Re: 4 speed install frustrations [Re: BigDaddy440] #1947710
11/08/15 09:06 PM
11/08/15 09:06 PM
Originally Posted By BigDaddy440
The crank was almost certainly from an automatic car, but the cavity looked deep enough for the input shaft nose.
DING,DING,DING, all of the OEM 1962 to 1974 RB, 413, 426 and 440 automatic crankshafts I've dealt with are not machine the correct depth or the correct I.D. for the stock length input shafts for the OEM NP 833 trans. and the stock Mopar pilot bushings. NAPA use to make a adapter pilot bushing that could be installed into the automatic cranks but that doesn't solve the depth problem shruggy Slide the tranny out and measure through the clutch disc with a thin tape measure to see how far it is into the bottom of the cranksahft pilot hole to the mounting surface of the bellhousing and then measure the length of your input shaft to the face of the tranny face scope thumbs I do know of several other Mopar racers that had thier input shfts shorten so they could run the automatic cranks with the NAPA pilot bushings shruggy
Re: 4 speed install frustrations [Re: Cab_Burge] #1947892
11/09/15 02:35 AM
11/09/15 02:35 AM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Is this it, from Breweer's?
http://www.brewersperformance.com/proddetail.asp?prod=PB5300
68 Roadrunner. 383 4-spd. Beat up.
Re: 4 speed install frustrations [Re: Mebsuta] #1947923
11/09/15 04:37 AM
11/09/15 04:37 AM
No, that is the later pilot bearing Mopar switch to sometime in the 1980 or 1990 confusedI haven't used one of them yet as I still have several of the of OEM types and several of the NAPA adapter bushings in stock.
Re: 4 speed install frustrations [Re: Cab_Burge] #1948139
11/09/15 04:31 PM
11/09/15 04:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
all of the OEM 1962 to 1974 RB, 413, 426 and 440 automatic crankshafts I've dealt with are not machine the correct depth or the correct I.D. for the stock length input shafts for the OEM NP 833 trans.n the automatic cranks with the NAPA pilot bushings
I'd have to disagree with the "all" in that statement. The majority of forged automatic cranks were pilot drilled 13/16" which is sufficient to clear the 3/4" pilot on the 833 and are plenty deep (usually over 1 1/2") but only standard shift cranks were reamed to the final size of 15/16" to accept the bushing.
Re: 4 speed install frustrations [Re: Cab_Burge] #1948182
11/09/15 06:10 PM
11/09/15 06:10 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
fwiw, & iirc.
My 4.15 Eagle crank was not finished machined for the tip of the input shaft but was machined for the pilot bushing. Motor was assembled, so measured and cut 5/8" (iirc) off the tip of a brand new 18 spline input shaft and still had extra shaft beyond the bushing even with a smaller bevel re-applied. Like in the other thread except now 2300 miles ago. ymmv =)
Re: 4 speed install frustrations [Re: BigDaddy440] #1948235
11/09/15 07:47 PM
11/09/15 07:47 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
My '68 C body 440 came from a 727 car and the crank was drilled deep enough, just not reamed out. I just ran the late model bearing.
Re: 4 speed install frustrations [Re: GTX MATT] #1948250
11/09/15 08:10 PM
11/09/15 08:10 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
We do not recommend using the NAPA undersize pilot bushing, as the auto cranks were drilled (not bored) and the undersize bushing will not be centered properly in the crankshaft. The correct way to use an auto crank is to set it up off the side of your mill, tram the flywheel register to make sure you are centered properly, and use a boring tool to open up for the standard .940 bushing----or just use the roller bearing.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: 4 speed install frustrations [Re: Paul_B] #1948280
11/09/15 08:52 PM
11/09/15 08:52 PM
Texas US
hemirag Offline
hemirag  Offline
Texas US
Originally Posted By Paul_B
Originally Posted By Supercuda
Hook up the clutch linkage, have someone push the pedal to the floor and slide it the rest of the way in. Most clutch alignment tools are cheapo plastic ones that aren't that good.
iagree
I wrestled with my 4 speed install for days and found that it only got it close with the silly plastic tool. I had someone push the clutch and it went in the inch or so I needed.
This worked for me also
Re: 4 speed install frustrations [Re: hemirag] #1948581
11/10/15 04:11 AM
11/10/15 04:11 AM
California
BigDaddy440 Offline OP
California
RESOLVED:
In the past, I've been able to get other manual trannys
to mate together with the bell housing a bit easier than
this one, but it's now fully seated and I feel a lot better.
In the end it was my mistake (shocker). I used slightly
longer bolts to pull the to units together, as the gap between
the Trans and housing was to big to use the stock length bolts
for this purpose....so the longer bolts were simply bottoming
out in the bell housing making it feel as though the input
shaft was not engaging properly or worse too long for the
crank.
To resolve the issue, I used washers on the longer bolts so they wouldn't bottom out and they pulled the two units together enough that I could trade them out for the stock length bolts.
Thanks to all replys and suggestions. I either have a 4speed crank or some auto cranks do have enough cavity built into them for the input shaft.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 4 speed install frustrations [Re: BigDaddy440] #1948617
11/10/15 09:46 AM
11/10/15 09:46 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Good deal. Hope all goes well from here.
[image][/image]
Re: 4 speed install frustrations [Re: BigDaddy440] #1948661
11/10/15 11:59 AM
11/10/15 11:59 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
RESOLVED:
crank.
It's a bad idea to use bolts to pull the trans into place, you are lucky you didn't break something.
The way I do it is to take two 3.5/4" long shouldered 7/16 bolts, cut the heads off and slot them so I can turn with a screwdriver if needed. I screw them in the top two holes as guide pins and slide the trans in on them. if it won't seat all the way I just use my long pry bar to push on the clutch fork and the trans slides right in the rest of the way. Put in the bottom 2 bolts and then replace the guide pins on the top.
Mainstream Media is the new Pravda
Re: 4 speed install frustrations [Re: JohnRR] #1948746
11/10/15 02:46 PM
11/10/15 02:46 PM
California
California
John,
I'll have to try your method in the future. I was trying to think of a way to use the fork with out the clutch pedal being set up to help with the ease of installation.
I think I'll be ok, as the trans moved forward smoothly and didn't fight me at all.
-Dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 4 speed install frustrations [Re: BigDaddy440] #1948772
11/10/15 03:21 PM
11/10/15 03:21 PM
dogdays Offline
dogdays  Offline
Then you should be OK.
On my latest reassembly I found that if I left the pressure plate bolts loose enough to just hold the clutch disk in place, I could wiggle the transmission around enough to get the pilot started. Then after installing the transmission I torqued the pressure plate bolts.
R.
Re: 4 speed install frustrations [Re: BigDaddy440] #1948872
11/10/15 06:00 PM
11/10/15 06:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I use studs on the upper two mounting holes instead of bolts. I bolt the bell to the engine and the studs guide the trans onto the bell, if things don't align enough to let it slip in you simply use the clutch pedal to release things. I then use bolts in the bottom two holes and a nut and washer on the studs.
Don't be the exception.
