Re: Fuel Volume vs. Fuel Pressure
[Re: TRENDZ]
#1934913
10/19/15 01:44 PM
10/19/15 01:44 PM
Posts: 26,010 United Socialist States of Ame...
tboomer
I don't know what a fuel pump has to do with a cistern? But I did talk with a tech from Aeromotive this morning and he recommended The same pump that Jim has on his N/SS car...
[Re: dogdays]
#1934992
10/19/15 04:11 PM
10/19/15 04:11 PM
Posts: 4,457 Washington
madscientist
Washington
You just proved you're not a scientist.
R. Nice come back. What exactly did I say that is wrong? You can have PRESSURE and ZERO flow. FACT. Now prove me wrong.
[Re: 340B5]
#1934996
10/19/15 04:15 PM
10/19/15 04:15 PM
madscientist
Washington
You can have pressure and ZERO flow. That is why if I have to use a .500 fuel line I want the pressure to the regulator to be 30 pounds or more. A bigger fuel line has more fuel in it, thus more weight. So if you don't raise the line pressure you can have pressure but zero flow. Seen it a bunch of times.
That said, most of the time it shows up in 60 feet. I know what you meant and you're right. More fuel mass in the line has more inertia so it has more of a tendency to stay put during launch, hence the need for more pressure to move it forward. Exactly. But the keyboard know-it-alls need to have it spelled out for them. Guess I should have spent my time educating them for free.
[Re: tboomer]
#1935006
10/19/15 04:33 PM
10/19/15 04:33 PM
Posts: 4,212 New York
polyspheric
New York
To a hammer, everything is a nail. When has a manufacturer not said "you need a big pump"? For those of you who still think that the car is faster in direct proportion to the amount of money spent (i.e., billet = power), I'll quote David Vizard (slight editing) on fuel supply requirements, not as line size but in terms of how much must be actually received at the carb inlet. "Brake Specific Fuel Consumption (as shown in dyno tests): how many lbs. of fuel per hour per horsepower the motor needs; .5 lbs./hr is a safe minimum figure. .5 lbs/hr/hp × 500 hp = 250 lbs./hr add 50% safety margin for restrictions, inertia, bends, etc. = 375 lbs./hr gas = 6 lbs. per gallon 62.5 gallons per hour is more than sufficient for a 500 hp motor." Sooo... your BG 400 pump is JUST RIGHT for that 3200 hp motor...
Boffin Emeritus
[Re: polyspheric]
#1935028
10/19/15 05:12 PM
10/19/15 05:12 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
To a hammer, everything is a nail. When has a manufacturer not said "you need a big pump"? For those of you who still think that the car is faster in direct proportion to the amount of money spent (i.e., billet = power), I'll quote David Vizard (slight editing) on fuel supply requirements, not as line size but in terms of how much must be actually received at the carb inlet. "Brake Specific Fuel Consumption (as shown in dyno tests): how many lbs. of fuel per hour per horsepower the motor needs; .5 lbs./hr is a safe minimum figure. .5 lbs/hr/hp × 500 hp = 250 lbs./hr add 50% safety margin for restrictions, inertia, bends, etc. = 375 lbs./hr gas = 6 lbs. per gallon 62.5 gallons per hour is more than sufficient for a 500 hp motor." Sooo... your BG 400 pump is JUST RIGHT for that 3200 hp motor... a BG 400 pump doesn't pump 400 gallons per hour. Neither does a magnafuel 275 pump 275. These are all Barry Grant misleading numbers a 5/8th garden hose will only flow between 200-300 GPH with no restrictions depending on pressure
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Monte_Smith]
#1935068
10/19/15 06:16 PM
10/19/15 06:16 PM
Posts: 22,727 Bitopia
jcc
Bitopia
Since we are using golf balls, water cisterns and all kinds of other useless crap, in relation to race car fuel systems.........how about this. I don't have any type pump on my house and I have good pressure and volume in the shower.........so hmmm...........hell maybe we don't even NEED fuel pumps.........LOL!!! Obviously my cistern analogy went over your head. I did however exempt you from the golf ball analogy. And sorry you couldn't form a legit question to my comment I could respond to.
