How do I take the dash out of my 67 b body? #1935921
10/21/15 12:33 AM
10/21/15 12:33 AM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Thanks!
Re: How do I take the dash out of my 67 b body? [Re: Blown61] #1935947
10/21/15 01:27 AM
10/21/15 01:27 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
See the latest issue of Mopar Action - they did an article on this very topic! Lots of helpful details!
It's Swifty! Swifty, you toad sucker!
Re: How do I take the dash out of my 67 b body? [Re: Blown61] #1935955
10/21/15 01:38 AM
10/21/15 01:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The dash frame ? hammer
The bolts that hold the frame to the body are under the windshield rubber gasket ...
Re: How do I take the dash out of my 67 b body? [Re: JohnRR] #1935980
10/21/15 02:20 AM
10/21/15 02:20 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Dash? meaning the whole metal frame, or the just the dash cluster. Plymouth, Coronet, or Charger? Factory A/C or just a plain heater?
Re: How do I take the dash out of my 67 b body? [Re: NANKET] #1936107
10/21/15 12:44 PM
10/21/15 12:44 PM
I ain't a B body guy but I have to drop the st column aways so the dash has room to come forward & up and out & place a rag on the col to protect its paint during the R&R. undo the bolts that hold the column to the underside of the dash (support the column) and first loosen the 3 bolts on the floorboard toe plate so the col has room to move WO binding anything. #1 With electrical the first step is always pull a batt cable off of its post. take off the nuts for the red and black ammeter main wires and CAREFULLY pry the black round connector EVENLY off of the pins on the printed circuit board and there will be some fold over tabs that secure the looms along its route
Re: How do I take the dash out of my 67 b body? [Re: Blown61] #1936143
10/21/15 01:54 PM
10/21/15 01:54 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
disconnect battery...lower steering column,remove radio/knobs/heater control knobs...remove all screws to cluster...reach around and disconnect speedometer cable....slowly pull cluster forward and disconnect connectors/wires to volt meter.
Re: How do I take the dash out of my 67 b body? [Re: terzmo] #1936172
10/21/15 02:50 PM
10/21/15 02:50 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Need more info, what car is this, no need to touch the radio on a Plymouth to remove cluster, but yes on a dodge.
Re: How do I take the dash out of my 67 b body? [Re: terzmo] #1936247
10/21/15 05:10 PM
10/21/15 05:10 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
yes....I'm referring to a Dodge
Re: How do I take the dash out of my 67 b body? [Re: Blown61] #1936308
10/21/15 07:32 PM
10/21/15 07:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Hello , MCFLY !!! , what part are you trying to remove ??? the steel frame , the cluster ?????
fan
Re: How do I take the dash out of my 67 b body? [Re: JohnRR] #1936506
10/22/15 01:00 AM
10/22/15 01:00 AM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
The whole thing, frame, cluster, heater core etc.
Re: How do I take the dash out of my 67 b body? [Re: Blown61] #1936721
10/22/15 02:55 PM
10/22/15 02:55 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
You will have to remove the WS to get to the bolts that hold the metal dash frame to the car..
Re: How do I take the dash out of my 67 b body? [Re: minivan] #1937103
10/23/15 01:22 AM
10/23/15 01:22 AM
wisconSIN
Blown61 Offline OP
Blown61  Offline OP
wisconSIN
Thank you all!
