Changing bulkhead connector-no fun at all #1937092
10/23/15 12:55 AM
10/23/15 12:55 AM
FL
HelleOnWheels Offline OP
FL
So I've read just about every single post on here about changing bulkhead, cleaning connectors, soldering techniques etc. I've learned a lot and felt very prepared. What I was not expecting was the dash harness to only reach out just under the steering column which means I am taking each connector out, cleaning it and re-installing it into the new bulkhead......all while laying on my side reaching up under the column. I need to do some yoga to get in this position!!!!
This should be interesting. Now let's just hope I put each wire back in the right slot.
Stay tuned for the likely questions that are going to be coming your way!!!!
Re: Changing bulkhead connector-no fun at all [Re: HelleOnWheels] #1937099
10/23/15 01:09 AM
10/23/15 01:09 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I would un-bolt the seat and get it out of there. Takes about 10 minutes to do.
Mo' Farts
Moderated by "tbagger".
Re: Changing bulkhead connector-no fun at all [Re: Grizzly] #1937110
10/23/15 01:39 AM
10/23/15 01:39 AM
FL
FL
I had this exact thought after finishing the first wire....seat coming out tomorrow night.....who knows....maybe I'll find some loose change or something else exciting under there
Re: Changing bulkhead connector-no fun at all [Re: HelleOnWheels] #1937125
10/23/15 02:40 AM
10/23/15 02:40 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Last one I did (quite a few years ago) I pulled the dash harness OUT of the car and did the connectors one at a time sitting on the floor...I'd NEVER do it with the harness still in the car.
Re: Changing bulkhead connector-no fun at all [Re: Jim_Lusk] #1937164
10/23/15 08:51 AM
10/23/15 08:51 AM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
I agree about pulling it out for better access. Make a tool like a small screw driver and insert it on the backside of the female connectors in the bulkhead connector.Yhere is a small tab in there that holds the female connector in the bulkhead.I have. changed several over the years.Time consuming but not that difficult.
Re: Changing bulkhead connector-no fun at all [Re: HelleOnWheels] #1937181
10/23/15 10:11 AM
10/23/15 10:11 AM
FL
FL
Yeah it doesn't seem like it is hard work just tedious. I can see how pulling the dash harness out would make changing the connector easier but I really don't want to add more work of removing and reinstalling dash harness. Once my connector is done, I have to re wire the entire engine bay with a new harness. Also changing battery cables, ground straps etc all at this same time. It's a 67 440 but I am upgrading it with the dual field alternator and 70's style regulator. Also think I shouldndonthe ammeter bypass while I have it all apart.
Re: Changing bulkhead connector-no fun at all [Re: HelleOnWheels] #1937316
10/23/15 03:07 PM
10/23/15 03:07 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
I'll have to start charging for all these clever ideas I have, let's go 50/50 on whatever turns up and for the moral support I'm providing over here too. thumbs laugh2
Mo' Farts
Re: Changing bulkhead connector-no fun at all [Re: Grizzly] #1937392
10/23/15 05:18 PM
10/23/15 05:18 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Some pics to help...LOL
Re: Changing bulkhead connector-no fun at all [Re: Jim_Lusk] #1939457
10/27/15 03:30 AM
10/27/15 03:30 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Give the man a cigar. This would be my method as well.
