Re: I had to be sure
[Re: Clanton]
#1953745
11/18/15 03:45 PM
11/18/15 03:45 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
I hope that was effective. That should have heated the outside of the block plenty, not sure about the cylinder wall.
[Re: an8sec70cuda]
#1953751
11/18/15 03:54 PM
11/18/15 03:54 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I hope that was effective. That should have heated the outside of the block plenty, not sure about the cylinder wall. The water in the block did the heat transfer very well.
[Re: Clanton]
#1953755
11/18/15 03:57 PM
11/18/15 03:57 PM
an8sec70cuda
I hope that was effective. That should have heated the outside of the block plenty, not sure about the cylinder wall. The water in the block did the heat transfer very well. Good. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I didn't know you had the block filled w/ water.
[Re: dizuster]
#1953761
11/18/15 04:16 PM
11/18/15 04:16 PM
Clanton
northern,Ohio,USA
If it's not a crack... What caused the big rust spot?
If it were me, I wouldn't be putting this thing back together until I knew the answer to that question. In my perspective I have satisfied reasonable doubt that is will leak again from anything other than a head gasket.
[Re: dvw]
#1954029
11/19/15 12:11 AM
11/19/15 12:11 AM
Clanton
northern,Ohio,USA
How would the rings or hone not touch every area on a round and straight bore? Are you saying the rusted area was hollow (concave)? Doug That is what was causing a ton of crank case pressure the blowby in that area.I was getting a lot of oil from the valley tray every run.
[Re: Clanton]
#1954044
11/19/15 12:23 AM
11/19/15 12:23 AM
Clanton
northern,Ohio,USA
This was the 3rd or 4th bore on the new block and only .001 to clean it up.
[Re: Clanton]
#2049277
04/07/16 10:33 PM
04/07/16 10:33 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I got the block re honed after finding this and had to be sure. Hows the hone job look now? That prior hone looks terrible, as does the rust spot. Nice pressure test set up though.
