Re: 78 440 Stock Plug Wire Routing
[Re: Wailin D]
#1953851
11/18/15 07:29 PM
11/18/15 07:29 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I bought a new W200 with a 440 in 1977 and it did not stay stock very long. And I have never had a vehicle of any make that has. Good luck finding a picture of what you need.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Wailin D]
#1954244
11/19/15 12:41 PM
11/19/15 12:41 PM
Posts: 15,487 Florida
scratchnfotraction
depends on the manifolds you have.
some trucks had 2 center dump and some had a driver side center dump with a pass side rear dump "log manifold".
I put my 78 truck 440 in a 88 d100 and swapped it over to 2 center dump manifolds. all 90* plug boots.
I then went to hedman 79250 headers and run the same plug wire routing.
I have 4 wires down the pass side VC with 2 dropping down the back for the #6 & #8 2 down the back for #5 & #7 ( they would drop under the manifold/tuck behind tubes)
2 wires drop down pass side front for #2 & #4 with 2 droping down driver front for #1 & #3
I run a set of firecore wires with heat sleeves at the plugs.
nice/clean looking as far as plug wire routing.
**the pass side log manifold will have #8 90* boot/drop down from back, #6 will drape out over manifold using a straight boot. #2 & #4 drop down from front and use 90* boots.
driver side will have all 90* boots #5 & #7 run down pass side VC dropping down in back crossing over to driver side.
#1 & #3 drop down in front.
after market sets will have deferent boot angles to contend with so it is best to have a good look at them before buying a set.
I will see about posting a pic tonight if that helps.
[Re: Wailin D]
#1956368
11/23/15 10:55 AM
11/23/15 10:55 AM
scratchnfotraction
no problem. I will take some today and see if I can get them posted.
[Re: scratchnfotraction]
#1956401
11/23/15 12:01 PM
11/23/15 12:01 PM
scratchnfotraction
with headers
the heat socks make it look tight, but the 90* boots and wire tucks behind the tubes with 1/2" + clearance. I used socks just in case. firecore wires = 165$ with socks (31 feet of wire)
[Re: Polarapete]
#1957053
11/24/15 01:39 PM
11/24/15 01:39 PM
scratchnfotraction
Now that is not stock cause it should have a Thermoquad for a carburetor...But I like it better me too! it works. here it is stock with manifolds and a THERMOBOG
