I actually thought that she might be overdriving the car also until I made a pass in it.
I have driven a lot of different cars ranging from all types or tire sizes, suspension setups, and power and some cars will move around and not require any type of steering input. Super Stock cars will get that radial wobble sometimes, but this car has to be corrected going down the track. It swayed with the old alignment with the posi in it and was corrected with the alignment to where it would drive straight down the track in all conditions. Now that the axles are locked together it is highlighting a different issue I need to find. I have two travel races the next two weeks with a LODRS event in Noble,Ok and a National in Dallas so the car is on the back burner since the bracket season is all but over this season.
