A-body fastener master kit? Paint color reference guide? #1955201
11/21/15 01:56 AM
11/21/15 01:56 AM
State, country, etc.
gss Offline OP
gss  Offline OP
Who sells an A-body fastener kit? I have checked the usual places and can't fine one. The car is a Demon.
Also, is there a paint color reference guide for these cars? Something that shows what parts were dipped, sprayed, or left bare, and what the correct color would be?
Thanks!
Re: A-body fastener master kit? Paint color reference guide? [Re: gss] #1955218
11/21/15 03:06 AM
11/21/15 03:06 AM
BlueRacer69 Offline
BlueRacer69  Offline
You need to be a little clearer on what type fastener kit. Inside car ,outside car, what? Year-One use to have A-body kits, don`t know if they still do.
Re: A-body fastener master kit? Paint color reference guide? [Re: BlueRacer69] #1955227
11/21/15 04:50 AM
11/21/15 04:50 AM
gss Offline OP
gss  Offline OP
Complete body and under hood kit. An interior kit wouldn't hurt either.
Re: A-body fastener master kit? Paint color reference guide? [Re: gss] #1955229
11/21/15 05:04 AM
11/21/15 05:04 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Most anybody who sells a fastener kit is re-selling an AMK kit with markup. Go to amkproducts.com > pdf catalog > pages 196-201. The kits won't be 100% correct for your car, just correct for some Chrysler application - there were too many fastener vendors to offer each and every item from every vendor.
It may be better to restore your own fasteners and buy the shortages from the bulk catalog pages before page 196, unless a certain kit is exactly what you want.
Nearly all machine screws and bolts were high strength Grade 5 or higher with maker's marks, but many Phillips head tapping screws were generic and can be replaced with hardware store generic or re-plated.
Mostly the bare parts were in the drive train and suspension: control arms, transmission, drive shaft, center section, springs, spring hangers/shackles, U bolts, shock plates. Verify, but probably all your small brackets that are black were dip painted in the same sg black enamel on water. The K frame and axle housing were spray painted sg black. Most people agree Chrysler used gloss black for the dip and spray that soon went dull, so sg black is accepted as correct.
Re: A-body fastener master kit? Paint color reference guide? [Re: gss] #1955234
11/21/15 06:19 AM
11/21/15 06:19 AM
WA
tman Offline
tman  Offline
WA
I've used these folks
https://mrgusa.com/
Re: A-body fastener master kit? Paint color reference guide? [Re: gss] #1955393
11/21/15 03:56 PM
11/21/15 03:56 PM
BlueRacer69 Offline
BlueRacer69  Offline
To the best of my knowledge no one makes what you would call a complete master fastener kit, that would cover everything on/in an entire car. There would still be a occasional fastener you would need to buy individually sometimes. Example,You can buy a complete interior kit but it won`t have headliner clips with it. You can buy a complete exterior kit, but it would not have say rocker panel fasteners, and so on. Try Tom Race @ R/T Specialty. He sells a lot of mopar fasteners you can't find elsewhere. He use to have a website.
Re: A-body fastener master kit? Paint color reference guide? [Re: tman] #1955896
11/22/15 04:40 PM
11/22/15 04:40 PM
gss Offline OP
gss  Offline OP
https://mrgusa.com/
It looks like they can supply most of what I need, Thanks! up
Re: A-body fastener master kit? Paint color reference guide? [Re: gss] #1956068
11/22/15 08:50 PM
11/22/15 08:50 PM
WA
tman Offline
tman  Offline
WA
You bet. Screws are individually packaged and labeled so you know where they go.
Re: A-body fastener master kit? Paint color reference guide? [Re: tman] #1956591
11/23/15 06:07 PM
11/23/15 06:07 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yep, too bad most aren't even close to the originals, but they work. Dave Wise has guides but has not done the A-Body manuals yet. tsk
http://www.mmcdetroit.com/Market_Place/
JB Rhinehart, Realist
A-Body's RULE!
Re: A-body fastener master kit? Paint color reference guide? [Re: gss] #1956661
11/23/15 08:02 PM
11/23/15 08:02 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you don't have the originals for your car to refer to the next best thing is to buy a parts car from the same year, plant, and time of production and refer to or steal them off of it as needed.
Re: A-body fastener master kit? Paint color reference guide? [Re: ScottSmith_Harms] #1957267
11/24/15 07:36 PM
11/24/15 07:36 PM
gss Offline OP
gss  Offline OP
That would be nice. The problem is most of these old cars have been messed with and have the wrong fasteners so you still don't know what is correct. If the car has reached "parts car" status, then it is probably worse off than my car. Mine isn't too bad, but it would be nice not to have to research, de-rust, strip, and plate or paint each bolt.
I've been thinking of trying a vibratory tumbler to restore the hardware. Any experience with those?
Re: A-body fastener master kit? Paint color reference guide? [Re: gss] #1957281
11/24/15 08:02 PM
11/24/15 08:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes I understand, but I practice what I preach (I have two parts Dusters for my own project Duster). There's no easy out (even if there were a fastener manual).
Yes, I use tumblers a lot, good tools. The media is the key, different media for different purposes, like anything, experimenting will guide you.
.02
Re: A-body fastener master kit? Paint color reference guide? [Re: gss] #1957662
11/25/15 01:58 PM
11/25/15 01:58 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
If you live in the better weather parts of the country you can probably find A body's in the JY.
Re: A-body fastener master kit? Paint color reference guide? [Re: ademon] #1957925
11/25/15 10:17 PM
11/25/15 10:17 PM
gss Offline OP
gss  Offline OP
I will keep an eye out for a parts car.
There has to be some accepted info on color and finishes of the major components floating around. Any direction would be appreciated up
Re: A-body fastener master kit? Paint color reference guide? [Re: gss] #1957970
11/25/15 11:24 PM
11/25/15 11:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: A-body fastener master kit? Paint color reference guide? [Re: ScottSmith_Harms] #1958446
11/26/15 06:01 PM
11/26/15 06:01 PM
gss Offline OP
gss  Offline OP
Great build threads, I don't know how I missed those realcrazy
Yes, this is the start of my research. I hate to reinvent the wheel. It sounds like what you are really saying is don't expect someone to volunteer that top secret information.... tsk
Re: A-body fastener master kit? Paint color reference guide? [Re: gss] #1958457
11/26/15 06:36 PM
11/26/15 06:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It's not top secret, the details vary with every car. You'll find many of tips you'll need on the above threads. There is no "book" or individual with all the answers you are seeking.
