Re: prepping a block for paint
[Re: mickm]
#1945154
11/04/15 06:41 PM
11/04/15 06:41 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Trichlor is nasty stuff. Carcinogen and ozone depleting. I use brake clean on rag. Then blow off lint that the rough surface catches. Then wipe again with wax and grease remover. Blow off yet again. I also use an industrial primer. I got a couple of quarts from a supplier. It was red oxide and I brushed it on. I think it was a Rustoleum product. Seemed to work great. Did this on last two engines I built. The 440 was done 10 years ago. Although the engine is now disassembled, it still looks pretty good. My hemi was painted last year so no run time on it yet.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#1945164
11/04/15 06:53 PM
11/04/15 06:53 PM
RapidRobert
I would get a gallon of wax and grease remover & with a clean paint brush and scrub brush go over it vigorously repeatedly with enough of it to where it is dripping a big mess under the eng. then finish up with several cans of brake kleen, drowning it & it'll get into the pores/nooks and crannies. I would not use any rags. They were referring to painting a flat surface but the paint guys at Sears once told me that you use solvent (of an appropriate type of course) to raise the oils/debris then you must wipe it off when wet otherwise if it dries the oil just goes back down to the surface. I dont think the oil will evap no matter how much it is diluted but instead it must be flushed off of the eng.
[Re: RapidRobert]
#1945170
11/04/15 06:59 PM
11/04/15 06:59 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Yes... Areas I didn't like, I hit with RustMort... 'Engine Primer', followed by rattle-can Mopar Perf. Hemi Orange... Doing well after 20 years... (Of course, if I could go back, I'd a had it burned, and tumbled... The end result is a nice canvas...)
[Re: RSNOMO]
#1945179
11/04/15 07:07 PM
11/04/15 07:07 PM
RapidRobert
followed by rattle-can Mopar Perf. Hemi Orange... "street hemi orange" or "race hemi orange" ?. that street hemi orange looked like 318 red with God know what mixed in, terrible. the race hemi orange was somewhat close & someone mentioned that there was a Krylon or a brand like that (cant think of the name) that was very very close to the OE BB orange. EDIT Rustoleum maybe
[Re: mickm]
#1945305
11/04/15 10:51 PM
11/04/15 10:51 PM
Posts: 101 S.E. WI
RichL1967
S.E. WI
I've used Eastwood's "Chassis Clean" on two engine blocks with great results. Couldn't be happier with the stuff. When done, I had absolutely no residue and no issue with primer or paint lifting. Its cheap and in an aerosol can so you can spray blast it. Spray, scrub with toothbrush, repeat. Then wipe down with a clean rag. I love this stuff. I use it to clean all kinds of things. It will even take paint and grease off plastic without hurting the plastic if used carefully.
Common sense and caution are factors which cannot be built into any product. These must be supplied by the operator.
[Re: GY3]
#1945432
11/05/15 01:34 AM
11/05/15 01:34 AM
Posts: 2,592 None
71rm23
None
Block was baked and shot blasted.
Then the minor oil that ran down the side during assembly was cleaned off with brake parts cleaner and then wax and grease remover.
Plasti-Kote #226 Chrysler orange covers well and holds up way better than anything else I've tried. That is NICE!
[Re: GY3]
#1945434
11/05/15 01:37 AM
11/05/15 01:37 AM
RapidRobert
Plasti-Kote #226 Chrysler orange Yes that's the one I was thinking of earlier that I had heard rave reviews on from several parties
[Re: RapidRobert]
#1945443
11/05/15 01:53 AM
11/05/15 01:53 AM
Posts: 3,386 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Plasti-Kote #226 Chrysler orange Yes that's the one I was thinking of earlier that I had heard rave reviews on from several parties Another vote for wax and grease remover and brake cleaner, then Plasti-Kote Chrysler Orange engine paint. Almost 10 years and mine still looks great.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: mickm]
#1945465
11/05/15 02:47 AM
11/05/15 02:47 AM
Posts: 43,230 Bend,OR USA
Cab_Burge
Get a couple of cans of good spray brake cleaner, I buy and use Wal Mart brand brake cleaner and carb. cleaners for my shop use Spray the block off several times really well with the brake cleaner, then use a good heat gun and dry the block, or whatever other cast iron your going to paint with the heat gun, hold the heat on the cast iron in one spot until you see the moisture come to the surface and then evaporate, work your way over all the surfaces you want to paint twice drrying them out, it will take less time to redry the block on the second go around , and then shoot the paint to it Let us know your results, if you do it this way
[Re: mickm]
#1945531
11/05/15 10:07 AM
11/05/15 10:07 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Oven cleaner, then Dawn blue soap.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
