SAM Engine Masters Challenge Chrysler Poly 402ci
#1926353
10/05/15 03:46 PM
10/05/15 03:46 PM
Posts: 7,197 my own world
theraif
my own world
Re: SAM Engine Masters Challenge Chrysler Poly 402ci
[Re: theraif]
#1926766
10/06/15 12:37 AM
10/06/15 12:37 AM
Posts: 7,635 Minnesota
Hemi_Joel
Minnesota
Cool motor, what did it end up making for power? That would be great for a street rodder who doesn't want a belly button engine. Regarding the statement in the article that the poly was the forerunner of the Hemi, I wonder what they mean? The Hemi was Chryslers first V8, introduced as a 331 in 1951, but the poly didn't come about until 1955. It was introduced as a cost saver, using only 1 rocker shaft per head, and thus a smaller head casting. All 3 generations of Hemi heads use 2 rocker shafts and have nothing in common with the poly.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: theraif]
#1926781
10/06/15 12:57 AM
10/06/15 12:57 AM
Posts: 5,160 Texas
dannysbee
Texas
Joel I thought the same thing but didn't want to give my age away. Hemi's were first. Lol
Getting old just means you were smarter than some and luckier than others.
[Re: theraif]
#1926798
10/06/15 01:35 AM
10/06/15 01:35 AM
Posts: 4,225 New York
polyspheric
New York
Exactly. The 1955-* poly was a reduced-cost V8 for the non-hemi brand (Plymouth), and a cheaper replacement for the high-end DeSoto and Chrysler that previously got a sidevalve L6 (237, 251, 265).
"Other engines permitted in Vintage V8 competition — which are engine families introduced in 1954 or earlier — include the Nailhead Buick, Y-Block Ford, and Packard V8." BTW: also legal for 1954: Olds Rocket, Cadillac, Studebaker (?). Yeah, that 1955-67 poly fits right in there.
If the start date is really 1955, this allows Chevy small block, Pontiac, Rambler, and Lincoln Y block (assuming all hemis have their own class).
Too bad they couldn't find anyone who knew something about the engine. Ooppsss - some of the experts were right in the room. But reporters have a long tradition of "why ask, when you can just make stuff up?" (also true of all political events).
Just a guess at the cam specs: 1. short duration 2. very high accel & vel (test: the nominal and .050" durations are very close together) 3. very high ratio rockers, like 2:1 4. very small LSA, like 100
Boffin Emeritus
[Re: theraif]
#1926937
10/06/15 10:40 AM
10/06/15 10:40 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
The article said they were at 1.5hp/ci @ 6000 rpm.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: theraif]
#1927036
10/06/15 01:13 PM
10/06/15 01:13 PM
Posts: 12,543 Kalispell Mt.
HotRodDave
Kalispell Mt.
I was wondering the same thing about the poly being the daddy of the hemi, born 3 years later?
1.5 hp per cube at 402 CID = 600+ HP... is that even remotly possible with those heads? Never heard even the most optomistic of flow numbers getting anywhere close to enough air flow?
I am watching engine masters this year but it is just interesting and not much of a competetion as each class only has a handfull of participants. Looks like a couple of last years winning gen III hemis came back almost un changed and beat the other hemi in the challenge.
[Re: WO23Coronet]
#1927163
10/06/15 04:16 PM
10/06/15 04:16 PM
dogdays
Well, the intake valve is canted, the exhaust is at 0 degrees.
I looked at the facebook pictures, the piston sitting at zero deck is the Sealed Power P814CP which has a compression height of 1.755". In a 9.600" block with a 6.123" rod, the piston should be 0.067 down in the hole. And in the late LA 9.577" block, it should be 0.044" down. So how did they get it to zero deck? Either stroked the crank or a 6.2" rod.???
BTW, I love those $1000+ rocker arms, I'm going to buy a set right after I buy their $700 intake manifold. But wait, the Enginemasters entry didn't use it.
Years ago I was posting about Poly head flow and Brian at IMM replied that he had worked on some much earlier, lost the flow sheets, but he remembered that the best results came from moving the intake port up as far as it would go. But to go from 210cfm to 330 is beyond my wildest expectations.
R.
I hope those guys haven't quit their day jobs. As much as I love the Poly motor it isn't worth all the hype they're trying to stir up.
[Re: dogdays]
#1927236
10/06/15 06:41 PM
10/06/15 06:41 PM
Posts: 1,057 The Great White North
RAMM
R.
