440 Manual Trans Swap, 1974 W200 Powerwagon Parts Req'd?
#1952538
11/16/15 09:08 PM
11/16/15 09:08 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Considering a Future Engine swap from a LA 360 w/ NP435 Manual Transmission to a 440 USING THE SAME NP435 Manual Transmission, in a 1974 W200 Powerwagon.
What extra parts are required? Along with a suitable 440, internal/external balance issues aside, Here is a Required Parts List as best I understand, but is this Complete/Correct?
1) BB Bellhousing and bottom cover 2) BB 143 Tooth Flywheel 3) BB 11-Inch Clutch 4) Rear Sump Oil Pan w/ Pickup 5) Center Dump Exhaust Manifolds 6) Small Diameter Pwr Brake Booster 7) Drill Crankshaft for Pilot Bushing (if cast or non-manual Trans crank) 8) Radiator with inlet/outlet correct for BB 9) Motor Mounts 10) Transmission Input Shaft? 1 1/8 Or 1 3/16 inch? 18-Spline, is that correct?
So, Is this List Correct/Complete?
