Transbrake Case Connector - What are you using? #1932022
10/14/15 02:49 PM
10/14/15 02:49 PM
Central California
MoParFish Offline OP
Central California
Just curious what everyone is using for a case connector for the transbrake solenoid wire,,,that doesn't leak ... Seems like there would be something simple that resembles a pipe plug with insulated blade terminals at each end but, I don't find one shruggy
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Transbrake Case Connector - What are you using? [Re: MoParFish] #1932076
10/14/15 04:02 PM
10/14/15 04:02 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I looked around and couldn't find anything, found this site though and roughly followed its instructions to make my own.
http://www.thatmetalbox.com/automotive/bulkHead-FeedThrough/
Mine held up to mud bogging this year, no water or mud in the transmission.
Re: Transbrake Case Connector - What are you using? [Re: MoParFish] #1932082
10/14/15 04:11 PM
10/14/15 04:11 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Turbo Action, ProTrans and others include a case connector with their transbrake kits. Don't know if they sell them separately. I believe it's a Mopar part #4348945. I think I have a few around here somewhere.
Re: Transbrake Case Connector - What are you using? [Re: CMcAllister] #1932108
10/14/15 04:44 PM
10/14/15 04:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I just use a brass NTP to inverted flair adapter and drill the center hole to snugly fit the #10 wire and then use JB weld to fill in the recess on the inverted flair end making sure I slide the wire in and out to pull a little JB down around the wire and adapter to work any bubbles or divots out then let sit over night, add required terminal ends and you are good as gold,,, never had one leak yet.
Re: Transbrake Case Connector - What are you using? [Re: dartman366] #1932652
10/15/15 03:23 PM
10/15/15 03:23 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Re: Transbrake Case Connector - What are you using? [Re: MoParFish] #1932753
10/15/15 06:52 PM
10/15/15 06:52 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
i got mine from cope. it's a A&A
Re: Transbrake Case Connector - What are you using? [Re: CTD5.9] #1932789
10/15/15 08:01 PM
10/15/15 08:01 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Mine looks like that as well on my 727.
I am currently rebuilding a lock up 999 (904) for my work truck. It has terminal that is a pipe thread in the case where my 727 has the trans brake terminal. I am not sure what it does in the 999 LOL, I would guess it is the wire that engages the lock up converter. REGARDLESS what it does in stock form, as soon as I saw it on the 999 I thought "That looks like it would work as a trans brake terminal"
-Kenny
Re: Transbrake Case Connector - What are you using? [Re: dartman366] #1932840
10/15/15 10:21 PM
10/15/15 10:21 PM
Central California
Central California
Thanks for the good info guys thumbs I was considering the A&A connector but can't find a single pic of it on the web. I'm sure it's great, just like to see what I'm getting.. Reading dartman366's reply got me thinking about using a compression fitting for 1/8 tubing similar to what comes what comes with cheap oil pressure gauges. Just drill the fitting to 1/8 inch, use size of wire that's just small enough to slip through the ferule and run it through the fitting into the case. Just tighten the compression nut until it clamps the wire snug. Think I might give it a shot.. It works in my head anyway grin
Re: Transbrake Case Connector - What are you using? [Re: MoParFish] #1932945
10/16/15 12:16 AM
10/16/15 12:16 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
One I got with my Pro Trans T-brake.....
Re: Transbrake Case Connector - What are you using? [Re: MoParFish] #1933035
10/16/15 02:29 AM
10/16/15 02:29 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I have what Jay's got, tapped into the rear of the case in both of mine.
"Just a Bracket car dressed up like a streetcar"
Re: Transbrake Case Connector - What are you using? [Re: MoParFish] #1933052
10/16/15 03:21 AM
10/16/15 03:21 AM
Central California
Central California
Looks like a nice piece...Thanks guys...
Re: Transbrake Case Connector - What are you using? [Re: MoParFish] #1933053
10/16/15 03:23 AM
10/16/15 03:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
pm me an address you'll magically owe me a beer.
