Re: Trick Flow heads
[Re: fast68plymouth]
#1930251
10/11/15 04:27 PM
10/11/15 04:27 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
It would be great if there was a comparison with same short block two sets of heads, Trick Flow and Edelbrock or Indy.
Have a great day Iowan
"obsolete is neat"
#1930402
10/11/15 08:42 PM
10/11/15 08:42 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
These heads look like my EZ heads only much nicer finish. I have to wonder why Trickflow doesn't make rockers to mate with these heads ![work work](/ubbthreads/images/graemlins/custom/work.gif) It cant be a big secret that there are issues with rocker arm geometry on big block Mopar heads. I really like my EZ heads but if these heads were out when I bought my Indys I would have bought these just because the ports look more finished.I had to do a lot of work to my EZ heads to make them work as well as they do. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
#1930743
10/12/15 11:08 AM
10/12/15 11:08 AM
Posts: 1,237 North Central, Indiana
Roughbird72
I have a few different rockers here I test fit to check the sweep. The standard HS rockers are really too long. The TF specified part number is the rockers that fit the RPM heads, and they are shorter, so they should fit well. I also checked an Indy/Dove rocker. Slightly too long. A Comp Pro-magnum looks pretty good, but the best sweep of the rockers I have here was with a Crane Gold. I believe the "short" HS rockers are supposed to have the same shaft to roller relationship as the Crane Golds, although I haven't had any of those to check myself.
The things I've said I would do differently on these heads are really kind of nit-picky things. Of the currently available BB Mopar offerings, I would say these have the nicest overall fit and finish, especially when you take the price into consideration. I don't see how you can go wrong with these things for $2000, if they will work in your combination for the level of performance you're after.
Keep in mind, TF guarantees you won't have any problems with the guides, valve job, valves, springs, etc. for two years, and I'm sure most of the heads they sell will get taken out of the box and bolted on. Would you foresee any problems running the Crane ductile rockers? ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
72 Plymouth Roadrunner 11.08@123.25
[Re: dart games]
#1930746
10/12/15 11:16 AM
10/12/15 11:16 AM
Posts: 4,704 Wichita
GY3
Wichita
fabo also has a thread on these heads and did some flow numbers Yep. And, as usual, something in the water in Idaho leads to inflated flow bench numbers when compared to two others that are virtually identicle. ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: GY3]
#1930767
10/12/15 12:06 PM
10/12/15 12:06 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
fabo also has a thread on these heads and did some flow numbers Yep. And, as usual, something in the water in Idaho leads to inflated flow bench numbers when compared to two others that are virtually identicle. numbers ??
[Re: GY3]
#1930793
10/12/15 12:45 PM
10/12/15 12:45 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
fabo also has a thread on these heads and did some flow numbers Yep. And, as usual, something in the water in Idaho leads to inflated flow bench numbers when compared to two others that are virtually identicle. Link me, dude. I was waiting for the big numbers from "the Idaho bench" to get posted here. Kinda curious they weren't. But numbers higher than everyone else sorta confirms that the bench is Maybe Jim did a little magical clean up of the factory porting, hence the bigger numbers (at least that is what I'd claim ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) ). A guy on the bullet mentioned he got one of the first sets of heads. I advised him to send them to Andy F since they're both in the same state. He said he was sending them to Idaho instead. I warned him about the inflated numbers that come out of that part of the country but he sent them anyway. LINK --- V Scroll to post #48http://www.yellowbullet.com/forum/showthread.php?t=1178282&highlight=trick+flow+mopar+heads
[Re: 64Post]
#1930866
10/12/15 02:36 PM
10/12/15 02:36 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
It's been my experience that he's usually pretty consistent if he's flowing an as-cast port. It's the "hand ported" results that IMO get really creative. Sometimes darn near impossibly creative.
[Re: 64Post]
#1931153
10/12/15 11:36 PM
10/12/15 11:36 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
It's been my experience that he's usually pretty consistent if he's flowing an as-cast port. It's the "hand ported" results that IMO get really creative. Sometimes darn near impossibly creative. Maybe Jim has hands like these and can get in the port where no 5 axis machine can... Ha ha!
Brian Hafliger
