Radio delete question
#1922465
09/30/15 01:58 PM
09/30/15 01:58 PM
Posts: 3,449 Gateway to the West.
hemi_harvester
I'm trying to find out when ( year ) Chrysler went from a blank fender top ( no hole ) to a fender with the hole and chrome plug ..
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Radio delete question
[Re: hemi_harvester]
#1922557
09/30/15 04:27 PM
09/30/15 04:27 PM
Posts: 1 Illinois
blackdart
Illinois
I have an early 68 GTS with radio delete with a chrome plug in the passenger fender. An old Chrysler mechanic told me that if a car needed a radio the front fender had to be drilled out at his dealership. I am confused about this for you would believe that the great majority of new cars would come with an am radio and it would be easier on the assembly line to have all the right front fenders pre-drilled for an antennae.
#1922839
09/30/15 10:08 PM
09/30/15 10:08 PM
Posts: 12,078 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My 68 Barracuda notch does not have the hole.
Master, again and still
#1922911
09/30/15 11:11 PM
09/30/15 11:11 PM
Posts: 1,357 central Florida
VL21
central Florida
I THINK I remember it being '73. That is when they went to the raised mounting area with a flat base, IIRC.
The antennae came in a box (in the trunk usually), an installation kit with a template for where to drill the hole.
Some of our customers in rural Vermont would have us put the antenna on the left, so that low branches on our dirt roads wouldn't bend/break them off.
The short one piece masts pretty much ended that problem anyhoo.
If a fender doesn't have the raised mounting position and has a plug of some sort in the hole it is because it at one time DID have an antenna or at least the prep guys messed up and drilled without looking inside.
It takes gasoline to interest me.
[Re: Rhinodart]
#1924256
10/02/15 04:26 PM
10/02/15 04:26 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
That is a good question as I have had a 67 Dart radio delete that had no hole in the fender and a 69 Dart with radio delete with a plastic plug that looked like a power antenna that was in the fender?!? I had a '68 Dart no radio car and there was no hole in the fender. Parted out a couple Aussie cars too that were both radio and heater delete and no fender hole in them either..
[Re: Rhinodart]
#1924644
10/03/15 01:17 AM
10/03/15 01:17 AM
Posts: 2,763 Myrtle Beach, SC formerly the ...
340wedge
My 71 Duster 340 was ordered without a radio. I am convinced one was added by the dealer who used an aftermarket (TRW) brand antenna. The hole cut in the fender was a crude circular cut and not like the factory where it is a stamped out hole. So no hole in the original fender. My opinion on the TRW brand antenna used by dealerships is because I have seen so many radio delete cars with that same antenna!
1971 Sassy Grass Green Duster 340 2006 Charger Daytona GoMango
[Re: 340wedge]
#1924669
10/03/15 01:52 AM
10/03/15 01:52 AM
Posts: 3,378 KY USA
mopargem
KY USA
No hole on my 69 polara 500
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
