just fine also. Callies makes some nice rods too but they are more expensive than the Olivers.
Re: BB rods, preference? [Re: AndyF] #1959029
11/27/15 11:50 PM
11/27/15 11:50 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Crower
Re: BB rods, preference? [Re: dvw] #1959119
11/28/15 04:14 AM
11/28/15 04:14 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
We run several years with 1600 hp and K1 rods & crank. Now replaced with Molnar parts. We have 440 source rods in the 528, almost ten years now, first with nitrous, then with a blower and now with twin turbo. No rod problems so far.
Plynouth VIP '67 TT IC EFI
Re: BB rods, preference? [Re: dvw] #1959198
11/28/15 01:39 PM
11/28/15 01:39 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I would go with what you have in there now - seems to be working exceptionally well for that combo - but if you were wanting steel then Oliver for reliability - I am looking at the Molnar rods for the HEMI I am building in the same size combo.
Re: BB rods, preference? [Re: dvw] #1959201
11/28/15 01:42 PM
11/28/15 01:42 PM
warren, mich.
dwayne welder Offline
warren, mich.
Hi Doug do you have aluminum rods now? Then who is the manufacture? If you do have aluminum I like BME no matter what anybody says!!!
Re: BB rods, preference? [Re: dvw] #1959220
11/28/15 02:13 PM
11/28/15 02:13 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
BME aluminum right now. car gets around 100 passes a year. I feel 300 runs is safe. Now comes to cost. I can put steel rods in it and be done, Balancing isn't a issue as I can do it. Low cost steel rods, higher end steel, or aluminum. I do like the BME just not the cost every 3 years.
Doug
Re: BB rods, preference? [Re: dvw] #1959525
11/29/15 01:12 AM
11/29/15 01:12 AM
SoCal
SoCal
Doug
I can't guarantee this, but I know many guys running Aluminum rods going well over 300 passes. I'm not saying you should...but I know guys that go 500-700 passes with no problems.
I think if you go over the combo with BME, and do what they tell you about maintenance and procedures, you'll find you can double that # you change them at.
Brian Hafliger
Re: BB rods, preference? [Re: AndyF] #1959530
11/29/15 01:22 AM
11/29/15 01:22 AM
Lehigh Acres, Florida
rickstershemi Offline
CompStar's - 74-7500 900+ 7.90's....Has been 4.60's 1/8 w/NOS in TS and is now back running brackets and SG and never been apart.
Rickster
Re: BB rods, preference? [Re: rickstershemi] #1959544
11/29/15 01:34 AM
11/29/15 01:34 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
If I felt good about using aluminum rods for 300 runs, I agree, stay with them. I use Oliver for steel rods but Carrillo would be the cats a$$ if I could afford them. I think they are around #3000. Penkyl would be on the wish list too. No idea how to spell it.
Re: BB rods, preference? [Re: dvw] #1959584
11/29/15 04:07 AM
11/29/15 04:07 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
GRP for me. We have been 400+ passes on them with no issues. This was at 1088hp. If you want steel Pankyl are the best, parent company of CP/Carillo. Carillos are nice as well.
Re: BB rods, preference? [Re: dvw] #1959604
11/29/15 07:50 AM
11/29/15 07:50 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
I agree with the sentiment to stay with the aluminum rods. No adding Mallory to the crank, easier on the block and bearings. I'd get another set of BME's, since you've had good performance and send the current set back for evaluation, perhaps reuse/spare set. Most of the people I know running aluminum rods go 500+ runs on them, so you're probably being too conservative there. S/F.....Ken M
Re: BB rods, preference? [Re: dvw] #1959631
11/29/15 11:36 AM
11/29/15 11:36 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
4 very hard years on my Manley H beams no
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: BB rods, preference? [Re: dvw] #1959674
11/29/15 01:33 PM
11/29/15 01:33 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
i have olivers in mine. also found some trans problems so the car should be back to where it was.
