Page 1 of 12 1 2 3 11 12
Cost of 900 hp in a N/A small block? #1931406
10/13/15 02:20 PM
10/13/15 02:20 PM
Out West
408strokerdart Offline OP
Out West
Mopar guys seem to have a reputation of being "cheap" in general, but I know some of us that are not.
I'm just trying to get a feel from some on this board on what they think 900 hp should cost in a N/A small block...carb to pan. I know there are other options for 900 hp that might be cheaper, but thats for another topic.
There are a few here that know the answer to this question, but would like to hear from a few that haven't been down this road yet.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931415
10/13/15 02:33 PM
10/13/15 02:33 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
someone on here was selling their 360-1 head small block that made in the 700s and said it was a $19k engine.
So I will guess 26k
Re: Cost of 900 hp in a N/A small block? [Re: sixpackgut] #1931419
10/13/15 02:39 PM
10/13/15 02:39 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
So I will guess 26k
To get a REAL 900hp from a true inline wedge smallblock.......26K won't begin to touch it, even if you can do it, which I have my doubts. I know guys can produce dyno sheets that SAY their inline motor makes that, but that's another discussion.
That power number can be attained with canted valve heads, but it's still likely going to be a 40K small block
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931422
10/13/15 02:42 PM
10/13/15 02:42 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Can a n/a small block make 900 hp? My guess is a R5/p7 may be the cheapest, if it would do it. If it could be done with a R3/W8 I'm going to say over 40 grand. My R1 Indy head will hopefully make 650-675 on pump gas. Knowing what this build has cost I would've taken a different route, or maybe said screw it and sold out.
Re: Cost of 900 hp in a N/A small block? [Re: Monte_Smith] #1931425
10/13/15 02:45 PM
10/13/15 02:45 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
So I will guess 26k
Not sure if Brian's makes 900 but its close. 2800 @ 156 is 851 so I'm looking forward to hearing the details of this
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931428
10/13/15 02:50 PM
10/13/15 02:50 PM
AndyF Online content
AndyF  Online Content
410 sprint car motors usually make 830 to 850 hp and cost around $45K or $50K. I'm pretty sure that if you call up Stanton and ask him for 900 hp drag race version he'll build it for you. Might cost $60K by the time you come up with a different cam/compression/head package for drag racing.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931432
10/13/15 02:54 PM
10/13/15 02:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Do you consider a gen III a SB? The engine masters make 700 with them and they have RPM limits and cams are basically mandated by rules to be on the very short side of duration as well as very conservative compression limits. Throw in 30 degrees more cam, 2 points more compression another 20-30 cubes sheetmetal intake more liberal port size and I think it could be done but like Monte said you may get it on a dyno but in the real world who knows till you try it.
If inline wedge is it than a W8 is the only way to stand a chance.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931442
10/13/15 03:07 PM
10/13/15 03:07 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Im pretty much guessing here but... R5p7 with more comp, more cam, better intake should be close. Cost COULD be under 15k if you find a good used motor witch ive seen from $3500.
Re: Cost of 900 hp in a N/A small block? [Re: sshemi] #1931446
10/13/15 03:15 PM
10/13/15 03:15 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I know what it cost to build a 590 hp small block,,, more than I ever spent in my life on a motor,, as far as Brians motor, I am going to guess 55-60 g's.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931466
10/13/15 03:37 PM
10/13/15 03:37 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
IMO, the only "fair" way to estimate the cost is if you assume it was built from all new, currently available parts. Otherwise it's just a game of who can find the best deal on the best used parts, which not everyone is going to be able to come up with.
A 572ci BB, using premium internals and valve train components would be in the mid-20's.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931469
10/13/15 03:43 PM
10/13/15 03:43 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Im starting to realize the 8k I'm willing to spend is not going to get me there
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931474
10/13/15 03:45 PM
10/13/15 03:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
An " upgraded" r5 p7 will be the cheapest way.
I know a freshened complete motor can be had for 10k or less complete that will make 750-800 horse.
It's then a matter of whatever is involved to make the extra power.
Buddy of mine bought such a motor, put it in a 3000 pound car and ran 9.40's at 143 with it exactly how he bought it( for well under 10k complete)
This was 12 to1 and had a dinky248/258@ 50 camshaft in it. Lots of room there to upgrade I would think. He took the heads off and had them flowed by a well known in these parts head guru and they went over 400.
