Better 60 foot times? #1946791
11/07/15 05:04 AM
11/07/15 05:04 AM
Tulsa, Oklahoma
Wagonmaster Offline OP
Tulsa, Oklahoma
I'm driving a buddy's car 1/4 mile at a time. He is not able to, but gets a kick out of still seeing the car go fast.
So, my reaction times average in the .3 - .4 range [best is way quicker, won't talk about the worst], but the 60' times are around 1.9 - 2.0 range. Am I worrying too much about the techie side of drag racing? BTW, I am ETing 12.50s in a 3,700 lb car with a 4-gear and 4.11 gears. M/T drag radials, not much spin.
Thoughts and input, please.
Re: Better 60 foot times? [Re: Wagonmaster] #1946845
11/07/15 11:58 AM
11/07/15 11:58 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
If it's not bogging down, and doesn't have excessive spin, it sounds like your launching dead on. You can probably play with launch rpm, tire pressure and chart results. Pinion snubber, Caltrac's or the like will help. What engine and gear box?
[image][/image]
Re: Better 60 foot times? [Re: sgcuda] #1947022
11/07/15 05:04 PM
11/07/15 05:04 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
I guess my question is will a better 60 foot time really make that much difference? That is my primary curiosity. Back in the day, I don't seem to remember even being concerned about anything but the ET.
I feel the car is doing about as well as it can. My launch technique is a bit erratic, so I can't blame the car for that. The best runs have been on about a 3,750 RPM clutch release, following a good tire heat.
It bogs a bit if I leave with a lower RPM and I have hit the limiter, with spin with a 4K launch. Still dialing it in. I guess I'll have to wait until spring for much more, as this coming week it goes in the shop for a set of fresh PRS CNC heads and a .600/.264 roller cam.
Re: Better 60 foot times? [Re: Wagonmaster] #1947108
11/07/15 08:14 PM
11/07/15 08:14 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
You should be able to drop at least 2 tenths off of the 60 foot. That will drop the ET at least three or four tenths.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Better 60 foot times? [Re: Wagonmaster] #1947117
11/07/15 08:31 PM
11/07/15 08:31 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Driver mod, or put a good converter and 3 speed in it.
Re: Better 60 foot times? [Re: 1980volare] #1947157
11/07/15 09:17 PM
11/07/15 09:17 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
A lot of times a race is won at the 60 ft mark as It does make a huge difference in E.T. As mentioned before a .2 reduction in
E.T. can mean .4 on the long end.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Better 60 foot times? [Re: Wagonmaster] #1947602
11/08/15 05:05 PM
11/08/15 05:05 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
What's your mph?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Better 60 foot times? [Re: Wagonmaster] #1947607
11/08/15 05:23 PM
11/08/15 05:23 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Slicks (bias ply) may work better for you than drag radials with a stick car.
I too am curious about the MPH.
Re: Better 60 foot times? [Re: dustergirl340] #1947814
11/09/15 12:06 AM
11/09/15 12:06 AM
Tulsa, Oklahoma
Tulsa, Oklahoma
Reaction time: .573
60 foot: 2.017
1/4 12.511
MPH 113.12
I don't think it's too terrible for an old man in a used car...
I just don't remember the emphasis back in the day [60s and 70s].
Re: Better 60 foot times? [Re: Wagonmaster] #1947820
11/09/15 12:13 AM
11/09/15 12:13 AM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Sixty foot matters a lot. My husband's Challenger (pictured in avatar) runs 11.70's at the same 113 MPH. Sixty foot 1.60.
Re: Better 60 foot times? [Re: dustergirl340] #1947918
11/09/15 04:23 AM
11/09/15 04:23 AM
I ain't a drag racer at all but just repeating what my mentor told me decades ago (sounds simple but I am bored/cant sleep!) regarding this which was that 60 ft times are chassis related and ET's are a function of horsepower. I'd look at the chassis/driver reaction
Re: Better 60 foot times? [Re: RapidRobert] #1947940
11/09/15 06:08 AM
11/09/15 06:08 AM
Tulsa, Oklahoma
Tulsa, Oklahoma
"I'd look at the chassis/driver reaction."
Both are seasoned.
I am 60, the car is 37.
Re: Better 60 foot times? [Re: Wagonmaster] #1948086
11/09/15 03:10 PM
11/09/15 03:10 PM
Locomotion Offline
Locomotion  Offline
Your RT's: Gett a practice tree. It can help you develop a reflex rythem even if you go through different motions. I footbrake but practice with a button. It translates to more consistent reactions at the track. But go for consistency rather than actual reaction time on the practice tree. (Unless you have an adjustable "rollout" and can get it close to what the car is doing.)
Car RT's: That's not easy. You may have to use shorter tires and other tricks to stiffen the suspension and frame.
60' time: I don't know enough about sticks to offer a lot of advice. But I know it's not easy. If you are not spinning or just a little, it can be "bogging" or just "flat". Don't know the rest of your combo, but I know of old 273 wagons with auto transmissions needing 5.13 to 5.57 gears to get their weight moving with a little engine. If you improve your 60'times with that weight, you'll have to watch for weak links in your drivetrain!
Re: Better 60 foot times? [Re: Wagonmaster] #1948169
11/09/15 05:53 PM
11/09/15 05:53 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Both are seasoned.
"seasoned" driver and car makes little difference. That sixty foot is slow for a car with that mph. It seems to have decent power, but is definitely NOT putting it down early. Pick it up two tenths in 60ft and the car will likely be nearly a half second quicker at the same mph
Re: Better 60 foot times? [Re: RapidRobert] #1948170
11/09/15 05:56 PM
11/09/15 05:56 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Sixty foots AND ET is a function of setup and chassis. MPH is a function of HP
Re: Better 60 foot times? [Re: Monte_Smith] #1948184
11/09/15 06:23 PM
11/09/15 06:23 PM
Washington
madscientist Offline
Washington
Gald you caught that Monte.
MPH is HP and ET is chassis. Then you have to figure out if the MPH is up and the ET is slow, or is the hook good and the HP down.
I.E. 12.50 @ 155 MPH would suggest the car didn't hook.
12.50 @ 85 MPH would suggest the car hooked but made no HP.
OP...what clutch are you using???
Re: Better 60 foot times? [Re: Wagonmaster] #1948194
11/09/15 06:34 PM
11/09/15 06:34 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
A bias ply tire will work better in this application than the drag radial.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Better 60 foot times? [Re: Monte_Smith] #1948389
11/09/15 10:35 PM
11/09/15 10:35 PM
Now that you corrected me on this I am remembering that it WAS MPH not ET that is a function of HP that my mentor had stated (it was 32 yrs ago!). thank you for the correction.
Re: Better 60 foot times? [Re: Wagonmaster] #1948584
11/10/15 04:25 AM
11/10/15 04:25 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
As said above at nausium..... 113 mph says you're making enough power to go into the 11's. Work on the launch and all available chassis modifications to get that thing to transfer weight, then keep hitting the clutch with more RPM, until the tires spin.
