Re: Any idea pof what...
[Re: DAYCLONA]
#192841
01/13/09 11:32 PM
01/13/09 11:32 PM
Posts: 12,812 Tulsa, Oklahoma
Wagonmaster
Tulsa, Oklahoma
Are you refering to the casting number on the side of trhe block 318-3,....if so, it's a truck designated block(although not necessally installed as such) because the crank is a premium 318 forged unit
That would be the one. Actually, this is supposed to be a '71 engine. Claim was it was a steel crank engine. Now that I found that designation, going with it. [came in my pickup] Also has a 6 qt pan on it [not aftermarket].
This spring I am freshening up the engine with maintenance items like a timing chain/gears, water pump, belts, hoses, etc. Ir has 360 J heads and runs really well. Just trying to validate a few things. Thanks for the responses.
