NEW Predator tool steel shaft rocker
#1932637
10/15/15 03:01 PM
10/15/15 03:01 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
These New CAm FX shaft rockers are tool steel, are lighter on the valve tip than a aluminum rocker, less deflection , needle or bushed tips,don't have the short cycle life that aluminum has.,and all parts are made right here in America. All ratios are available. Rockers are complete with tool steel shafts,tips and ajusters...pm me for details...LIFETIME WARRANTY!!! Tony
Re: NEW Predator tool steel shaft rocker
[Re: boatracer572]
#1932646
10/15/15 03:14 PM
10/15/15 03:14 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That looks very VERY nice!!!!!!!!!!
[Re: boatracer572]
#1932698
10/15/15 05:03 PM
10/15/15 05:03 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Seriously they look nice. What ratios are available??
[Re: Al_Alguire]
#1932716
10/15/15 05:50 PM
10/15/15 05:50 PM
boatracer572
San Jose Ca.
was told anything up to 2.1, these are similar but not big chief rockers....
[Re: boatracer572]
#1932736
10/15/15 06:21 PM
10/15/15 06:21 PM
Posts: 4,210 New York
polyspheric
New York
Right - if it looks good, the engineering must be perfect, since (as we all know) all bad designs have rough edges, tool marks, etc.
Boffin Emeritus
[Re: boatracer572]
#1932813
10/15/15 09:22 PM
10/15/15 09:22 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
These are individual shaft rockers. The smaller axle only spans the width of the rocker. There is a bolt on both sides. 16 bolts hold the rockershafts(splayed valve) instead of 5 on an inline arrangement. Totally different application. not an apples to apples comparison.
[Re: boatracer572]
#1932907
10/15/15 11:40 PM
10/15/15 11:40 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
I ordered a set of those weak, ill engineered, not as good as aluminum babies today so I guess it was all just one big mistake given the theory of how weak they are.
Having seen plenty of the guy's work, on plenty other tappets, and complete rocker system, and having seen stiffer exhaust rockers pick up power. I think it'll all be ok.
I only use steel on the exhaust side, and I've seen it make more power for anyone interested, or has high cylinder pressure IE blown, or heavy nitrous.
i can attest that EVERYTHING the guy makes is as nice as it comes. Most especially his tappets.
[Re: dthemi]
#1932987
10/16/15 01:22 AM
10/16/15 01:22 AM
boatracer572
San Jose Ca.
[Re: boatracer572]
#1933158
10/16/15 12:13 PM
10/16/15 12:13 PM
polyspheric
New York
Literacy evidently not a requirement...
Boffin Emeritus
[Re: boatracer572]
#1933255
10/16/15 03:11 PM
10/16/15 03:11 PM
Posts: 200 AB
Efidart
AB
I run the T & D stainless rockers on the intake and exhaust since its a forced induction app. Did the needle bearing tips and spring oiling option which has performed flawless so far.
Wonder if these are any cheaper than the T&D?
Then again the aluminum ones seem to stand up to boost with no problems with other guys.. Piece of mind costs big money it seems.
What does everyone run for lifters and pushrods?
Smith bros 1/2" to 7/16" taper here and Isky EndurX EZ Roll 3372-EZX I think is the PN.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: Efidart]
#1933261
10/16/15 03:25 PM
10/16/15 03:25 PM
Posts: 1,404 Chesterfield Twp. Mi.
John Burdine
Hey, Matt. I will be running the Jesel Sportsman .937 lifters, pushrod oiling.
[Re: Efidart]
#1933659
10/17/15 03:06 AM
10/17/15 03:06 AM
boatracer572
San Jose Ca.
1.062" cam FX keyway lifters- 9/16 .188 wall double taper pushrods
