Re: Replaced a Posi with a spool now the car moves around
[Re: 1980volare]
#1928859
10/09/15 08:10 AM
10/09/15 08:10 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Put a radial on it and enjoy going faster and not dancing around. I think its tire circumference since the only thing that has changed is the swapping in of a spool. Considering drag radials for my next tire purchase, my friends car launches like a fiend with them. Slicks don't bother me though, some walking around the track is just part of the experience in my opinion. If the rest of the car is tight it really should not be a huge problem.
"I think its got a hemi"
[Re: cudaman1969]
#1930745
10/12/15 11:15 AM
10/12/15 11:15 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
What bearing did you use on new axels?
Did you use the green bearings or the taper? Green bearings on Strange axles.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#1931279
10/13/15 09:12 AM
10/13/15 09:12 AM
Jacob Pitt
Mansfield, Tx
I got the car up on jackstands yesterday and checked everything out. Looks like the rearend is in there straight, shackles and bushings on the leaf springs are tight, idler arm and pitman arm are tight. I don't know about the tires yet and I don't know if the housing is flexing or not.
[Re: Jacob Pitt]
#1931287
10/13/15 09:54 AM
10/13/15 09:54 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Measure the rollout. Try adding some pressure just to see if it helps it. I like another 2-4psi in mine than what you do.
[Re: Jacob Pitt]
#1931360
10/13/15 01:09 PM
10/13/15 01:09 PM
Posts: 5,160 Texas
dannysbee
Texas
Measure the distance between the slicks front and back and see if there is any toe in or out. I bet it has always been bent.
Getting old just means you were smarter than some and luckier than others.
[Re: Jacob Pitt]
#1931397
10/13/15 02:10 PM
10/13/15 02:10 PM
Posts: 20,188 Park Forest, IL
slantzilla
Park Forest, IL
Another vote for adding 3-4 psi and see if it makes any difference. If nothing else it's free.
