540ci low deck combos
#1930675
10/12/15 08:43 AM
10/12/15 08:43 AM
Posts: 10,039 MN
JERICOGTX
MN
I am thinking about building a new short block for my Road Runner. Want to go with a Indy aluminum block. Just curious what others have used for internal parts in that combo.
Jeff
69 GTX
68 Road Runner
Re: 540ci low deck combos
[Re: JERICOGTX]
#1930719
10/12/15 10:14 AM
10/12/15 10:14 AM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: JERICOGTX]
#1930754
10/12/15 11:49 AM
10/12/15 11:49 AM
Posts: 10,039 MN
JERICOGTX
MN
Those are for high rollers not poor people like me.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#1931004
10/12/15 07:40 PM
10/12/15 07:40 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you are going to go with an alloy block I am guessing you plan on putting some serious heads on it? A basic combo would be 4.25 stroke, 4.50 bore, B1 or B1Mc heads, 6.535 long aluminum rods, standard 9.980 deck and a good quality crank. Paul Pitman ran this combo with the Mc heads many years ago, made a bundle of power. (1050?)
[Re: JERICOGTX]
#1931026
10/12/15 08:18 PM
10/12/15 08:18 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
What is the intended application and use?
[Re: JERICOGTX]
#1931079
10/12/15 09:44 PM
10/12/15 09:44 PM
Posts: 10,039 MN
JERICOGTX
MN
Greg, I would use my current Indy SR heads. Probably have the ports cleaned up a little more and go to a 2.25 intake valve. I would like to make around 830-850hp and keep the Rpms under 7200. If I was going to change heads I would just build a 605 HEMI, but I do not want my Jerico trans to be a ticking time bomb.
I just want to build a very solid bracket motor that will last.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#1931097
10/12/15 10:17 PM
10/12/15 10:17 PM
Posts: 10,039 MN
JERICOGTX
MN
Unless I have my left leg amputated, I will NEVER run a automatic trans. I'd rather give up racing and take up knitting.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#1931126
10/12/15 10:53 PM
10/12/15 10:53 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Unless I have my left leg amputated, I will NEVER run a automatic trans. I'd rather give up racing and take up knitting. Somewhat like you Jeff, I'm thinking reliability, especially now that I split a cylinder. Guess Ill call fiat and order my new block.
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: JERICOGTX]
#1931243
10/13/15 02:47 AM
10/13/15 02:47 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Unless I have my left leg amputated, I will NEVER run a automatic trans. I'd rather give up racing and take up knitting. i'm wanting a sweater. what are your knitting skills like?
[Re: JERICOGTX]
#1931289
10/13/15 10:03 AM
10/13/15 10:03 AM
gregsdart
Jeff, running those heads you should have no problem staying below 7200 rpm, maybe even 7000 max or less if you want to run a gear to trap at shift rpm. My 528 with 440-1 heads makes max power at 6900 (on Methanol though) as a rough bench mark. One question I have is about running steel rods with the alloy block. To get decent quench when hot, the pistons may end up with only .020 piston to head clearance when cold to get .040 at running temp? That might make it necessary to run aluminum rods? That weight loss up front sure will be nice! Care to say what you figure the block ready to assemble costs?
[Re: JERICOGTX]
#1931357
10/13/15 01:00 PM
10/13/15 01:00 PM
Posts: 10,039 MN
JERICOGTX
MN
I will take the biggest bore I can get all day long. The bare block from Indy is $4800. I would then take it to my machinist and have him do the final cleanup work.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#1931427
10/13/15 02:48 PM
10/13/15 02:48 PM
Posts: 10,039 MN
JERICOGTX
MN
Thanks Pete. I have looked at those pictures. Are the Compstar rods Callies?
As for upgrading this that and every other thing possible, well I am not made of money. I possibly have a chance to sell my current 499 short block, and just want to upgrade to a nice reliable piece. Nothing more nothing less...
When I hit the lottery then yes I'll be building a 605 HEMI with a Liberty 5 speed. Until then...
69 GTX
68 Road Runner
