Page 4 of 7 1 2 3 4 5 6 7
Re: Fuel Volume vs. Fuel Pressure [Re: TRENDZ] #1934913
10/19/15 01:44 PM
10/19/15 01:44 PM
tboomer Offline OP
tboomer  Offline OP
I don't know what a fuel pump has to do with a cistern? But I did talk with a tech from Aeromotive this morning and he recommended The same pump that Jim has on his N/SS car...
Re: Fuel Volume vs. Fuel Pressure [Re: tboomer] #1934917
10/19/15 01:48 PM
10/19/15 01:48 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Ted, I'm thinking we can go to Home Depot/Lowe's and get a well water pump when on sale and have plenty of fuel volume!!!! May even be cheaper then a regular ole small fuel pump shruggy
Re: Fuel Volume vs. Fuel Pressure [Re: dogdays] #1934992
10/19/15 04:11 PM
10/19/15 04:11 PM
Washington
madscientist Offline
Washington
Originally Posted By dogdays
You just proved you're not a scientist.
R.
Nice come back.
What exactly did I say that is wrong?
You can have PRESSURE and ZERO flow.
FACT.
Now prove me wrong.
Re: Fuel Volume vs. Fuel Pressure [Re: TRENDZ] #1934993
10/19/15 04:12 PM
10/19/15 04:12 PM
USA
540DUSTER Offline
540DUSTER  Offline
USA
I think there is another law that says an object in motion tends to stay in motion UNLESS some force or g-force tends to stop it.
Re: Fuel Volume vs. Fuel Pressure [Re: 340B5] #1934996
10/19/15 04:15 PM
10/19/15 04:15 PM
Washington
Washington
Originally Posted By 340B5
Originally Posted By madscientist
You can have pressure and ZERO flow. That is why if I have to use a .500 fuel line I want the pressure to the regulator to be 30 pounds or more. A bigger fuel line has more fuel in it, thus more weight. So if you don't raise the line pressure you can have pressure but zero flow. Seen it a bunch of times.
That said, most of the time it shows up in 60 feet.
I know what you meant and you're right. More fuel mass in the line has more inertia so it has more of a tendency to stay put during launch, hence the need for more pressure to move it forward.
Exactly.
But the keyboard know-it-alls need to have it spelled out for them. Guess I should have spent my time educating them for free.
Re: Fuel Volume vs. Fuel Pressure [Re: tboomer] #1935003
10/19/15 04:25 PM
10/19/15 04:25 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Since we are using golf balls, water cisterns and all kinds of other useless crap, in relation to race car fuel systems.........how about this. I don't have any type pump on my house and I have good pressure and volume in the shower.........so hmmm...........hell maybe we don't even NEED fuel pumps.........LOL!!!
Re: Fuel Volume vs. Fuel Pressure [Re: tboomer] #1935006
10/19/15 04:33 PM
10/19/15 04:33 PM
New York
polyspheric Offline
polyspheric  Offline
New York
To a hammer, everything is a nail.
When has a manufacturer not said "you need a big pump"?
For those of you who still think that the car is faster in direct proportion to the amount of money spent (i.e., billet = power), I'll quote David Vizard (slight editing) on fuel supply requirements, not as line size but in terms of how much must be actually received at the carb inlet.
"Brake Specific Fuel Consumption (as shown in dyno tests): how many lbs. of fuel per hour per horsepower the motor needs; .5 lbs./hr is a safe minimum figure.
.5 lbs/hr/hp × 500 hp = 250 lbs./hr
add 50% safety margin for restrictions, inertia, bends, etc. = 375 lbs./hr
gas = 6 lbs. per gallon
62.5 gallons per hour is more than sufficient for a 500 hp motor."
Sooo... your BG 400 pump is JUST RIGHT for that 3200 hp motor...
Boffin Emeritus
Re: Fuel Volume vs. Fuel Pressure [Re: polyspheric] #1935028
10/19/15 05:12 PM
10/19/15 05:12 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
a BG 400 pump doesn't pump 400 gallons per hour. Neither does a magnafuel 275 pump 275. These are all Barry Grant misleading numbers
a 5/8th garden hose will only flow between 200-300 GPH with no restrictions depending on pressure
Re: Fuel Volume vs. Fuel Pressure [Re: Monte_Smith] #1935068
10/19/15 06:16 PM
10/19/15 06:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Obviously my cistern analogy went over your head. I did however exempt you from the golf ball analogy. And sorry you couldn't form a legit question to my comment I could respond to.
