540ci low deck combos #1930675
10/12/15 08:43 AM
10/12/15 08:43 AM
MN
JERICOGTX Offline OP
MN
I am thinking about building a new short block for my Road Runner. Want to go with a Indy aluminum block. Just curious what others have used for internal parts in that combo.
Jeff
69 GTX 68 Road Runner
Re: 540ci low deck combos [Re: JERICOGTX] #1930719
10/12/15 10:14 AM
10/12/15 10:14 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Hemi.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 540ci low deck combos [Re: JERICOGTX] #1930754
10/12/15 11:49 AM
10/12/15 11:49 AM
MN
MN
Those are for high rollers not poor people like me.
Re: 540ci low deck combos [Re: JERICOGTX] #1930990
10/12/15 07:10 PM
10/12/15 07:10 PM
birdtracker Offline
birdtracker  Offline
I currently have a 474 with stage6 heads and a 690 comp roller. I just got my Indy block and am in the same boat. I think the 690 is plenty of cam for a natural aspirated . Waiting to get my 4.25 crank. Its going to be an Eagle 4340 with 440 mains and 2.2 rod end. I have not picked a rod as I am think about hanging one 88 mm turbo off the front. Great thread. Thanks for starting it. Birdtracker
Re: 540ci low deck combos [Re: JERICOGTX] #1931004
10/12/15 07:40 PM
10/12/15 07:40 PM
gregsdart Offline
gregsdart  Offline
If you are going to go with an alloy block I am guessing you plan on putting some serious heads on it?
A basic combo would be 4.25 stroke, 4.50 bore, B1 or B1Mc heads, 6.535 long aluminum rods, standard 9.980 deck and a good quality crank.
Paul Pitman ran this combo with the Mc heads many years ago, made a bundle of power. (1050?)
Re: 540ci low deck combos [Re: JERICOGTX] #1931026
10/12/15 08:18 PM
10/12/15 08:18 PM
What is the intended application and use?
Re: 540ci low deck combos [Re: JERICOGTX] #1931079
10/12/15 09:44 PM
10/12/15 09:44 PM
MN
MN
Greg, I would use my current Indy SR heads. Probably have the ports cleaned up a little more and go to a 2.25 intake valve. I would like to make around 830-850hp and keep the Rpms under 7200. If I was going to change heads I would just build a 605 HEMI, but I do not want my Jerico trans to be a ticking time bomb.
I just want to build a very solid bracket motor that will last.
Re: 540ci low deck combos [Re: JERICOGTX] #1931095
10/12/15 10:08 PM
10/12/15 10:08 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Sell the wedge stuff and build a 605. You'll have to ditch the Jerico. My underheaded 605 makes 853hp@5782rpm.Dave
Re: 540ci low deck combos [Re: JERICOGTX] #1931097
10/12/15 10:17 PM
10/12/15 10:17 PM
MN
MN
Unless I have my left leg amputated, I will NEVER run a automatic trans. I'd rather give up racing and take up knitting.
Re: 540ci low deck combos [Re: JERICOGTX] #1931126
10/12/15 10:53 PM
10/12/15 10:53 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
Somewhat like you Jeff, I'm thinking reliability, especially now that I split a cylinder. Guess Ill call fiat and order my new block.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: 540ci low deck combos [Re: JERICOGTX] #1931243
10/13/15 02:47 AM
10/13/15 02:47 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm wanting a sweater. what are your knitting skills like?
Re: 540ci low deck combos [Re: JERICOGTX] #1931270
10/13/15 08:20 AM
10/13/15 08:20 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I didn't say give up a 4 spd, maybe upgrade.
Re: 540ci low deck combos [Re: JERICOGTX] #1931289
10/13/15 10:03 AM
10/13/15 10:03 AM
gregsdart Offline
gregsdart  Offline
Jeff, running those heads you should have no problem staying below 7200 rpm, maybe even 7000 max or less if you want to run a gear to trap at shift rpm. My 528 with 440-1 heads makes max power at 6900 (on Methanol though) as a rough bench mark.
One question I have is about running steel rods with the alloy block. To get decent quench when hot, the pistons may end up with only .020 piston to head clearance when cold to get .040 at running temp? That might make it necessary to run aluminum rods?
That weight loss up front sure will be nice! Care to say what you figure the block ready to assemble costs?
Re: 540ci low deck combos [Re: quickd100] #1931290
10/13/15 10:04 AM
10/13/15 10:04 AM
Colorado
506RR Offline
506RR  Offline
Colorado
If you are gonna stick with the SR heads, maybe go with a 4.44 bore?
Save the 4.5 bore until you upgrade to some better heads?
Either way, it will make a ton of torque and be a blast to drive!
Re: 540ci low deck combos [Re: 506RR] #1931295
10/13/15 10:15 AM
10/13/15 10:15 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Indy makes the blocks with 2 different sleeve outside dia. One for 4.375 to 4.440 and one for 4.500 so you have to chrange sleeves. Didn't just make a thick wall sleeve that can be bored from 4.375 to 4.500. Another way to milk more money out I guess.
Re: 540ci low deck combos [Re: JERICOGTX] #1931357
10/13/15 01:00 PM
10/13/15 01:00 PM
MN
MN
I will take the biggest bore I can get all day long. The bare block from Indy is $4800. I would then take it to my machinist and have him do the final cleanup work.
Re: 540ci low deck combos [Re: JERICOGTX] #1931363
10/13/15 01:12 PM
10/13/15 01:12 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
On a low deck the 4.25" 6.535" 2.200/.990 (BBC journal & Pin) Rod bottom end is proven strong and reliable and not too hard on the block side loading, it gives you about a 1.32" Compression height piston. If I were going High dollar block I think I would opt for a 6.700 rod, 6.800" is doable as well but it puts the pin way up in the piston/ring pack.
but If I were going aluminum block I think I'd just go all-out and get an RB and maybe even a raised cam core and go BIGGER on the stroke and long as possible on the rod. Why build a 540 when you can build a 605 for the same $$$. the weight savings is in the Aluminum block, 605 is like an extra cylinder's worth of displacement.
WIZE
In Car:
Re: 540ci low deck combos [Re: Streetwize] #1931366
10/13/15 01:18 PM
10/13/15 01:18 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
We have a few on our FaceBook page. Here is a link to one of them https://www.facebook.com/media/set/?set=a.709748919080794.1073741846.135175363204822&type=3
Re: 540ci low deck combos [Re: JERICOGTX] #1931412
10/13/15 02:25 PM
10/13/15 02:25 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
my 540 low deck,630 block uses a 4.500 ohio crank that lighten,400 mains,chevy 2.20 rod ends,bme 396 aluminum rods
Re: 540ci low deck combos [Re: JERICOGTX] #1931427
10/13/15 02:48 PM
10/13/15 02:48 PM
MN
MN
Thanks Pete. I have looked at those pictures. Are the Compstar rods Callies?
As for upgrading this that and every other thing possible, well I am not made of money. I possibly have a chance to sell my current 499 short block, and just want to upgrade to a nice reliable piece. Nothing more nothing less...
When I hit the lottery then yes I'll be building a 605 HEMI with a Liberty 5 speed. Until then...
