Page 3 of 6 1 2 3 4 5 6
Re: Trick Flow Mopar head [Re: Trick Flow] #1923995
10/02/15 10:22 AM
10/02/15 10:22 AM
Canada
Criterion Offline
Criterion  Offline
Canada
A typical steel retainer with a 7 or 10 degree lock, depending on what springs you choose.
Re: Trick Flow Mopar head [Re: Criterion] #1924035
10/02/15 11:35 AM
10/02/15 11:35 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Criterion
Here's an image album of them: Powerport 240 gallery
Cool, REAL heads! up
Re: Trick Flow Mopar head [Re: Trick Flow] #1924046
10/02/15 11:51 AM
10/02/15 11:51 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Those look nice
68 Barracuda Formula S 340
Re: Trick Flow Mopar head [Re: Trick Flow] #1924099
10/02/15 01:24 PM
10/02/15 01:24 PM
Renton Washington
Triple Threat Offline
Renton Washington
Those look very nice. Are there flow numbers out there anywhere?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Trick Flow Mopar head [Re: Trick Flow] #1924107
10/02/15 01:29 PM
10/02/15 01:29 PM
Canada
Criterion Offline
Criterion  Offline
Canada
Lift Value Intake Flow CFM Exhaust Flow CFM
.100″ 78 58
.200″ 154 130
.300″ 230 186
.400″ 282 222
.500″ 310 243
.600″ 326 253
.700″ 334 262
Tests conducted at 28″ of water (pressure). Bore size: 4.350″; exhaust with 2″ pipe.
Re: Trick Flow Mopar head [Re: Trick Flow] #1924150
10/02/15 02:28 PM
10/02/15 02:28 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
WOW, that does look nice
2011 Drag Pak Challenger
Re: Trick Flow Mopar head [Re: Trick Flow] #1924164
10/02/15 02:42 PM
10/02/15 02:42 PM
Idaho
LaRoy Engines Offline
Idaho
I think there will be a lot more information available soon from various sources, as the first pair will arrive here at our shop Tuesday.
Re: Trick Flow Mopar head [Re: LaRoy Engines] #1924199
10/02/15 03:14 PM
10/02/15 03:14 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Will you be diving in and porting them right away? or bolting them on an engine. I'm Excited to hear there potential.
Re: Trick Flow Mopar head [Re: Trick Flow] #1924320
10/02/15 06:09 PM
10/02/15 06:09 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
I'm definitely buying a set of these heads. I wish they had a matching dual plane intake to match.
Re: Trick Flow Mopar head [Re: 70RT Charger] #1924896
10/03/15 02:11 PM
10/03/15 02:11 PM
BradH Offline
BradH  Offline
No dual plane in that port size can match the flow potential of those new heads. You could use a Performer RPM, but it will cost you power on a combination otherwise intended to take advantage of those heads. Not a good match of parts, IMO.
Re: Trick Flow Mopar head [Re: Criterion] #1924906
10/03/15 02:32 PM
10/03/15 02:32 PM
BradH Offline
BradH  Offline
.100″ 78 58
.200″ 154 130
.300″ 230 186
.400″ 282 222
.500″ 310 243
.600″ 326 253
.700″ 334 262
Too bad my flow bench isn't back together, yet. It would be interesting to see the results from another independent bench.
Re: Trick Flow Mopar head [Re: Trick Flow] #1924935
10/03/15 03:22 PM
10/03/15 03:22 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Brad, which head do you feel would be a better option to bolt an RPM intake onto for $1979?
A customer of mine supposedly ordered a set a week ago, so I'm hoping to have them here to test fairly soon.
Re: Trick Flow Mopar head [Re: Trick Flow] #1924950
10/03/15 03:40 PM
10/03/15 03:40 PM
Canada
Criterion Offline
Criterion  Offline
Canada
If the engine is an RB, use the Indy dual plane. If it's a B, use a single plane and make the best of it by camming the motor correctly. Another alternative would be to port the RPM if you're trying to keep up with the heads. Hughes Engines' site has reference flow numbers and comments on various aftermarket intakes.
Dollar for dollar, I don't think much is going to touch these heads in a stock port window street application, out of the box.
