Page 4 of 45 1 2 3 4 5 6 44 45
Re: Trick Flow heads [Re: fast68plymouth] #1930183
10/11/15 02:27 PM
10/11/15 02:27 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Nice Info Dwayne!
Its a nice to see they are living up to all the hype so far!
The info on the rockers that fit is interesting
Rocker arms: Harland Sharp #S70015KE (1.5 ratio)
Harland Sharp #S70016KE (1.6 ratio)
Most COMP Cams and Crane Cams rockers
They also recommend
Rocker arm stud kit: Trick Flow #TFS-61600613
The only place that I can find that lists these other than HS (and they only list the 1.5)is Summit at $907 - I wonder if the Scorpion rocker under development will be the go to rocker for these since they do make many of rockers for the Ford Trick Flow heads.
Re: Trick Flow heads [Re: fast68plymouth] #1930251
10/11/15 04:27 PM
10/11/15 04:27 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
It would be great if there was a comparison with same short block two sets of heads, Trick Flow and Edelbrock or Indy.
Have a great day
Iowan
"obsolete is neat"
Re: Trick Flow heads [Re: fast68plymouth] #1930402
10/11/15 08:42 PM
10/11/15 08:42 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
These heads look like my EZ heads only much nicer finish. I have to wonder why Trickflow doesn't make rockers to mate with these heads work It cant be a big secret that there are issues with rocker arm geometry on big block Mopar heads. I really like my EZ heads but if these heads were out when I bought my Indys I would have bought these just because the ports look more finished.I had to do a lot of work to my EZ heads to make them work as well as they do.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Trick Flow heads [Re: fast68plymouth] #1930560
10/12/15 12:43 AM
10/12/15 12:43 AM
JCFcuda Offline
JCFcuda  Offline
Thanks Dywane
glad you're posting good information on the board again
Very informative as usual
Just wish there were more post like this.
Jim F
Re: Trick Flow heads [Re: fast68plymouth] #1930653
10/12/15 04:45 AM
10/12/15 04:45 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
fabo also has a thread on these heads and did some flow numbers
Re: Trick Flow heads [Re: GY3] #1930672
10/12/15 08:40 AM
10/12/15 08:40 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Originally Posted By GY3
People would be goin' out of their damn minds if this little square was on a "Chinese" head casting... runaway whistle
You must be new here... shruggy
They'd be offering up 1001 and one uses .. and excuses ... for bubble gum to fill that hole wink
Re: Trick Flow heads [Re: dartman366] #1930673
10/12/15 08:41 AM
10/12/15 08:41 AM
JohnRR Offline
JohnRR  Offline
Originally Posted By dartman366
Is there anything on the deck of the block that would intersect that square divit in the head like any open passage?
yes ... the lifter valley ...
Re: Trick Flow heads [Re: fast68plymouth] #1930743
10/12/15 11:08 AM
10/12/15 11:08 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Originally Posted By fast68plymouth
I have a few different rockers here I test fit to check the sweep.
The standard HS rockers are really too long. The TF specified part number is the rockers that fit the RPM heads, and they are shorter, so they should fit well.
I also checked an Indy/Dove rocker. Slightly too long.
A Comp Pro-magnum looks pretty good, but the best sweep of the rockers I have here was with a Crane Gold. I believe the "short" HS rockers are supposed to have the same shaft to roller relationship as the Crane Golds, although I haven't had any of those to check myself.
The things I've said I would do differently on these heads are really kind of nit-picky things. Of the currently available BB Mopar offerings, I would say these have the nicest overall fit and finish, especially when you take the price into consideration.
I don't see how you can go wrong with these things for $2000, if they will work in your combination for the level of performance you're after.
Keep in mind, TF guarantees you won't have any problems with the guides, valve job, valves, springs, etc. for two years, and I'm sure most of the heads they sell will get taken out of the box and bolted on.
Would you foresee any problems running the Crane ductile rockers? shruggy
72 Plymouth Roadrunner 11.08@123.25
Re: Trick Flow heads [Re: dart games] #1930746
10/12/15 11:16 AM
10/12/15 11:16 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep.
And, as usual, something in the water in Idaho leads to inflated flow bench numbers when compared to two others that are virtually identicle. whistling
Re: Trick Flow heads [Re: GY3] #1930767
10/12/15 12:06 PM
10/12/15 12:06 PM
JohnRR Offline
JohnRR  Offline
Yep.
numbers ??