I hope those guys haven't quit their day jobs. As much as I love the Poly motor it isn't worth all the hype they're trying to stir up. Haha! You and Monte should get together and enter and go to the EMC. The EMC is like the ultimate gearheads "Science Fair". Only this fair/expo is applied to engines within a specific set of rules. Very few "Big" name builders dare to enter. What would happen to their "status" if they had their arses handed to them--and most of them would BTW. lol J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: theraif]
#1927253
10/06/15 06:59 PM
10/06/15 06:59 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Yep.......Kaase and BES are no names........LOL.........and it seems like they win more than they lose. Oakley Motorsports also has an entry this year. VERY well known in Top Sportsman, Top Dragster and tractor pulling circuits
Why do I need to enter. I don't have an engine shop and have way more important things to do than build some one off type "science project" motor for a competition, that would be of no use to me otherwise. Just because you put a lot of stock in it, doesn't mean everybody should...............but none of that changes what I said. Tell us how "practical" it is to build a 600hp poly headed Mopar, that likely cost them 20K or better to build, if they had to pay for all that stuff. The EFI stack injection alone would be 10k. Being that it is a SAM engine, that is something that Judson can use to teach principles and show what can be done...........but in real life, who else would build that and for what?
I ultimately respect the EMC competitors, what they do and the power they pull from unusual combinations, but it is not something that appeals to me in the least bit to actually do.
I know how much time and money Phillip spent on his motor and I know Kaase spends a crazy amount of time and money on his projects. I can't do that. Kaase's shop manager is a friend of mine, see him at the races all the time. He told me on some of those motors, that they have tried dozens of cams, several sets of heads, different rod lengths, different pistons, etc. That's a LOT of time and money. Tinkering and that competition is just something that John likes to do, so it's a no expense spared hobby for him
[Re: Monte_Smith]
#1927269
10/06/15 07:17 PM
10/06/15 07:17 PM
RAMM
Why do I need to enter. I don't have an engine shop and have way more important things to do than build some one off type "science project" motor for a competition, that would be of no use to me otherwise. Just because you put a lot of stock in it, doesn't mean everybody should...............but none of that changes what I said. Tell us how "practical" it is to build a 600hp poly headed Mopar, that likely cost them 20K or better to build, if they had to pay for all that stuff. The EFI stack injection alone would be 10k. Being that it is a SAM engine, that is something that Judson can use to teach principles and show what can be done...........but in real life, who else would build that and for what? Got your blinders on Monte? I said VERY FEW big name builders enter. You mentioned Oakley--not me. You're right BES,Kaase, and SAM do win, that is not in dispute here. I never disputed the practical aspect of anything EMC-EVER. It is a CHALLENGE-just like maybe you approach or regard your nitrous projects-nothing more. SAM's engine likely cost WAY more than what you have stated by a fair margin I would wager. I never said "Everyone on planet Earth HAS to regard the EMC as the greatest event ever" Christ you'd make someone a good wife 'cuz you sure no how to [censored]. J.Rob p.s. I give up--you're right I am wrong. Please forgive me honey 'er Monty.
[Re: RAMM]
#1927279
10/06/15 07:36 PM
10/06/15 07:36 PM
Monte_Smith
North Alabama
Why do I need to enter. I don't have an engine shop and have way more important things to do than build some one off type "science project" motor for a competition, that would be of no use to me otherwise. Just because you put a lot of stock in it, doesn't mean everybody should...............but none of that changes what I said. Tell us how "practical" it is to build a 600hp poly headed Mopar, that likely cost them 20K or better to build, if they had to pay for all that stuff. The EFI stack injection alone would be 10k. Being that it is a SAM engine, that is something that Judson can use to teach principles and show what can be done...........but in real life, who else would build that and for what? Got your blinders on Monte? I said VERY FEW big name builders enter. You mentioned Oakley--not me. You're right BES,Kaase, and SAM do win, that is not in dispute here. I never disputed the practical aspect of anything EMC-EVER. It is a CHALLENGE-just like maybe you approach or regard your nitrous projects-nothing more. SAM's engine likely cost WAY more than what you have stated by a fair margin I would wager. I never said "Everyone on planet Earth HAS to regard the EMC as the greatest event ever" Christ you'd make someone a good wife 'cuz you sure no how to [censored]. J.Rob p.s. I give up--you're right I am wrong. Please forgive me honey 'er Monty. Exactly what is it, you have your panties in a wad about? All I said was the motor was very cool, very expensive and very impractical........points you in fact agree with........Then you drug me in, by saying that I should enter the contest with some other guy after HE made a comment. YOU are the one who drug me in this debate.......and I really don't even see what you are disagreeing with me about. Seems you are the one being the "woman" here.......starting the whole thing and just arguing to be arguing
[Re: Monte_Smith]
#1927284
10/06/15 07:42 PM
10/06/15 07:42 PM
RAMM
Seems you are in a toxic relationship with all things MOPAR.
Listen up everyone! Don't do anything or have interest in
anything Monte Smith doesn't approve of or else! J.Rob
[Re: theraif]
#1927316
10/06/15 08:41 PM
10/06/15 08:41 PM
Posts: 10,958 Oakdale CT
gdonovan
Oakdale CT
Cool engine! Sounds like it has a lot of squeeze during cranking.
"I think its got a hemi"
