Re: 4 speed install frustrations
[Re: BigDaddy440]
#1947710
11/08/15 09:06 PM
11/08/15 09:06 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
The crank was almost certainly from an automatic car, but the cavity looked deep enough for the input shaft nose.
DING,DING,DING, all of the OEM 1962 to 1974 RB, 413, 426 and 440 automatic crankshafts I've dealt with are not machine the correct depth or the correct I.D. for the stock length input shafts for the OEM NP 833 trans. and the stock Mopar pilot bushings. NAPA use to make a adapter pilot bushing that could be installed into the automatic cranks but that doesn't solve the depth problem Slide the tranny out and measure through the clutch disc with a thin tape measure to see how far it is into the bottom of the cranksahft pilot hole to the mounting surface of the bellhousing and then measure the length of your input shaft to the face of the tranny face I do know of several other Mopar racers that had thier input shfts shorten so they could run the automatic cranks with the NAPA pilot bushings
[Re: Mebsuta]
#1947923
11/09/15 04:37 AM
11/09/15 04:37 AM
Cab_Burge
No, that is the later pilot bearing Mopar switch to sometime in the 1980 or 1990 I haven't used one of them yet as I still have several of the of OEM types and several of the NAPA adapter bushings in stock.
[Re: Cab_Burge]
#1948139
11/09/15 04:31 PM
11/09/15 04:31 PM
Posts: 25,813 Rio Linda, CA
John_Kunkel
Rio Linda, CA
all of the OEM 1962 to 1974 RB, 413, 426 and 440 automatic crankshafts I've dealt with are not machine the correct depth or the correct I.D. for the stock length input shafts for the OEM NP 833 trans.n the automatic cranks with the NAPA pilot bushings I'd have to disagree with the "all" in that statement. The majority of forged automatic cranks were pilot drilled 13/16" which is sufficient to clear the 3/4" pilot on the 833 and are plenty deep (usually over 1 1/2") but only standard shift cranks were reamed to the final size of 15/16" to accept the bushing.
[Re: BigDaddy440]
#1948235
11/09/15 07:47 PM
11/09/15 07:47 PM
Posts: 5,162 CT
GTX MATT
CT
My '68 C body 440 came from a 727 car and the crank was drilled deep enough, just not reamed out. I just ran the late model bearing.
[Re: GTX MATT]
#1948250
11/09/15 08:10 PM
11/09/15 08:10 PM
Posts: 4,285 Ohio
64dodge572
Ohio
We do not recommend using the NAPA undersize pilot bushing, as the auto cranks were drilled (not bored) and the undersize bushing will not be centered properly in the crankshaft. The correct way to use an auto crank is to set it up off the side of your mill, tram the flywheel register to make sure you are centered properly, and use a boring tool to open up for the standard .940 bushing----or just use the roller bearing.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: Paul_B]
#1948280
11/09/15 08:52 PM
11/09/15 08:52 PM
Posts: 72 Texas US
hemirag
Texas US
Hook up the clutch linkage, have someone push the pedal to the floor and slide it the rest of the way in. Most clutch alignment tools are cheapo plastic ones that aren't that good. I wrestled with my 4 speed install for days and found that it only got it close with the silly plastic tool. I had someone push the clutch and it went in the inch or so I needed. This worked for me also
[Re: hemirag]
#1948581
11/10/15 04:11 AM
11/10/15 04:11 AM
Posts: 707 California
BigDaddy440
California
RESOLVED:
In the past, I've been able to get other manual trannys to mate together with the bell housing a bit easier than this one, but it's now fully seated and I feel a lot better.
In the end it was my mistake (shocker). I used slightly longer bolts to pull the to units together, as the gap between the Trans and housing was to big to use the stock length bolts for this purpose....so the longer bolts were simply bottoming out in the bell housing making it feel as though the input shaft was not engaging properly or worse too long for the crank.
To resolve the issue, I used washers on the longer bolts so they wouldn't bottom out and they pulled the two units together enough that I could trade them out for the stock length bolts.
Thanks to all replys and suggestions. I either have a 4speed crank or some auto cranks do have enough cavity built into them for the input shaft.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#1948661
11/10/15 11:59 AM
11/10/15 11:59 AM
Posts: 75,019 U.S.S.A.
JohnRR
U.S.S.A.
RESOLVED:
Thanks to all replys and suggestions. I either have a 4speed crank or some auto cranks do have enough cavity built into them for the input shaft. It's a bad idea to use bolts to pull the trans into place, you are lucky you didn't break something. The way I do it is to take two 3.5/4" long shouldered 7/16 bolts, cut the heads off and slot them so I can turn with a screwdriver if needed. I screw them in the top two holes as guide pins and slide the trans in on them. if it won't seat all the way I just use my long pry bar to push on the clutch fork and the trans slides right in the rest of the way. Put in the bottom 2 bolts and then replace the guide pins on the top.
[Re: JohnRR]
#1948746
11/10/15 02:46 PM
11/10/15 02:46 PM
BigDaddy440
California
John, I'll have to try your method in the future. I was trying to think of a way to use the fork with out the clutch pedal being set up to help with the ease of installation. I think I'll be ok, as the trans moved forward smoothly and didn't fight me at all. -Dan
[Re: BigDaddy440]
#1948872
11/10/15 06:00 PM
11/10/15 06:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I use studs on the upper two mounting holes instead of bolts. I bolt the bell to the engine and the studs guide the trans onto the bell, if things don't align enough to let it slip in you simply use the clutch pedal to release things. I then use bolts in the bottom two holes and a nut and washer on the studs.
