Re: 340 restoration block
[Re: 1980volare]
#1939889
10/27/15 09:25 PM
10/27/15 09:25 PM
Posts: 7,506 Az
Crizila
Az
What are you using to fill it? Moroso engine block filler. As mentioned, an oil cooler is a good idea if you use a lot of filler. Mine is filled to the bottom of the water pump holes. Seen oil temp as high as 212, but synthetic is often good to over 250 - per Royal Purple tech people. Still, a cooler is not a bad idea if you do a lot of street driving.
Fastest 300
