I have a feeling it's in the rear somewhere especially since I rebuilt the whole frontend and it didn't change anything about how the car handled. I will check the front spring bushings because I believe they were rubber when I installed the springs years ago, and will also check to see if the rearend is square. I will also roll the tires and check them. I will keep you guys updated on what I find.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
