MSD PROBLEM #1926809
10/06/15 02:54 AM
10/06/15 02:54 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Built a 340 4 speed and put it in a 80 d100 stepside. Using a 6A #6200 box. I first used a blaster 2 coil and a mallory unilte distributor. No fire. Did the test coil seemed weak. Installed a different coil still no fire. got the son's msd dist. from his 360. Redid the wiring for the msd setup. still no fire. I left the ballast and stock module hooked up. What am i missing.
Re: MSD PROBLEM [Re: rickb67] #1926810
10/06/15 03:09 AM
10/06/15 03:09 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
When using a CD ignition. The ballast resistor is no longer used.
You have the ignition ON wired into a circuit that is only on during the key on position. You need it wired so you have power to it when ON and in CRANK position. Most circuits go dead, when the key is in CRANK position.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: MSD PROBLEM [Re: DemonDust] #1926811
10/06/15 03:21 AM
10/06/15 03:21 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Do i jumper the balast wires or unplug them?
Re: MSD PROBLEM [Re: rickb67] #1926815
10/06/15 03:27 AM
10/06/15 03:27 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
If you have a MSD box, distributor, and coil, you do nothing with the ballast resistor.
Did you check your small red wire to make sure it has power while cranking?
SDG Motorsports
Re: MSD PROBLEM [Re: DemonDust] #1926823
10/06/15 03:45 AM
10/06/15 03:45 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
I will check tomorrow night.
Re: MSD PROBLEM [Re: rickb67] #1926897
10/06/15 10:50 AM
10/06/15 10:50 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Originally Posted By rickb67
Built a 340 4 speed and put it in a 80 d100 stepside. Using a 6A #6200 box. I left the ballast and stock module hooked up. What am i missing.
No need to leave the stock module hooked up. Not sure if thats the issue but i would unplug it