[Re: Monte_Smith]
#1935086
10/19/15 06:51 PM
10/19/15 06:51 PM
Posts: 176 Sterling Heights, MI
John_T_Brown
The fuel PUMP is only a small part of the fuel SYSTEM. The biggest baddest pump in the world won't work if the system doesn't. It all has to work together. Bigger lines, hold more volume and the column of fuel is harder to move in a G situation, so you need more pump. Smaller lines help that, but won't supply the volume. More pressure is NOT the answer. Pressure just aerates the fuel, which is NOT a good thing. Your fuel system should supply the volume of fuel you need and not need more than 5 psi at the carb to do it. If 5psi of regulated pressure at the carb, does not supply enough fuel...........you need more volume Exactly what has been said here! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
If it ain't broke fix it anyway!
[Re: justinp61]
#1935184
10/19/15 09:28 PM
10/19/15 09:28 PM
Thumperdart
State of confusion
I meant a pic of the fuel entrance where the supply line hooks up to.......
[Re: justinp61]
#1935216
10/19/15 10:03 PM
10/19/15 10:03 PM
Thumperdart
State of confusion
That`s the money shot..........see that nasty wall the fuel has to go through? The QF entries are blended and smooth.....no walls baffles etc......Thankxx man.
[Re: polyspheric]
#1935224
10/19/15 10:11 PM
10/19/15 10:11 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
To a hammer, everything is a nail. When has a manufacturer not said "you need a big pump"? For those of you who still think that the car is faster in direct proportion to the amount of money spent (i.e., billet = power), I'll quote David Vizard (slight editing) on fuel supply requirements, not as line size but in terms of how much must be actually received at the carb inlet. "Brake Specific Fuel Consumption (as shown in dyno tests): how many lbs. of fuel per hour per horsepower the motor needs; .5 lbs./hr is a safe minimum figure. .5 lbs/hr/hp × 500 hp = 250 lbs./hr add 50% safety margin for restrictions, inertia, bends, etc. = 375 lbs./hr gas = 6 lbs. per gallon 62.5 gallons per hour is more than sufficient for a 500 hp motor." Sooo... your BG 400 pump is JUST RIGHT for that 3200 hp motor... and he also says a vacuum secondary carb is perfect for a drag race car, because it acts like two carbs in one.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: jcc]
#1935368
10/20/15 01:48 AM
10/20/15 01:48 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Since we are using golf balls, water cisterns and all kinds of other useless crap, in relation to race car fuel systems.........how about this. I don't have any type pump on my house and I have good pressure and volume in the shower.........so hmmm...........hell maybe we don't even NEED fuel pumps.........LOL!!! Obviously my cistern analogy went over your head. I did however exempt you from the golf ball analogy. And sorry you couldn't form a legit question to my comment I could respond to. No, it didn't go over my head and I felt no need to ask you a question from that meaningless stuff you posted, because it is not relevant to the discussion at hand. You think it is...fine, I just don't care to talk about theory and equations, because I know what a race car needs and how to properly set up a fuel system that works right. You want to flex your engineering knowledge, fine, knock yourself out. I will opt for proven results that work As far as regarding Vizards word as the gospel of all things automotive...........I will refrain until he builds or tunes an actual car that runs fast, instead of peppering us with theory and dyno numbers
[Re: tboomer]
#1935378
10/20/15 02:15 AM
10/20/15 02:15 AM
polyspheric
New York
That happened about 50 years ago.
I love how people don't trust those "science", "physics", and "chemistry" things, instead they appreciate "real world experience". LOL!
Boffin Emeritus
[Re: polyspheric]
#1935442
10/20/15 10:05 AM
10/20/15 10:05 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I love how people don't trust those "science", "physics", and "chemistry" things, instead they appreciate "real world experience". LOL! 50 years ago "science" and "physics" said it would be impossible for a piston driven vehicle to exceed 180mph in a 1/4 mile.... I'll take real world experience.
