prepping a block for paint #1945091
11/04/15 05:21 PM
11/04/15 05:21 PM
California
mickm Offline OP
mickm  Offline OP
California
so i thought i cleaned my block well, serious scrubbing with hot soapy water and a good rinse, but it seems there is still a film of oil on it in some places.
what is the best way to really clean it off to prep it for paint? can i just wipe it down well with a rag and lacquer thinner?
oh, and it's already a long block and mostly taped off. i figured this out as i realized the tape was not sticking well at all to the block.
Re: prepping a block for paint [Re: mickm] #1945105
11/04/15 05:56 PM
11/04/15 05:56 PM
dogdays Offline
dogdays  Offline
1,1,1 Trichloroethane would probably do it. That is what used to be in brake cleaners. If you are still able to get the non-flammable kind I'd try that first. You have to saturate the surface so the oil dissolves in the cleaner and then evaporates.
My friend uses lacquer thinner for this.
R.
Re: prepping a block for paint [Re: mickm] #1945154
11/04/15 06:41 PM
11/04/15 06:41 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Trichlor is nasty stuff. Carcinogen and ozone depleting. I use brake clean on rag. Then blow off lint that the rough surface catches. Then wipe again with wax and grease remover. Blow off yet again. I also use an industrial primer. I got a couple of quarts from a supplier. It was red oxide and I brushed it on. I think it was a Rustoleum product. Seemed to work great. Did this on last two engines I built. The 440 was done 10 years ago. Although the engine is now disassembled, it still looks pretty good. My hemi was painted last year so no run time on it yet.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: prepping a block for paint [Re: RoadRunner] #1945164
11/04/15 06:53 PM
11/04/15 06:53 PM
I would get a gallon of wax and grease remover & with a clean paint brush and scrub brush go over it vigorously repeatedly with enough of it to where it is dripping a big mess under the eng. then finish up with several cans of brake kleen, drowning it & it'll get into the pores/nooks and crannies. I would not use any rags. They were referring to painting a flat surface but the paint guys at Sears once told me that you use solvent (of an appropriate type of course) to raise the oils/debris then you must wipe it off when wet otherwise if it dries the oil just goes back down to the surface. I dont think the oil will evap no matter how much it is diluted but instead it must be flushed off of the eng.
Re: prepping a block for paint [Re: RapidRobert] #1945170
11/04/15 06:59 PM
11/04/15 06:59 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Yes...
Areas I didn't like, I hit with RustMort...
'Engine Primer', followed by rattle-can Mopar Perf. Hemi Orange...
Doing well after 20 years...
(Of course, if I could go back, I'd a had it burned, and tumbled...
The end result is a nice canvas...)
Re: prepping a block for paint [Re: RSNOMO] #1945179
11/04/15 07:07 PM
11/04/15 07:07 PM
"street hemi orange" or "race hemi orange" ?. that street hemi orange looked like 318 red with God know what mixed in, terrible. the race hemi orange was somewhat close & someone mentioned that there was a Krylon or a brand like that (cant think of the name) that was very very close to the OE BB orange. EDIT Rustoleum maybe
Re: prepping a block for paint [Re: RapidRobert] #1945186
11/04/15 07:16 PM
11/04/15 07:16 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'Street Hemi'...
Back when I sprayed this engine('93), the color was real close...
No complaints...
A friend talked-up Plasti-Kote in the past...
Now TODAY, I'd look at other options...
Paint's changed a lot...
Re: prepping a block for paint [Re: mickm] #1945305
11/04/15 10:51 PM
11/04/15 10:51 PM
S.E. WI
RichL1967 Offline
RichL1967  Offline
S.E. WI
I've used Eastwood's "Chassis Clean" on two engine blocks with great results. Couldn't be happier with the stuff. When done, I had absolutely no residue and no issue with primer or paint lifting. Its cheap and in an aerosol can so you can spray blast it. Spray, scrub with toothbrush, repeat. Then wipe down with a clean rag. I love this stuff. I use it to clean all kinds of things. It will even take paint and grease off plastic without hurting the plastic if used carefully.
Common sense and caution are factors which cannot be built into any product. These must be supplied by the operator.
