clutch fork installation #1948599
11/10/15 05:22 AM
11/10/15 05:22 AM
California
BigDaddy440 Offline OP
California
New question!
Is this clutch fork riding on this T.O. bearing correctly, or should it fit further in so that the fork arms hug the bearing a bit more?
If I unbolted the pivot tab, and turned it around I believe the fork would move closer to the bearing.
I just want to make sure I'm installing it correctly. Thanks.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: clutch fork installation [Re: BigDaddy440] #1948604
11/10/15 06:45 AM
11/10/15 06:45 AM
NJ
rth Offline
rth  Offline
NJ
The fork ends should be centered on the bearing. Also the clips are on backwards. The fork should be between the round part of clip and bearing. Clips should secure bearing to fork. The clips might be what is causing misalignment.
Re: clutch fork installation [Re: rth] #1948616
11/10/15 09:44 AM
11/10/15 09:44 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
iagree
[image][/image]
Re: clutch fork installation [Re: BigDaddy440] #1948687
11/10/15 12:57 PM
11/10/15 12:57 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree its wrong.The clips as said go into the fork.Turn it around and clip them into the fork.Rocky
Chrysler Firepower
Re: clutch fork installation [Re: therocks] #1948781
11/10/15 03:27 PM
11/10/15 03:27 PM
dogdays Offline
dogdays  Offline
Does anyone have a source for just the clips? Or does one have to buy a new fork to get them?
R.
Re: clutch fork installation [Re: dogdays] #1948803
11/10/15 03:56 PM
11/10/15 03:56 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
The clips come with the throw out bearing not the fork.
Re: clutch fork installation [Re: BigDaddy440] #1948808
11/10/15 04:05 PM
11/10/15 04:05 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
All you need to do is pull the fork out, rotate the throw out bearing 180 degrees, and slide the fork back in. The clips on the throw out bearing should hold to fork to it.
The fingers should center on the throw out bearing, I'm guessing your fork just needs to slide into the pivot bracket further and will work out once you have the clips set up right. If not you may have the wrong bracket. They are specific to the bellhousing that you're using.
Re: clutch fork installation [Re: GTX MATT] #1948967
11/10/15 07:39 PM
11/10/15 07:39 PM
California
California
Ok before I reinstall the fork, do I have the pivot bracket mounted in the correct direction? I'm not sure if the fingers will reach the center of the ears of the bearing.
I do see how the clips work now, thank you.
So is the pivot bracket correctly mounted?
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: clutch fork installation [Re: BigDaddy440] #1948974
11/10/15 07:51 PM
11/10/15 07:51 PM
PNW
Danan Offline
Danan  Offline
PNW
Yes. Now install the fork.
Re: clutch fork installation [Re: BigDaddy440] #1948991
11/10/15 08:39 PM
11/10/15 08:39 PM
California
California
Done. Thank you.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
