Ball Joint Dust Boots #1955467
11/21/15 06:43 PM
11/21/15 06:43 PM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
I'm rounding up parts to do a suspension rebuild and got a decent deal on some USA made lower ball joints. Unfortunately I only got one dust seal. Some deal right? Rather than deal with RockAuto's return hassle and postage I'd be better off buying a good set of dust boots. Anyone got a good reccomended product? Who's got the best deal? I see sets of polyurethane boots on eBay about $23 with shipping. Anything better on the market?
Thanks!
Re: Ball Joint Dust Boots [Re: Pynzo] #1955475
11/21/15 07:00 PM
11/21/15 07:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I have a strong aversion to anything polyurethane other then paint, stay with rubber, as poly serves little purpose here IMO, could you just re use existing boot? bump
Re: Ball Joint Dust Boots [Re: jcc] #1955479
11/21/15 07:04 PM
11/21/15 07:04 PM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
That's a possible solution. I put some Moogs in early '90s and the boots maybe ok. Just would like to have new ones on hand just in case.
Re: Ball Joint Dust Boots [Re: Pynzo] #1955592
11/21/15 11:00 PM
11/21/15 11:00 PM
md
mopars4ever Offline
mopars4ever  Offline
md
these look close
www.ebay.com/itm/Brand-New-OEM-Seal-Front-Ball-Joint-Suspension-Control-Arm-For-Mopar-04052509-/151746650774?hash=item2354ce2296:g:-MQAAOSwgQ9VpVtX&vxp=mtr
Re: Ball Joint Dust Boots [Re: Pynzo] #1955604
11/21/15 11:40 PM
11/21/15 11:40 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Yeah polyurethane boots suck.
I re-used my Moog rubber boots
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Ball Joint Dust Boots [Re: RylisPro] #1955723
11/22/15 10:24 AM
11/22/15 10:24 AM
moparx Online content
moparx  Online Content
do they crack like cheap "help" rack import rubber boots ? not fit correctly? please explain. i know it's hard to get quality boots, and was thinking about the poly, but now i most likely will keep looking.
beer
Re: Ball Joint Dust Boots [Re: moparx] #1955803
11/22/15 02:06 PM
11/22/15 02:06 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
beer
Whoops!
It looks like I actually have polyurethane boots for my lower ball joints haha!
Sorry its been a couple of years since I re-did my suspension.
For my upper ball joint I tried the poly boots and those did not fit well on my Hotchkis A-arm so that's why I tossed them and re-used the Moog rubber lower ball joint boots as they have a flange and sealed up better
So polyurethane boots for the Lower Ball Joints are good!
Sorry about that!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Ball Joint Dust Boots [Re: RylisPro] #1955940
11/22/15 05:41 PM
11/22/15 05:41 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Those Hotchkis UCAs look well built. Did you gain much caster with them over stock ones?
Re: Ball Joint Dust Boots [Re: Kern Dog] #1956036
11/22/15 07:54 PM
11/22/15 07:54 PM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
X2 on that question. I'm looking at Firm Feel and Hotchkis for uca's. I want the best available. Opinions welcome!
Re: Ball Joint Dust Boots [Re: Pynzo] #1956052
11/22/15 08:17 PM
11/22/15 08:17 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I didnt want to hijack the post. I PM'ed Frankenduster a reply at first here is what I sent:
I forget what my caster was on stock upper A arms?
Here is my alignment with the Hotchkis Arms about a year ago.
here is the latest alignment where I had to fix the toe.
I actually lost caster haha!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Ball Joint Dust Boots [Re: Pynzo] #1956116
11/22/15 10:03 PM
11/22/15 10:03 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I just had mine re-aligned finally and I went to 8* + caster and -1* on my camber. Im loving it.
Mopar to the bone!!!
Re: Ball Joint Dust Boots [Re: RylisPro] #1956130
11/22/15 10:14 PM
11/22/15 10:14 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
You need to get a bit more nutty on your Caster
Re: Ball Joint Dust Boots [Re: Pynzo] #1956146
11/22/15 10:40 PM
11/22/15 10:40 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I didn't realize until now I had less caster. I had a toe wear issue that I was more concerned about for this last alignment.
Yeah I'm leaving a lot left on the table haha!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Ball Joint Dust Boots [Re: RylisPro] #1956362
11/23/15 10:35 AM
11/23/15 10:35 AM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
Thanks for the info!
I'd installed the Moog offset uca bushings last rebuild in early '90s and never could get a decent alignment. Can you use the Hotchkis UCA with tall spindles? I pulled a disc brake setup from a '75 Fury many years ago and was considering installing it finally.
Re: Ball Joint Dust Boots [Re: Pynzo] #1962810
12/04/15 12:47 AM
12/04/15 12:47 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Yes you can make them work with taller spindles. I'm using them with 73 C-Body spindles.
Re: Ball Joint Dust Boots [Re: Pynzo] #1962874
12/04/15 02:20 AM
12/04/15 02:20 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
If it is a street car I would go with the Firm Feels with rubber inner bushings, you can get them with urethane but I would pass.
A new iron curtain drawn across the 49th parallel
Re: Ball Joint Dust Boots [Re: 67autocross] #1962975
12/04/15 10:38 AM
12/04/15 10:38 AM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
Good to know. Is there any need to use the Moog offset bushings with the Firm Feel uca's
Re: Ball Joint Dust Boots [Re: Pynzo] #1963228
12/04/15 04:54 PM
12/04/15 04:54 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Pynzo -- I know someone who installed the moog offset uca bushings into the FF ucas... and was able to get about 7 pos caster... and did that with satisfaction... (67-a-body race car.. GT1 BCuda)... and some neg camber, as well.
Re: Ball Joint Dust Boots [Re: Pynzo] #1963634
12/05/15 10:42 AM
12/05/15 10:42 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
To answer the original question, I found these?....
http://www.rosevillemoparts.com/product_...roducts_id/7876
Re: Ball Joint Dust Boots [Re: brads70] #1963640
12/05/15 11:24 AM
12/05/15 11:24 AM
Philadelphia PA
Pynzo Offline OP
Drugs are bad
Pynzo  Offline OP
Drugs are bad
Philadelphia PA
Thanks!