Re: Fuel Volume vs. Fuel Pressure [Re: Monte_Smith] #1935086
10/19/15 06:51 PM
10/19/15 06:51 PM
Sterling Heights, MI
John_T_Brown Offline
The fuel PUMP is only a small part of the fuel SYSTEM. The biggest baddest pump in the world won't work if the system doesn't. It all has to work together. Bigger lines, hold more volume and the column of fuel is harder to move in a G situation, so you need more pump. Smaller lines help that, but won't supply the volume. More pressure is NOT the answer. Pressure just aerates the fuel, which is NOT a good thing. Your fuel system should supply the volume of fuel you need and not need more than 5 psi at the carb to do it. If 5psi of regulated pressure at the carb, does not supply enough fuel...........you need more volume
Exactly what has been said here! up
If it ain't broke fix it anyway!
Re: Fuel Volume vs. Fuel Pressure [Re: Thumperdart] #1935181
10/19/15 09:25 PM
10/19/15 09:25 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By Thumperdart
Originally Posted By justinp61
I need to pull one of the bowls off my QF 750 and one off my Biggs 950HP and compare them. Thanks for the info Thumper.
Post a pic if you can of the fuel entrance for all to see....... thumbs
Sorry for the delay Dom, I've been trying to get my short block together. This photo is of the Quick Fuel Bowl, the carb is 10 or 12 years old so it may not be the latest design. BTW the bowls on my Biggs 950HP are the same.
Re: Fuel Volume vs. Fuel Pressure [Re: justinp61] #1935184
10/19/15 09:28 PM
10/19/15 09:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I meant a pic of the fuel entrance where the supply line hooks up to.......
Re: Fuel Volume vs. Fuel Pressure [Re: Thumperdart] #1935207
10/19/15 09:57 PM
10/19/15 09:57 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: Fuel Volume vs. Fuel Pressure [Re: justinp61] #1935216
10/19/15 10:03 PM
10/19/15 10:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s the money shot..........see that nasty wall the fuel has to go through? The QF entries are blended and smooth.....no walls baffles etc......Thankxx man.
Re: Fuel Volume vs. Fuel Pressure [Re: polyspheric] #1935224
10/19/15 10:11 PM
10/19/15 10:11 PM
jersey
Spaceman Spiff Offline
jersey
and he also says a vacuum secondary carb is perfect for a drag race car, because it acts like two carbs in one.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Fuel Volume vs. Fuel Pressure [Re: Spaceman Spiff] #1935257
10/19/15 10:55 PM
10/19/15 10:55 PM
Next whistling grin devilLet not the pot stop boiling grin
Re: Fuel Volume vs. Fuel Pressure [Re: jcc] #1935368
10/20/15 01:48 AM
10/20/15 01:48 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
No, it didn't go over my head and I felt no need to ask you a question from that meaningless stuff you posted, because it is not relevant to the discussion at hand. You think it is...fine, I just don't care to talk about theory and equations, because I know what a race car needs and how to properly set up a fuel system that works right. You want to flex your engineering knowledge, fine, knock yourself out. I will opt for proven results that work
As far as regarding Vizards word as the gospel of all things automotive...........I will refrain until he builds or tunes an actual car that runs fast, instead of peppering us with theory and dyno numbers
Re: Fuel Volume vs. Fuel Pressure [Re: tboomer] #1935378
10/20/15 02:15 AM
10/20/15 02:15 AM
New York
polyspheric Offline
polyspheric  Offline
New York
That happened about 50 years ago.
I love how people don't trust those "science", "physics", and "chemistry" things, instead they appreciate "real world experience". LOL!
Boffin Emeritus
Re: Fuel Volume vs. Fuel Pressure [Re: tboomer] #1935385
10/20/15 02:35 AM
10/20/15 02:35 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Exactly...........so why do I care about what he did 50 years ago. I don't run 50 year old parts and some of his ideas are VERY dated.
As far as that "experience" thing........yeah, that means a lot to me, because "better ideas" are engineered every day that fall flat on their face..........so laugh all you want
Re: Fuel Volume vs. Fuel Pressure [Re: polyspheric] #1935442
10/20/15 10:05 AM
10/20/15 10:05 AM
jersey
jersey
50 years ago "science" and "physics" said it would be impossible for a piston driven vehicle to exceed 180mph in a 1/4 mile....
I'll take real world experience.
