A-body fastener master kit? Paint color reference guide?
#1955201
11/21/15 01:56 AM
11/21/15 01:56 AM
Posts: 1,121 State, country, etc.
gss
Who sells an A-body fastener kit? I have checked the usual places and can't fine one. The car is a Demon.
Also, is there a paint color reference guide for these cars? Something that shows what parts were dipped, sprayed, or left bare, and what the correct color would be?
Thanks!
Re: A-body fastener master kit? Paint color reference guide?
[Re: gss]
#1955229
11/21/15 05:04 AM
11/21/15 05:04 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Most anybody who sells a fastener kit is re-selling an AMK kit with markup. Go to amkproducts.com > pdf catalog > pages 196-201. The kits won't be 100% correct for your car, just correct for some Chrysler application - there were too many fastener vendors to offer each and every item from every vendor.
It may be better to restore your own fasteners and buy the shortages from the bulk catalog pages before page 196, unless a certain kit is exactly what you want.
Nearly all machine screws and bolts were high strength Grade 5 or higher with maker's marks, but many Phillips head tapping screws were generic and can be replaced with hardware store generic or re-plated.
Mostly the bare parts were in the drive train and suspension: control arms, transmission, drive shaft, center section, springs, spring hangers/shackles, U bolts, shock plates. Verify, but probably all your small brackets that are black were dip painted in the same sg black enamel on water. The K frame and axle housing were spray painted sg black. Most people agree Chrysler used gloss black for the dip and spray that soon went dull, so sg black is accepted as correct.
[Re: ScottSmith_Harms]
#1957267
11/24/15 07:36 PM
11/24/15 07:36 PM
gss
If you don't have the originals for your car to refer to the next best thing is to buy a parts car from the same year, plant, and time of production and refer to or steal them off of it as needed. That would be nice. The problem is most of these old cars have been messed with and have the wrong fasteners so you still don't know what is correct. If the car has reached "parts car" status, then it is probably worse off than my car. Mine isn't too bad, but it would be nice not to have to research, de-rust, strip, and plate or paint each bolt. I've been thinking of trying a vibratory tumbler to restore the hardware. Any experience with those?
[Re: gss]
#1957281
11/24/15 08:02 PM
11/24/15 08:02 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I've been thinking of trying a vibratory tumbler to restore the hardware. Any experience with those? Yes I understand, but I practice what I preach (I have two parts Dusters for my own project Duster). There's no easy out (even if there were a fastener manual). Yes, I use tumblers a lot, good tools. The media is the key, different media for different purposes, like anything, experimenting will guide you. .02
