Indy alumium block
#1956059
11/22/15 08:28 PM
11/22/15 08:28 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
I am having a new 600" motor built, I will be using the Indy Alum RB block. I see that they have machined pads on the side of the block for what appears to be engine mounts, are these for Hemi style mounts? This motor will be going into a 68 Cuda with a Hemi Denny coil over front suspension. I do not want to use a motor plate with this engine, can I just get the Hemi style mounts that would go to my Hemi Denny suspension?
I guess you can not get this block with the wedge style mounting ears?
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Indy alumium block
[Re: Old School]
#1956138
11/22/15 10:34 PM
11/22/15 10:34 PM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
That is a good question....I do not know on the pads. Mine was ordered without any motor mount provisions and I used a plate in my e-body. What I will tell you is good luck fitting it in the 68 A-body... We have a 474 Hemi in one with an older Cummins block...PITA it is...And yours might be worse, and I will tell you why. The front of the block is also cross bolted on the Indy blocks unlike a stock block. The boss there is wider than a standard block on both sides, so I am not sure if that will interfere with a motor mounts, steering or what not. On all of our installs we used a plate. And on our A-body Hemi below, we cut the passenger fender big time and re-welded it. No pics of this currently though.
[Re: Old School]
#1956357
11/23/15 10:26 AM
11/23/15 10:26 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
We use those pads too. The block is thin there, but so far, in 15 years, no problem.
Plynouth VIP '67 TT IC EFI
[Re: Old School]
#1956529
11/23/15 04:53 PM
11/23/15 04:53 PM
Posts: 2,933 A shed in England
Tig
A shed in England
Here's a pic if it helps.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1956622
11/23/15 06:51 PM
11/23/15 06:51 PM
Old School
Virginia Beach, VA
Here's a pic if it helps. Tig, are you using the mounts on the block or a plate? Todd Marsh is building my motor also. After reading about yours on here, I knew he was the one to build mine. Mine will be a 600" indy max block. 572-13 heads, 13.5, solid roller, street car motor.....
[Re: Old School]
#1956694
11/23/15 09:01 PM
11/23/15 09:01 PM
Posts: 9,866 MI, usa
dvw
MI, usa
I guess you can not get this block with the wedge style mounting ears? Why a 600" motor and no plate? I'm not sure I'd want the stress of mounts on the side of an Indy aluminum block. Doug
[Re: Old School]
#1956859
11/24/15 12:41 AM
11/24/15 12:41 AM
Tig
A shed in England
We use a motor plate and a home built mount that fits the block and the rhs K mount for a limiter, It ain't pretty but can be removed with the motor in place. Motor plate is 3/8th thick. The lhs mount is removed from the K frame for clearance for the Milodon dual lines and oil pump. Having only one limiter on one side doesn't seem to cause any problems. Motor sounds cool and Todd's great to work with also. HTH's.
