NEW Predator tool steel shaft rocker #1932637
10/15/15 03:01 PM
10/15/15 03:01 PM
San Jose Ca.
boatracer572 Offline OP
San Jose Ca.
These New CAm FX shaft rockers are tool steel, are lighter on the valve tip than a aluminum rocker, less deflection , needle or bushed tips,don't have the short cycle life that aluminum has.,and all parts are made right here in America. All ratios are available. Rockers are complete with tool steel shafts,tips and ajusters...pm me for details...LIFETIME WARRANTY!!!
Tony
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1932646
10/15/15 03:14 PM
10/15/15 03:14 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That looks very VERY nice!!!!!!!!!!
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: NEW Predator tool steel shaft rocker [Re: pittsburghracer] #1932682
10/15/15 04:38 PM
10/15/15 04:38 PM
Chesterfield Twp. Mi.
John Burdine Offline
your timing isn't very good, I just bought rocker gear a couple days ago.
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1932697
10/15/15 05:03 PM
10/15/15 05:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Big Chief parts stirthepot
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1932698
10/15/15 05:03 PM
10/15/15 05:03 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Seriously they look nice. What ratios are available??
Re: NEW Predator tool steel shaft rocker [Re: Al_Alguire] #1932716
10/15/15 05:50 PM
10/15/15 05:50 PM
San Jose Ca.
San Jose Ca.
was told anything up to 2.1, these are similar but not big chief rockers....
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1932718
10/15/15 05:55 PM
10/15/15 05:55 PM
San Jose Ca.
San Jose Ca.
talked to chris this morning, he has sold a couple sets already and was warming up the CNC to make more...
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1932736
10/15/15 06:21 PM
10/15/15 06:21 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Right - if it looks good, the engineering must be perfect, since (as we all know) all bad designs have rough edges, tool marks, etc.
Boffin Emeritus
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1932813
10/15/15 09:22 PM
10/15/15 09:22 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
These are individual shaft rockers. The smaller axle only spans the width of the rocker. There is a bolt on both sides. 16 bolts hold the rockershafts(splayed valve) instead of 5 on an inline arrangement.
Totally different application. not an apples to apples comparison.
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1932853
10/15/15 10:38 PM
10/15/15 10:38 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Why bother...
Re: NEW Predator tool steel shaft rocker [Re: polyspheric] #1932862
10/15/15 10:45 PM
10/15/15 10:45 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Yeah, glad you get the point. grin
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1932907
10/15/15 11:40 PM
10/15/15 11:40 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I ordered a set of those weak, ill engineered, not as good as aluminum babies today so I guess it was all just one big mistake given the theory of how weak they are.
Having seen plenty of the guy's work, on plenty other tappets, and complete rocker system, and having seen stiffer exhaust rockers pick up power. I think it'll all be ok.
I only use steel on the exhaust side, and I've seen it make more power for anyone interested, or has high cylinder pressure IE blown, or heavy nitrous.
i can attest that EVERYTHING the guy makes is as nice as it comes. Most especially his tappets.
Re: NEW Predator tool steel shaft rocker [Re: dthemi] #1932987
10/16/15 01:22 AM
10/16/15 01:22 AM
San Jose Ca.
San Jose Ca.
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1933158
10/16/15 12:13 PM
10/16/15 12:13 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Literacy evidently not a requirement...
Boffin Emeritus
Re: NEW Predator tool steel shaft rocker [Re: polyspheric] #1933200
10/16/15 01:26 PM
10/16/15 01:26 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Neither is snarkiness, yet there it is...
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1933255
10/16/15 03:11 PM
10/16/15 03:11 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
I run the T & D stainless rockers on the intake and exhaust since its a forced induction app. Did the needle bearing tips and spring oiling option which has performed flawless so far.
Wonder if these are any cheaper than the T&D?
Then again the aluminum ones seem to stand up to boost with no problems with other guys.. Piece of mind costs big money it seems.
What does everyone run for lifters and pushrods?
Smith bros 1/2" to 7/16" taper here and Isky EndurX EZ Roll 3372-EZX I think is the PN.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: NEW Predator tool steel shaft rocker [Re: Efidart] #1933261
10/16/15 03:25 PM
10/16/15 03:25 PM
Hey, Matt. I will be running the Jesel Sportsman .937 lifters, pushrod oiling.
Re: NEW Predator tool steel shaft rocker [Re: boatracer572] #1933639
10/17/15 02:06 AM
10/17/15 02:06 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Splayed low seat jesel tool steel .905 tie bars in the 636, and cam fx .905's in the 660. 1/2" intake, and 5/8" exhaust pushrods.
I had to choose between tappet dia, and lifter bore spacing. I went with highest quality small tappet, with the widest spacing I can do with the blocks I have to work with. My push rod spacing at the tappets is 2.3. That's about as straight as I can get them. I'd do .937, 1", or 1.062' on a 60 mm core if I were planning to zing a smaller CI combo.
Re: NEW Predator tool steel shaft rocker [Re: dthemi] #1933655
10/17/15 02:57 AM
10/17/15 02:57 AM
Why does the stiffer rocker on the exhaust side make such a difference?
Re: NEW Predator tool steel shaft rocker [Re: Efidart] #1933659
10/17/15 03:06 AM
10/17/15 03:06 AM
San Jose Ca.
San Jose Ca.
1.062" cam FX keyway lifters- 9/16 .188 wall double taper pushrods
