69 B Body post 1/4 window? #1931570
10/13/15 07:17 PM
10/13/15 07:17 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Is there suppose to be something that holds the 1/4 window tight against the 1/4 belt area? There are 3 screws on the post and one in the area by the lock in the sail panel area but to me it should sit tighter against the 1/4.
Contact Me about AMD Prices
Re: 69 B Body post 1/4 window? [Re: hotairballoonpilot] #1931729
10/13/15 11:22 PM
10/13/15 11:22 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
That's all there is... I dont know if its the aftermarket AMD quarter panels or not, but my windows and gaskets fit so poorly that I ended up using some stiff spring clamps to squeeze it all together. I'm sure that there is a better fix, but its been working for me for 4-5 years now.
beer
Paul
'69 Super Bee 383 EFI Turbo
Re: 69 B Body post 1/4 window? [Re: Black_Bee] #1931903
10/14/15 10:15 AM
10/14/15 10:15 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Just the 4 screws hold it in. You could try and elongate the holes on the front to get it out a bit more.
If a replacement quarter, it appears the top was not rolled in far enough. The gap is excessive.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: 69 B Body post 1/4 window? [Re: hotairballoonpilot] #1932166
10/14/15 06:27 PM
10/14/15 06:27 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
I have the same problem on my roadrunner, there is a 1/4" gap and no easy fix. I thought it was the windows, so I sourced a second set...but that wasn't the problem. I had one replacement quarter but I have the same problem on both sides... work
Re: 69 B Body post 1/4 window? [Re: nutso suave] #1932395
10/15/15 12:44 AM
10/15/15 12:44 AM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
I ran into this with my 1969 Road Runner. I replaced mine because they were frosted "Back in the Day". Anyway what I didn't notice that my car actually had Super Bee windows that actually fit really good. I was getting very frustrated trying to get the correct Road Runner ones to fit as well. I had them in and out multiply times. Best fit came with gently prying up and out on the frame of the window while tightening the screws.
Crazy that the Super Bee ones sealed up better, there is no gap with mine but it isn't as tight to the quarter...I am sure if the car got wet, water would easily leak down into the quarter.
Re: 69 B Body post 1/4 window? [Re: hotairballoonpilot] #1932619
10/15/15 02:26 PM
10/15/15 02:26 PM
South Dakota
South Dakota
thanks guys I will have to see what I can do to make them fit better. Drivers side sits better than passenger side. Will see
Re: 69 B Body post 1/4 window? [Re: hotairballoonpilot] #1933568
10/17/15 12:16 AM
10/17/15 12:16 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Had the same problem, it has been a few years but I believe I added some 3M strip caulk to space the gasket closer to the quarter panel. I added it between the metal frame and the gasket to plump it our.
It was a bit of trial and error but came out good.
