BB rods, preference?
#1958770
11/27/15 01:16 PM
11/27/15 01:16 PM
Posts: 10,043 MI, usa
dvw
MI, usa
BB Chevy journal and pin, 7.100". It has BME 426 forgings which have performed great. The problem is maintenance. 300 passes comes up pretty quick. Engine runs to 7100 makes 850-900hp. If I go to steel then I'm sure it's going to need mallory. Steel rods being anywhere from about $600 (Scat, Eagle ,Molinar, etc) to $1500 (Manley, Oliver or for that matter BME). What do you like? Doug
Re: BB rods, preference?
[Re: dvw]
#1958880
11/27/15 06:08 PM
11/27/15 06:08 PM
Posts: 2,760 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
440 Source is $499 delivered. Good price. Should hold the power and I have no reason to think that any other Chinese rods are any better.
2011 Drag Pak Challenger
[Re: rickseeman]
#1958891
11/27/15 06:18 PM
11/27/15 06:18 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have K1 rods in my 572, Eagle rods in my 422, Molnars in my 360, K1's in my 408, and 440source are going in my 512 engine that I am putting together right now. All are H beem rods with upgraded rod bolts. my last set of 440sorce rods made 275 8 seconds passes until I found a crack in my 440 block. I sold the whole assembly and it now has 2 Summers on the street. I personally would not buy the Eagle rods but I bought the whole 422 rotating assembly from a Friend.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: rickseeman]
#1958936
11/27/15 07:40 PM
11/27/15 07:40 PM
Posts: 5,488 SoCal
Brian Hafliger
SoCal
440 Source is $499 delivered. Good price. Should hold the power and I have no reason to think that any other Chinese rods are any better. That's like saying all American rods will have the same quality or power/rpm rating...not good advice...but I get what your saying. There is a big difference between the way Eagle, Scat, Molnar, K1 and other do their rods compared to Carrillo, Callies, Oliver, etc.... Brian
Brian Hafliger
[Re: Brian Hafliger]
#1958942
11/27/15 07:46 PM
11/27/15 07:46 PM
dvw
MI, usa
440 Source is $499 delivered. Good price. Should hold the power and I have no reason to think that any other Chinese rods are any better. That's like saying all American rods will have the same quality or power/rpm rating...not good advice...but I get what your saying. There is a big difference between the way Eagle, Scat, Molnar, K1 and other do their rods compared to Carrillo, Callies, Oliver, etc.... Brian Brian what are your thoughts? What would you suggest? Doug
[Re: dvw]
#1958985
11/27/15 09:24 PM
11/27/15 09:24 PM
Posts: 3,513 DFW
mr_340
DFW
I've had trouble with rods being up to snuff. I bought a set of Manley Hemi I-beam rods a number of years ago from a SS Hemi racer. They were still new in the box, but when my machinist/engine builder took them apart he found the rod bolts were galled in the threads and under the bolt heads. These rods are around $1600/set new now. I think I paid around $1300 for them and spent another $1k on new rod bolts, ring dowels, and machine work to fix them. For that money, I could have bought Carrillo's with CARR bolts.
I've had problems with other rods for 440s that I've bought as well. One set had the hardness down around 25 HRC, basically the annealed hardness of 4340. Rather disappointing.
Floyd Lippencott IV
[Re: AndyF]
#1959029
11/27/15 10:50 PM
11/27/15 10:50 PM
Posts: 370 Indy
496 A-body
Indy
[Re: dvw]
#1959119
11/28/15 03:14 AM
11/28/15 03:14 AM
Posts: 2,936 Finalnd, Perkele
jyrki
Finalnd, Perkele
We run several years with 1600 hp and K1 rods & crank. Now replaced with Molnar parts. We have 440 source rods in the 528, almost ten years now, first with nitrous, then with a blower and now with twin turbo. No rod problems so far.
Plynouth VIP '67 TT IC EFI
[Re: dvw]
#1959525
11/29/15 12:12 AM
11/29/15 12:12 AM
Posts: 5,488 SoCal
Brian Hafliger
SoCal
BME aluminum right now. car gets around 100 passes a year. I feel 300 runs is safe. Now comes to cost. I can put steel rods in it and be done, Balancing isn't a issue as I can do it. Low cost steel rods, higher end steel, or aluminum. I do like the BME just not the cost every 3 years. Doug I can't guarantee this, but I know many guys running Aluminum rods going well over 300 passes. I'm not saying you should...but I know guys that go 500-700 passes with no problems. I think if you go over the combo with BME, and do what they tell you about maintenance and procedures, you'll find you can double that # you change them at.
Brian Hafliger
[Re: AndyF]
#1959530
11/29/15 12:22 AM
11/29/15 12:22 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
At 900 hp I'd most likely buy a set of Oliver rods but I wouldn't be surprised if the SCAT Pro H beam rods handled that power just fine also. Callies makes some nice rods too but they are more expensive than the Olivers. CompStar's - 74-7500 900+ 7.90's....Has been 4.60's 1/8 w/NOS in TS and is now back running brackets and SG and never been apart. Rickster
[Re: dvw]
#1959584
11/29/15 03:07 AM
11/29/15 03:07 AM
Posts: 19,599 Las Vegas
Al_Alguire
Las Vegas
GRP for me. We have been 400+ passes on them with no issues. This was at 1088hp. If you want steel Pankyl are the best, parent company of CP/Carillo. Carillos are nice as well.
