Re: I had to be sure [Re: Clanton] #1953745
11/18/15 03:45 PM
11/18/15 03:45 PM
an8sec70cuda Offline
I hope that was effective. That should have heated the outside of the block plenty, not sure about the cylinder wall.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: I had to be sure [Re: an8sec70cuda] #1953751
11/18/15 03:54 PM
11/18/15 03:54 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The water in the block did the heat transfer very well.
Re: I had to be sure [Re: Clanton] #1953753
11/18/15 03:56 PM
11/18/15 03:56 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
If it's not a crack... What caused the big rust spot?
If it were me, I wouldn't be putting this thing back together until I knew the answer to that question.
Re: I had to be sure [Re: Clanton] #1953755
11/18/15 03:57 PM
11/18/15 03:57 PM
Good. up I didn't know you had the block filled w/ water.
CHIP
Re: I had to be sure [Re: dizuster] #1953761
11/18/15 04:16 PM
11/18/15 04:16 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
In my perspective I have satisfied reasonable doubt that is will leak again from anything other than a head gasket.
Re: I had to be sure [Re: Clanton] #1953968
11/18/15 10:34 PM
11/18/15 10:34 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Look... It's your motor...so you obviously can do what you want. So just know everyone is just trying to help.
But even if it leaked from the head, how did the water defy gravity and pool up and rust on the side of the bore?
Re: I had to be sure [Re: Clanton] #1953996
11/18/15 11:32 PM
11/18/15 11:32 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I appreciate the help don't get me wrong.You pose a good question but we may never find out also.I may have missed that spot looking after the last hone someone did and the rings just never got it and it rusted.
Re: I had to be sure [Re: Clanton] #1954021
11/19/15 12:02 AM
11/19/15 12:02 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How would the rings or hone not touch every area on a round and straight bore? Are you saying the rusted area was hollow (concave)?
Doug
Re: I had to be sure [Re: Clanton] #1954024
11/19/15 12:06 AM
11/19/15 12:06 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Yes!
Re: I had to be sure [Re: dvw] #1954029
11/19/15 12:11 AM
11/19/15 12:11 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Doug
That is what was causing a ton of crank case pressure the blowby in that area.I was getting a lot of oil from the valley tray every run.
Re: I had to be sure [Re: Clanton] #1954035
11/19/15 12:16 AM
11/19/15 12:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How on earth do you hone a new block into a hollow? No way. It was straight when it was honed if the stones touched. I'm assuming this was a new Koleno block honed with a real hone, not ball hone. If it's hollow the bore moved, a lot. Why? How far over did it have to go to clean up? .010", .020", .030"?
Doug
Re: I had to be sure [Re: Clanton] #1954044
11/19/15 12:23 AM
11/19/15 12:23 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
This was the 3rd or 4th bore on the new block and only .001 to clean it up.
Re: I had to be sure [Re: Clanton] #2049264
04/07/16 10:20 PM
04/07/16 10:20 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Time to file fit new rings in the fresh bore.Speed Pro R-19103 35 Hellfire rings.I have a bench top hand ring filer and a fine file.[I will gap them .030 to .032]
Re: I had to be sure [Re: Clanton] #2049277
04/07/16 10:33 PM
04/07/16 10:33 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I got the block re honed after finding this and had to be sure.
Hows the hone job look now? That prior hone looks terrible, as does the rust spot.
Nice pressure test set up though.
Re: I had to be sure [Re: Clanton] #2049283
04/07/16 10:36 PM
04/07/16 10:36 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The pattern is good on the new hone and I checked it with a dial bore gauge.
