vibration in front end
#1954879
11/20/15 02:42 PM
11/20/15 02:42 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I have had a vibration in the front end at speeds of 70mph plus. sometimes it would really happen on nice paved roads, sometimes and lower mph on really crap roads
well after changing lower control arm bushings and lower ball joints the vibration is still kindof there. Then I noticed my rack and pinion has slop in it. I can move the front right tire in and out a good bit. maybe 1/4" maybe more. Is the rack bad or is there something I can do to fix while in the car?
I had hit a terrible pot hole back in 2014 and think that is what caused this
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: vibration in front end
[Re: sixpackgut]
#1955124
11/20/15 11:12 PM
11/20/15 11:12 PM
Posts: 419 NY
F1Scamp
NY
Sounds like a bad inner or outer tie rod to me? When you rock the wheel back and forth can you see the outer tie rod move up and down in the joint? If so, then the outer is bad. Usually the inner just screws off the rack, though some have a roll pin that go through, just pop the boot and see what style you have.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
[Re: sixpackgut]
#1955251
11/21/15 10:14 AM
11/21/15 10:14 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I agree with the inner tie rod, pull the boot back and then shakedown the front end again, you will likely see movement there.
68 Barracuda Formula S 340
[Re: sixpackgut]
#1955322
11/21/15 01:27 PM
11/21/15 01:27 PM
sixpackgut
Charleston
Ok ill try that, thanks guys