He ran a 4150 carb and old W2 headers he made work on it.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Cost of 900 hp in a N/A small block? [Re: B3422W5] #1931480
10/13/15 03:52 PM
10/13/15 03:52 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
The R5p7 deal will do it easy. With the NASCRAP rules the Penske motors were making north of 850. You can buy complete motors with inconel headers and all for 7 to 8 all day long. Yeah they need fresh pieces but the hardware alone is worth that. Larry Smith tells me that Nascrap have a rule where by the top of the cylinder port measured from the centerline of the crank is limited. Take away the rule and do set from scratch and he says you might get close to a grand......Todd
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931516
10/13/15 05:37 PM
10/13/15 05:37 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
Racing Engines By Arrington has this listed
Dodge Mopar R6 with Aluminum P8 Cylinder Heads NASCAR Racing Engine
$24,900 Dodge R6 Racing Engine
400 Miles since last rebuild
Moroso Distributor
Bosch Alternator
Moroso Oil Pan
AET Pistons
AET Connecting Rods
4.176 Bore
3.253 Stroke
6.175 Rod Length
12:1 Compression
.382 / 105 Cam w/ 2.2 Rocker Ratio
9.005 Deck Height
40.8 Cylinder Head Chamber Volume
It is 850 hp
Switched to the dark side...
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931523
10/13/15 05:48 PM
10/13/15 05:48 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If you read the internet and listen to guys at the track...........there is a swinging dick on EVERY street corner with an inline valve, wedge smallblock, that makes over 900HP. I have been doing this stuff for a LONG time and have NEVER seen one, be it a Ford, Mopar or Chevy. As I said, you can do it with some canted valve stuff, but it's still not REAL easy and will be at a min of 40K if you do it with all new stuff.
I have done several 434ish Chevys and Fords, with the BEST 15-18* heads you can buy. A good one will make between 840 and 880, depending on cam, compression, rotating weight, etc. I have yet to see a Mopar head that was BETTER than the best off brand, so I am going to say it can't even realistically be done with an inline head........regardless to what some dyno sheets may say to the contrary
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931540
10/13/15 06:03 PM
10/13/15 06:03 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Now that you see what it costs...
is NA really that important?
Boffin Emeritus
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931541
10/13/15 06:04 PM
10/13/15 06:04 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Interesting post. There might be one or two, the score boards tell the real truth though. To go over 850 costs lots of $$ and rpm.
Re: Cost of 900 hp in a N/A small block? [Re: sixpackgut] #1931575
10/13/15 07:24 PM
10/13/15 07:24 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
So I will guess 26k
Not sure what you consider "close"......but within 50 isn't close to me. And as I said, if his does in fact make 850, that is a realistic number for a "killer" inline headed motor, because I see a LOT of those. a TRUE 900.....NEVER seen one. When you get to this HP level on this type motor, 10 hp is a TON, 50 is an eternity
Re: Cost of 900 hp in a N/A small block? [Re: Monte_Smith] #1931597
10/13/15 07:54 PM
10/13/15 07:54 PM
No doubt it can be done if the only rules are "SB" and "inline wedge head" and "NA". No doubt it would be an R&D exercise but it could be done. (the op didn't say anything about wedge heads only so that is a rule that you made up Monte)
The Pro Stock truck guys were 950 hp from 358 cubes a few years back and the Aussie Pro Stock guys are 1100 hp from 400 cubes. I've seen dyno sheets from 900 hp SB motors which seem believeable and there are turn key sprint car engines which are in the neighborhood of the number. So when you add those data points up it looks like an achieveable number to me.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1931623
10/13/15 08:31 PM
10/13/15 08:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well I know what the 900-1000hp INLINE SB Comp stuff costs and they are generally well north of $50K. But these are small cube high reving deals.
For those saying I know about this or that combo making 700hp, who cares. 700HP is MILES away from a TRUE 900hp deal, especially in a SB.
Aussie Pro stock aint an inline head and the R&D money in those is STUPID money. I have around many very good comp teams and know what they spend on engine development and engine combos. Spend a fair amount of time at a builder that does Aussie Pro Stock P5 stuff and the heads up car we are involved with is basically an Aussi Pro Stock SB Chevy combo making 1055hp. So I have a pretty good idea what it takes and truct me you aint taking a 700HP combo and getting there.
