Re: Cost of 900 hp in a N/A small block?
[Re: pittsburghracer]
#1933887
10/17/15 07:36 PM
10/17/15 07:36 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Little inline small block beating a bbc on spray! I see two chevies and one having a nitrous back-fire. What does that have to do with the posted question. LOL I guess I'm showing one of those can't make 900 Real hp motors with a inline head...Lol
[Re: 408strokerdart]
#1933919
10/17/15 08:55 PM
10/17/15 08:55 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I'd rather have the dizzy in the front lol.
http://www.ebay.com/itm/Dodge-Mopar-R6-P8-NASCAR-Racing-Engine-356-CID-8-Cylinder-Motor/121781317811?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D34004%26meid%3D4f4f8a985a1f4b3387b40818deb6a70d%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D121786077498
Mopar to the bone!!!
#1934151
10/18/15 09:29 AM
10/18/15 09:29 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Ok so most of us agree the 900HP number can be hit. Now the question is how long will said engine last. It's not for me as I race my junk weekly all Summer long and not just on bonzi days.
[Re: 72Swinger]
#1934238
10/18/15 01:13 PM
10/18/15 01:13 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
http://www.ebay.com/itm/Dodge-Mopar-R6-P8-NASCAR-Racing-Engine-356-CID-8-Cylinder-Motor/121781317811?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D34004%26meid%3D4f4f8a985a1f4b3387b40818deb6a70d%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D121786077498 Why have a dizzy. It's 2015
[Re: WO23Coronet]
#1934348
10/18/15 04:26 PM
10/18/15 04:26 PM
Posts: 428 wappinger falls new york
Jimi_Vignogna
On my 300" engine , pistons,rods,bearings,rings,valve springs,locks retainers, timing belt,distributor belt,rebuild or replace roller lifters,check over all rocker arms,mag the crank. This engine spends most of every pass between 8800 and 10,500 rpm.
[Re: Jimi_Vignogna]
#1934366
10/18/15 05:28 PM
10/18/15 05:28 PM
Posts: 1,019 Finland
mafo
Finland
I broke a rocker this fall and I m going to replace them all before next season, they were manufactured in 1998 and must have several hundred runs ... that got me thinking about the valves, I have replaced the exhaust valves but I m not sure how old the intake valves are, there must be a limit on how long you can run them, anyone knows? I m not interested in finding out on my own valves are titanium, I believe they are Manleys
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: SpareParts]
#1934371
10/18/15 05:36 PM
10/18/15 05:36 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Jeremy at Extreme could easily do it, watch an x275 race You mean the X275 class that is a "POWER ADDER" class..........the only thing that proves is that some are better at power management than others Plus the FASTEST car ever in X275...........a twin turbo SBF, the next two, a BBC nitrous and a SBC nitrous. So how is any of that relevant to this discussion? The smallblock car is Ron Rhodes, been 4.40s on a radial with nitrous at a REALLY light weight. It's an inline wedge motor, that does NOT make 900hp on motor alone..........so what does all that tells us.........again, not a damn thing....LOL!!!!
[Re: ademon]
#1934377
10/18/15 05:51 PM
10/18/15 05:51 PM
72Swinger
Nebraska
http://www.ebay.com/itm/Dodge-Mopar-R6-P8-NASCAR-Racing-Engine-356-CID-8-Cylinder-Motor/121781317811?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D34004%26meid%3D4f4f8a985a1f4b3387b40818deb6a70d%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D121786077498 Why have a dizzy. It's 2015 I personally do not, nor do I use spark plug wires....
[Re: J_BODY]
#1934615
10/19/15 01:32 AM
10/19/15 01:32 AM
Posts: 345 Nebraska
451Cuda
Nebraska
with that thinking why does a big block have to hit any given number? Why do slant 6 guys try to go faster than other slant 6 guys? Why aren't we just buying used GM based stuff off of Racing Junk and calling it good? With the dollar amounts we're talking here for a max effort n/a vs a comparable hp p/a setup...it's a matter of common sense. There's ways to hit that number that are much cheaper and easier. That's why I ask...why is this the goal? I mean if the guy has trucks full of money that he can throw away just to prove a point and says he made 900 hp n/a with X engine, more power to him and good luck have fun. But if he's on a budget (like most of us) and is under the assumption that he can hit that number within a tight budget, a reality check is approaching.
#1934653
10/19/15 02:36 AM
10/19/15 02:36 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Well we went 8.19 with a 1.14 60' this weekend with 2800lb all motor SB on a 29.5x10.5 tire with a short wheelbase ladder bar car. So I have some idea what kinda money it takes to hit 900hp with a SB Also watched a fellow competitor go 8.006 at 2875 with his all motor SB as well.
#1934829
10/19/15 11:08 AM
10/19/15 11:08 AM
72Swinger
Nebraska
We need a "How much power for $10K" thread on Moparts. My cheap a$$ has his limitations.
[Re: 72Swinger]
#1934848
10/19/15 12:07 PM
10/19/15 12:07 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
We need a "How much power for $10K" thread on Moparts. My cheap a$$ has his limitations. I thought mine did too until I got into this R1 build.
[Re: Al_Alguire]
#1934960
10/19/15 02:44 PM
10/19/15 02:44 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Well we went 8.19 with a 1.14 60' this weekend with 2800lb all motor SB on a 29.5x10.5 tire with a short wheelbase ladder bar car. So I have some idea what kinda money it takes to hit 900hp with a SB Also watched a fellow competitor go 8.006 at 2875 with his all motor SB as well. Hey Al I think you blew right by 900 with that one.. think you're closer to 1000hp to run That et at track not to mention you are racing up hill in a parking lot . Your average racer would have no idea
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