Re: Trick Flow heads [Re: GY3] #1930793
10/12/15 12:45 PM
10/12/15 12:45 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Yep.
Link me, dude.
I was waiting for the big numbers from "the Idaho bench" to get posted here. Kinda curious they weren't. But numbers higher than everyone else sorta confirms that the bench is boogie
Maybe Jim did a little magical clean up of the factory porting, hence the bigger numbers (at least that is what I'd claim biggrin).
A guy on the bullet mentioned he got one of the first sets of heads. I advised him to send them to Andy F since they're both in the same state. He said he was sending them to Idaho instead. I warned him about the inflated numbers that come out of that part of the country but he sent them anyway.
LINK --- V Scroll to post #48
http://www.yellowbullet.com/forum/showthread.php?t=1178282&highlight=trick+flow+mopar+heads
Re: Trick Flow heads [Re: 64Post] #1930804
10/12/15 01:01 PM
10/12/15 01:01 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
http://www.forabodiesonly.com/mopar/showthread.php?t=328349&page=4
I'm not going to post the numbers here to avoid confusion...
Let's just say ~20 more cfm at .500 lift.
Re: Trick Flow heads [Re: GY3] #1930819
10/12/15 01:24 PM
10/12/15 01:24 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Jim must be throwing a bit more correction into his numbers these days. Frankly, I was expecting he'd come in at 360+ cfm @ .600"-.700". laugh2
Re: Trick Flow heads [Re: 64Post] #1930822
10/12/15 01:34 PM
10/12/15 01:34 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Hey, 40 more HP is nothing to sneeze at! wrench
Re: Trick Flow heads [Re: 64Post] #1930866
10/12/15 02:36 PM
10/12/15 02:36 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It's been my experience that he's usually pretty consistent if he's flowing an as-cast port. It's the "hand ported" results that IMO get really creative. Sometimes darn near impossibly creative.
Re: Trick Flow heads [Re: GY3] #1930880
10/12/15 02:57 PM
10/12/15 02:57 PM
Roughbird72 Offline
Roughbird72  Offline
shock popcorn
Re: Trick Flow heads [Re: moper] #1931058
10/12/15 09:17 PM
10/12/15 09:17 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Maybe Jim has hands like these and can get in the port where no 5 axis machine can...
Re: Trick Flow heads [Re: 64Post] #1931153
10/12/15 11:36 PM
10/12/15 11:36 PM
SoCal
Brian Hafliger Offline
SoCal
Ha ha!
Brian Hafliger
Re: Trick Flow heads [Re: fast68plymouth] #1931483
10/13/15 03:54 PM
10/13/15 03:54 PM
Idaho
LaRoy Engines Offline
Idaho
No problem, I can give you any kind of intake flows you want just by changing the radius plate. (1) no plate, (2) 1/4" clay roll, (3) 1/2" clay roll, (4) radius plate #1, (5) radius plate #2
Lift.......(1).......(2).......(3).......(4).......(5)
.100.....74......75...................75...........75
.200....151.....153................153.........151
.300....206.....225................225.........219
.400....229.....274................279.........272
.500....236.....291................317.........320
.600....239.....295................323.........338
.700....239.....284.....312.....315.........333
And yes, all intake ports I tested began to stall between .600" and .700" lift.
I probably have been making a mistake as to how I open the exhaust valve at the beginning of the test and skewing the opening lift flows. Here is what I get now, on this one port, with no pipe and then w/ my 2" pipe design.
Lift......no pipe......2" pipe w/belled end
.100......52.............53
.200.....119............133
.300.....161............185
.400.....192............227
.500.....211............251
.600.....223............267
.700.....230............273
Re: Trick Flow heads [Re: fast68plymouth] #1931602
10/13/15 08:01 PM
10/13/15 08:01 PM
AndyF Online content
AndyF  Online Content
Yep, head flow numbers don't mean a ton to me unless there is a way to really document everything. I found this out years ago on my own bench when I played around with head placement over the cylinder. It is easy to pick up some cfm my moving the intake over closer to the center of the bore. I finally built a fixture with dowel pins so the head was always in the same location on the bore. I also machined up a radius plate that I used on all heads. Once I did that I was able to start getting repeatable results.
There were some guys on SpeedTalk a while back who had a test fixture which they sent from guy to guy so everyone could calibrate their benches to the same fixture. Something like that makes sense for people who are working back and forth a bunch.