Re: Trick Flow Mopar head [Re: fast68plymouth] #1924960
10/03/15 03:47 PM
10/03/15 03:47 PM
BradH Offline
BradH  Offline
IMO, the build that person talked about previously sounds like a better fit for a mildly worked-over set of Sidewinders, especially if he's target-locked an a d-p intake for whatever reason. Would save him some $$$, too. This is the same guy who had a "hissy fit" over the idea of having to spend more $$$ on better-than-OEM rockers to go along w/ some new heads, too. shruggy
I'd like to see some TF #s from your bench even more than mine, considering the extra "horsepower" your Saenz has to test 'em. grin
So... would you think the standard-port location TFs would make more HP than my old raised-port Stage VIs, since the TFs boast more "raw" CFM? If I wasn't so invested in Victors right now (heads, offset lifters & rockers, etc.), I'd be really curious how just swapping out my old Stage VIs for a set of TFs along w/ the COMP .650" RX roller you got me would work. They would even have the same compression ratio, too.
Re: Trick Flow Mopar head [Re: Trick Flow] #1924976
10/03/15 04:10 PM
10/03/15 04:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
If the TF heads really flow what they claim, and the port volume is only 240cc's, then I think these will be pretty tough to beat on a pump gas hot street/strip 440-470 type combo.
If they actually flow 330+, that's 15+ better than a MCH CNC stealth on my bench, and 12cc's smaller port volume and a bigger valve.
I have numbers from my bench and your stage 6's, so it will be interesting to see how they compare side by side. IMO, what those 6's really had going for them was decent flow from pretty small port volume, which I feel is a good combo for moderate cube pump gas motors running in heavy-ish cars with closed exhaust systems.
If the TF's flow 330+, then I think the real apples to apples heads to compare them to are going to be the Hughes std port EZ's where they CNC the chambers and fill in the lip on the intake roof. But those cost $800 more.
Both are std port heads, heart shaped chambers, std height ex ports, std rocker arms.
I guess you could include some CNC ported 75cc edelbrock heads too, but they are also over $500 more than the TF's.
That would be a pretty fun dyno shoot out. Those three heads on like a 505 pump gas short block, try a couple different intakes on each set of heads.....see how it all shakes out.
Re: Trick Flow Mopar head [Re: fast68plymouth] #1924993
10/03/15 04:35 PM
10/03/15 04:35 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I was thinking that considering all of the constraints on a "replacement" type head, that we are approaching diminishing returns. I was also thinking the same thing on the 75 cc Eddy head. MCH CNC but with the 2.19 and irrespective of the flow bench numbers, the real winner could only be determined on a dyno, or better, in a car.
Re: Trick Flow Mopar head [Re: Trick Flow] #1925012
10/03/15 05:12 PM
10/03/15 05:12 PM
So. Burlington, Vt.
So. Burlington, Vt.
My gut feeling is that on a 440-451ci package, assuming the TF heads flow as advertised, they would likely be the "winner". I also feel that at 500"+ the reworked EZ would prevail, provided there was enough cam and a good enough manifold to allow the motor to peak high enough to take advantage of the extra volume.
Re: Trick Flow Mopar head [Re: Trick Flow] #1925084
10/03/15 06:44 PM
10/03/15 06:44 PM
AndyF Offline
AndyF  Offline
I should have a 470 inch B block on the dyno in a month or so with the TF heads. Pump gas engine with a solid roller. PipeMax says it will make 680 hp so I guess we'll see how close it comes.
Re: Trick Flow Mopar head [Re: AndyF] #1925091
10/03/15 06:58 PM
10/03/15 06:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Andy.. that 680 hp.. is that the min, average or max
on pipemax... I havent figured that out over all these
years... mine has always been near the min or slightly
above that
wave
Re: Trick Flow Mopar head [Re: Trick Flow] #1925132
10/03/15 08:23 PM
10/03/15 08:23 PM
AndyF Offline
AndyF  Offline
680 was the low, 700 was the high. This was based on a total intake flow of 310 cfm which is a bit of a guess. Once I have the heads I can bolt the intake and the carb on and see what my little flow bench says.
