Radio delete question #1922465
09/30/15 01:58 PM
09/30/15 01:58 PM
Gateway to the West.
hemi_harvester Offline OP
I'm trying to find out when ( year ) Chrysler went from a blank fender top ( no hole ) to a fender with the hole and chrome plug ..
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Radio delete question [Re: hemi_harvester] #1922552
09/30/15 04:11 PM
09/30/15 04:11 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is a good question as I have had a 67 Dart radio delete that had no hole in the fender and a 69 Dart with radio delete with a plastic plug that looked like a power antenna that was in the fender?!? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Radio delete question [Re: hemi_harvester] #1922557
09/30/15 04:27 PM
09/30/15 04:27 PM
Illinois
blackdart Offline
blackdart  Offline
Illinois
I have an early 68 GTS with radio delete with a chrome plug in the passenger fender. An old Chrysler mechanic told me that if a car needed a radio the front fender had to be drilled out at his dealership. I am confused about this for you would believe that the great majority of new cars would come with an am radio and it would be easier on the assembly line to have all the right front fenders pre-drilled for an antennae.
Re: Radio delete question [Re: hemi_harvester] #1922839
09/30/15 10:08 PM
09/30/15 10:08 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
My 68 Barracuda notch does not have the hole.
Master, again and still
Re: Radio delete question [Re: hemi_harvester] #1922871
09/30/15 10:44 PM
09/30/15 10:44 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Radio Deleted
Re: Radio delete question [Re: hemi_harvester] #1922911
09/30/15 11:11 PM
09/30/15 11:11 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I THINK I remember it being '73. That is when they went to the raised mounting area with a flat base, IIRC.
The antennae came in a box (in the trunk usually), an installation kit with a template for where to drill the hole.
Some of our customers in rural Vermont would have us put the antenna on the left, so that low branches on our dirt roads wouldn't bend/break them off.
The short one piece masts pretty much ended that problem anyhoo.
If a fender doesn't have the raised mounting position and has a plug of some sort in the hole it is because it at one time DID have an antenna or at least the prep guys messed up and drilled without looking inside.
It takes gasoline to interest me.
Re: Radio delete question [Re: hemi_harvester] #1923784
10/01/15 11:16 PM
10/01/15 11:16 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Deleted
Re: Radio delete question [Re: hemi_harvester] #1923789
10/01/15 11:27 PM
10/01/15 11:27 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I just bought a 1970 Superbee that is radio and heater delete. It has 40699 miles on it, but along the way it did get a radio installed.
Need to check if the fender has a factory stamped hole or not.
I have 70 Challenger R/T that is radio delete and that fender has no hole.
Re: Radio delete question [Re: hemi_harvester] #1924245
10/02/15 04:02 PM
10/02/15 04:02 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Deleted
Re: Radio delete question [Re: Rhinodart] #1924256
10/02/15 04:26 PM
10/02/15 04:26 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I had a '68 Dart no radio car and there was no hole in the fender.
Parted out a couple Aussie cars too that were both radio and heater delete and no fender hole in them either..
Re: Radio delete question [Re: Rhinodart] #1924644
10/03/15 01:17 AM
10/03/15 01:17 AM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
My 71 Duster 340 was ordered without a radio. I am convinced one was added by the dealer who used an aftermarket (TRW) brand antenna. The hole cut in the fender was a crude circular cut and not like the factory where it is a stamped out hole. So no hole in the original fender. My opinion on the TRW brand antenna used by dealerships is because I have seen so many radio delete cars with that same antenna!
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Radio delete question [Re: 340wedge] #1924669
10/03/15 01:52 AM
10/03/15 01:52 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
No hole on my 69 polara 500
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Radio delete question [Re: hemi_harvester] #1924836
10/03/15 12:24 PM
10/03/15 12:24 PM
Rapid City, South Dakota
six-pack-mopar Offline
Speaking of cars that were radio delete, does anyone have the factory chrome plug that some are stating filled the fender hole? I would like to pick one up from someone is they have one.
Thanks,
Buddy 605 390 1950
Re: Radio delete question [Re: hemicar1971] #1925331
10/04/15 01:08 AM
10/04/15 01:08 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By hemicar1971
So to change the direction of the thread a little can you tell more about this 1970 Superbee. Any heater delete pictures of the ducts and dash faces and firewall.
I didn't want to highjack this thread so I created this post
https://board.moparts.org/ubbthreads/ubbt...tml#Post1925318
