Re: Transbrake Case Connector - What are you using?
[Re: MoParFish]
#1932082
10/14/15 04:11 PM
10/14/15 04:11 PM
Posts: 11,573 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Turbo Action, ProTrans and others include a case connector with their transbrake kits. Don't know if they sell them separately. I believe it's a Mopar part #4348945. I think I have a few around here somewhere.
[Re: CMcAllister]
#1932108
10/14/15 04:44 PM
10/14/15 04:44 PM
dartman366
Mt. Vernon, Ohio
I just use a brass NTP to inverted flair adapter and drill the center hole to snugly fit the #10 wire and then use JB weld to fill in the recess on the inverted flair end making sure I slide the wire in and out to pull a little JB down around the wire and adapter to work any bubbles or divots out then let sit over night, add required terminal ends and you are good as gold,,, never had one leak yet.
[Re: CTD5.9]
#1932789
10/15/15 08:01 PM
10/15/15 08:01 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Mine looks like that as well on my 727. I am currently rebuilding a lock up 999 (904) for my work truck. It has terminal that is a pipe thread in the case where my 727 has the trans brake terminal. I am not sure what it does in the 999 LOL, I would guess it is the wire that engages the lock up converter. REGARDLESS what it does in stock form, as soon as I saw it on the 999 I thought "That looks like it would work as a trans brake terminal" -Kenny
[Re: MoParFish]
#1933035
10/16/15 02:29 AM
10/16/15 02:29 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I have what Jay's got, tapped into the rear of the case in both of mine.
"Just a Bracket car dressed up like a streetcar"
