Page 3 of 3 1 2 3
Re: Replaced a Posi with a spool now the car moves around [Re: 1980volare] #1928859
10/09/15 08:10 AM
10/09/15 08:10 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Originally Posted By 1980volare
Put a radial on it and enjoy going faster and not dancing around.
I think its tire circumference since the only thing that has changed is the swapping in of a spool.
Considering drag radials for my next tire purchase, my friends car launches like a fiend with them. Slicks don't bother me though, some walking around the track is just part of the experience in my opinion. If the rest of the car is tight it really should not be a huge problem.
"I think its got a hemi"
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1929029
10/09/15 02:27 PM
10/09/15 02:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
On my Duster the idler arm would move up and down about 3/4 inch before making the tie rod move, that tiny bit of play made mine a bear to drive with mix tires. Once I replaced it and had the front end alignment recheck it was good thumbs
Re: Replaced a Posi with a spool now the car moves around [Re: cudaman1969] #1930745
10/12/15 11:15 AM
10/12/15 11:15 AM
Mansfield, Tx
Jacob Pitt Offline OP
Mansfield, Tx
Originally Posted By cudaman1969
What bearing did you use on new axels?
Did you use the green bearings or the taper?
Green bearings on Strange axles.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1931279
10/13/15 09:12 AM
10/13/15 09:12 AM
Mansfield, Tx
Mansfield, Tx
I got the car up on jackstands yesterday and checked everything out. Looks like the rearend is in there straight, shackles and bushings on the leaf springs are tight, idler arm and pitman arm are tight. I don't know about the tires yet and I don't know if the housing is flexing or not.
14x Track Champ
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1931287
10/13/15 09:54 AM
10/13/15 09:54 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Measure the rollout. Try adding some pressure just to see if it helps it. I like another 2-4psi in mine than what you do.
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1931360
10/13/15 01:09 PM
10/13/15 01:09 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Measure the distance between the slicks front and back and see if there is any toe in or out. I bet it has always been bent.
Getting old just means you were smarter than some and luckier than others.
Re: Replaced a Posi with a spool now the car moves around [Re: Jacob Pitt] #1931397
10/13/15 02:10 PM
10/13/15 02:10 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Another vote for adding 3-4 psi and see if it makes any difference. If nothing else it's free.
Page 3 of 3 1 2 3
