E body mods
#1938965
10/26/15 03:25 PM
10/26/15 03:25 PM
Posts: 1,131 Home of the Bluegrass
MoparJunkie
Hey guys, I want to make some suspension and brake changes to my 70 challenger. It has front disc with rear drum brakes. I wanna stay with the drums on the DANA. It has front and rear sway bars(stock diameter). I have .096 torsion bars, and KYB's at all four corners. I want to upgrade rotors and calipers, and make the mods necessary for as good of a suspension as I can obtain with stock front end components. I don't wanna change upper or lower control arms...etc. So give me some combo's you'd recommend to go with for the changes I want.... So... throw them at me. TIA
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: E body mods
[Re: ahy]
#1939355
10/26/15 11:53 PM
10/26/15 11:53 PM
MoparJunkie
I have the offset bushings in already. So.... what shocks??? I'm also running 15" wheels, so I was thinking the 11.75" rotors.
Re: E body mods
[Re: ahy]
#1939452
10/27/15 03:00 AM
10/27/15 03:00 AM
Posts: 752 AZ - The "dry heat" state
71autoxr
For shocks, up to 1" bars, KYB will work OK (I run them with 1" bars) but matched Bilstiens or Koni's are considered way better and pretty much required for a good outcome with T bars over 1". I would get a specific recommendation from somebody running that setup or a vendor like Firm Feel.
Starting with .96 bars, I would consider adding the better sway bar, better brakes and handling alignment with the offset bushings to help and see how you like it. Shocks would be next and heavier T bars next after that. First off I would think that the 15" rims are going to be the weak point in the entire system. Tire size is limited, brake size is limited for upgrading the fronts, and once you start upgrading t-bars and sway bars you will wish you changed wheels/tires to take advantage of it all. Although....you can keep a trans am look with some 15" minilites and goodyear bluestreaks!! On my small block Challenger I have 1.12" t-bars with koni reds and stock front sway bar with poly mounts. No rear bar (factory installed, not connected) 16x7 wheels with 255/50/16. The car is very predictable and flat and surprises a lot of people. With the weight of a big motor up front, I would opt for the biggest torsion bar you can get, and go from there. I ran the stock single piston caliper for many years of autocrossing, and recently swapped to Wilwood calipers up front for better pad selection. The pads I have now are incredible and are a VERY noticeable improvement over the "stock" type replacement pads. If money were no object I would have done a big brake swap years ago, but the Wilwoods were free and racing is expensive. No matter what you do, it would be best to make one change at a time and see how the car responds, despite the urge to tear it all apart at once.
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
Re: E body mods
[Re: 71autoxr]
#1939494
10/27/15 09:42 AM
10/27/15 09:42 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Starting with .96 bars, I would consider adding the better sway bar, better brakes and handling alignment with the offset bushings to help and see how you like it. Shocks would be next and heavier T bars next after that. First off I would think that the 15" rims are going to be the weak point in the entire system. Tire size is limited, brake size is limited for upgrading the fronts, and once you start upgrading t-bars and sway bars you will wish you changed wheels/tires to take advantage of it all. Although....you can keep a trans am look with some 15" minilites and goodyear bluestreaks!! On my small block Challenger I have 1.12" t-bars with koni reds and stock front sway bar with poly mounts. No rear bar (factory installed, not connected) 16x7 wheels with 255/50/16. The car is very predictable and flat and surprises a lot of people. With the weight of a big motor up front, I would opt for the biggest torsion bar you can get, and go from there. I ran the stock single piston caliper for many years of autocrossing, and recently swapped to Wilwood calipers up front for better pad selection. The pads I have now are incredible and are a VERY noticeable improvement over the "stock" type replacement pads. If money were no object I would have done a big brake swap years ago, but the Wilwoods were free and racing is expensive. No matter what you do, it would be best to make one change at a time and see how the car responds, despite the urge to tear it all apart at once. This is a good plan.
Re: E body mods
[Re: MoparJunkie]
#1941417
10/30/15 12:23 AM
10/30/15 12:23 AM
MoparJunkie
I have the connectors installed. They are the floor formed boxed in ones. From front to rear unibody. Don't really wanna start modifying the original components on the front suspension. I'm gonna try the 11.75 disc upgrade kit and bigger front sway bar and she what happens.... Thanks for the input guys!