Re: prepping a block for paint [Re: mickm] #1945326
11/04/15 11:10 PM
11/04/15 11:10 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
At the point you have the block, I would fill a paint gun with lacquer thinner. spray it down a couple of times and paint it....
Re: prepping a block for paint [Re: minivan] #1945360
11/04/15 11:49 PM
11/04/15 11:49 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Block was baked and shot blasted.
Then the minor oil that ran down the side during assembly was cleaned off with brake parts cleaner and then wax and grease remover.
Plasti-Kote #226 Chrysler orange covers well and holds up way better than anything else I've tried.
Re: prepping a block for paint [Re: mickm] #1945374
11/05/15 12:10 AM
11/05/15 12:10 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Once you've gotten the majority of the grime off a good final rinse with Acetone and a big stack of clean white lint free rags works great, follow up with a wash down with metal prep (the type that leaves a phosphate coating like Eastwood's "Ospho") rinse with water (I use dripping wet rags) until the stickyness of the Ospho is gone, then let it air dry. A nasty looking white film will be apparent when it dries, this is the phosphate that protects the metal from rusting short term. Once dry shoot paint directly over it, works great!
Re: prepping a block for paint [Re: mickm] #1945398
11/05/15 12:48 AM
11/05/15 12:48 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Well, you're only at the beginning of the block prep...Depending on what I see IN the cooling passages I treat it to a muratic acid cleanout...After I'm happy with the de-rust/de-scaling...I use Eastwood's oxysolv or Ospho as Scott has suggested...That makes for a nice,clean block the paint will easily adhere to...
Re: prepping a block for paint [Re: GY3] #1945432
11/05/15 01:34 AM
11/05/15 01:34 AM
None
71rm23 Offline
71rm23  Offline
None
That is NICE!
Re: prepping a block for paint [Re: GY3] #1945434
11/05/15 01:37 AM
11/05/15 01:37 AM
Yes that's the one I was thinking of earlier that I had heard rave reviews on from several parties
Re: prepping a block for paint [Re: RapidRobert] #1945443
11/05/15 01:53 AM
11/05/15 01:53 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Another vote for wax and grease remover and brake cleaner, then Plasti-Kote Chrysler Orange engine paint.
Almost 10 years and mine still looks great.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: prepping a block for paint [Re: mickm] #1945459
11/05/15 02:37 AM
11/05/15 02:37 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I used the method I described on these two. Paint was Frank Badelsons, gun sprayed over bare iron. I have painted others the exact same way (using Franks paint) starting in the early 1990's, it works VERY well if you are thorough in the details. The high gloss shine that Plasticote and others may offer might look "pretty" but if you are attempting to be as original as possible you don't want that super high gloss look, just depends on your goals.
Re: prepping a block for paint [Re: mickm] #1945465
11/05/15 02:47 AM
11/05/15 02:47 AM
Get a couple of cans of good spray brake cleaner, I buy and use Wal Mart brand brake cleaner and carb. cleaners for my shop use thumbs Spray the block off several times really well with the brake cleaner, then use a good heat gun and dry the block, or whatever other cast iron your going to paint with the heat gun, hold the heat on the cast iron in one spot until you see the moisture come to the surface and then evaporate, work your way over all the surfaces you want to paint twice drrying them out, it will take less time to redry the block on the second go around thumbs, and then shoot the paint to it scope twocents thumbs Let us know your results, if you do it this way thumbs
Re: prepping a block for paint [Re: mickm] #1945494
11/05/15 03:41 AM
11/05/15 03:41 AM
California
mickm Offline OP
mickm  Offline OP
California
bunch of different methods here, thanks everyone. just have to pick one and go for it.
scott, i have badelson's paint as well, and plan on spraying that. once i get it cleaned up, i'll be good to go!
Re: prepping a block for paint [Re: mickm] #1945500
11/05/15 04:05 AM
11/05/15 04:05 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Back in the day I used oven cleaner, let it sit over night, came out very clean.
Re: prepping a block for paint [Re: mickm] #1945531
11/05/15 10:07 AM
11/05/15 10:07 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Oven cleaner, then Dawn blue soap.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
